Marc,
Looking for the front and rear window washer diagrams and associated part numbers for the C5
Kenny
- Donor 2022
- x 127
- x 4922
Let me know the specific item numbers from each diagram you require Kenny:
Diag A Front
Diag B Rear
Diag A Front
Diag B Rear
- x 4922
- Donor 2023
- x 5
Hi Marc.
Spark plug numbers or makers code please.
I want to try a brand other than Bosch.
Thanks.
Thanks.
- x 4922
- Donor 2022
- x 127
Thanks for the diagrams Marc, Simple job made difficult by complicated design.
Kenny
Kenny
- Donor 2022
- x 127
Sorry Marc, further request
Can you confirm the right part no for the Air deflectors item 5 on the diagram for Underbody protection. My one was ripped off by something in or floating in a large puddling didn't realise until later when inspecting vehicle.
Kenny
Kenny
- x 4922
Here you go Kenny, better sit down with a stiff whisky
Item (5) Front Deflector
Right, part: 7013LM, £189.54
Left, part: 7013LN, £245.95
- Donor 2023
Hi all,
Can anybody supply the part number and the price for each of the following parts.
Power steering low pressure pipe
Power steering high pressure pipe
My VIN is VF7**************[VIN obfuscated, can be read by forum staff] and the RPO is 11551.
I had a conversation with the Citroen main dealer today and they informed me that these parts are not available any more
Any help much appreciated.
Regards
Konstantinos
Regards
Konstantinos
- x 4922
Here you go:
(1) Steering High Pressure Pipe, part: 4014X0 (No Longer Available)
(2) Steering Low Pressure Pipe, part: 4012P4 (No Longer Available)
(3) Power Steering Pump Supply Low Pressure Pipe, part: 4012A3, £34.21
Unfortunately this is the case now. Only Pipe (3) is showing as available from Citroen.
- Donor 2022
- x 127
Thanks Marc. I'm think of buying a piece of sheet hdpe and making same.
Kenny
Kenny
- Donor 2023
Morning Marc,
Thank you for the quick reply. Any suggestions/ideas what can i do or where to go to look for the pipes? Can you also please supply the steering rack part number and I am assuming the LDS fluid is still valid for my car.
I struggling to believe that I have to scrap the car for 2 pipes. I have also a request to a company called brakequip https://brakequip.co.uk/. Have you ever deal with them?
Regards
Konstantinos
Regards
Konstantinos
- x 4922
Yes Total LDS Fluid or Total Fluid DA is correct for the C5 X7. It uses the same fluid for the suspension system (hydraulic suspension) or for metallically sprung vehicles like yours in the power steering reservoir.
(1) Power Steering Rack, part: 1610577580, £1,772.68 from Citroen inc. VAT.
Bear in mind if you are getting a replacement rack elsewhere, it should be 180 degrees steering angle on this specific vehicle.
I haven't used that company, but do let us know on a separate thread if they are able to make up a suitable hose.
- Donor 2023
Hi Marc,
I am assuming the first digit for the above part number for the steering rack is 9 instead of 1? Can you please confirm if the above number is also equivalent to 4001 63 or 4001EA.
Regards
Konstantinos
Regards
Konstantinos
- Donor 2022
- x 19
Hi Marc,
Peugeot 306 again, VF3**************[VIN obfuscated, can be read by forum staff]
I'm after a set of injector seals (copper washers, fire washers) and sleeves please.
Many thanks
Many thanks
