- Donor 2023
- x 4
- x 20
Please can someone check if part number - 9675056980 has been replaced with a new number?
It's a drive shaft nut for a C4 Picasso 2014 (MK2)
It's the part number listed on a parts diagram site I use, but I can't find it in any UK websites.
- x 1119
Yes, showing replaced with 9813722580 which is common on all cars.
- x 20
Hello,
Please could you try and find the part number for the accelerator pedal with sensor for my C4 Picasso (mk2)
I think it's 9674829880 but want to double check.
Thank you
Thank you
- x 6373
Here you go:
Part: 9674829880, £223.67
- x 20
Thanks.
I'm assuming it's just a plug and play part - and I don't need to code it/calibrate it to the car in Diagbox?
It's got an electrical connection block on it at the top, so assume it's just a straight swap.
- x 6373
No coding needed, just follow the relevant parts of the BSI Reset / Battery Disconnect / Reconnect Procedure before and after. There are 3 bolts and a connector. Ensure bolts are tightened to 0,8 daNm after fitting.
- Donor 2023
- x 6
I am looking for the part number for the rear ABS wiring with connectors (not the sensors) it's the section of wiring that runs from the rear wheels to the connectors that are underneath the carpet in the rear.
Many thanks
Duncan.
Many thanks
Duncan.
- Donor 2023
- x 382
Could i please have the part number for my C5 X7 Alternator and the freewheel pulley please assuming they are supplied separate.
Colin
Colin
- x 6373
Hi Duncan. The harness shown Item (5): part: 9810156480, £473.44 inc. VAT, so you may be better off repairing the relevant section.Dustysweeper wrote: ↑01 Mar 2023, 19:10 I am looking for the part number for the rear ABS wiring with connectors (not the sensors) it's the section of wiring that runs from the rear wheels to the connectors that are underneath the carpet in the rear.
Many thanks
Duncan.
- x 6373
Which vehicle Colin? The last 3 of the relevant VIN will do. Also, please can you clarify if you mean the alternator tensioner roller?
- Donor 2023
- x 382
Sorry Marc my C5.
The alternator itself and the additional freewheel pulley which may come attached
Last 4 digits 7926
Colin
Last 4 digits 7926
Colin
- x 6373
OEM New Citroen Original, part: 9803750980, £1,106.40*
Cheaper Alternative Exchange Alternator, part: 1648236080, £507.38*
Exchange Valeo Original. part: 5702J4, £559.79*
(7) Dynamic Tensioner Roller, part: 1611425780, £136.42
* Note there's an £84 surcharge on any of these items, refundable on return of the old one.
- Donor 2023
- x 382
Thanks Marc
Looks like at those prices i will get a spare just incase they run out of stock
Colin
Colin
- x 21
Good afternoon Marc, Looking for the reverse sensors for my car please? also could you confirm the brake rotor size? there's two sizes available and i think mines the 283mm one just wanna double check. Thank you!
