Rhothgar
Donor 2023
x 99
Re: Citroen and Peugeot Parts Requests
Unread post by Rhothgar »
GiveMeABreak wrote: 28 Nov 2021, 11:57 The only one Citroen supply separately is item (9) Wishbone bush, part 96083570 £22.15
The other bushes are supplied as part of the actual wishbone item (2) which includes the item above and 'B' & 'C', parts:
OEM = (Citroen Original)
Left: 3520C1 (No longer available)
Right: 352181 (No longer available)
Citroen Cheaper Alternatives:
Left: 1607312780 £147.94
Right: 1635775380 (No longer available)
Is it time to scrap? Nah! Not yet.
Seem to have found the rear bush in Italy but it is £33 plus £33 postage!!! It is what it is. Also, part is compatible with many Volvos of the period so that's another option before going too far afield.
I replaced C on nearside last year with a pattern part.
Thanks for all your help Marc.
Would it be of any use if I speak to the owner of PowerFlex bushes that I know through business for any other bush parts for Citroens? I think she could make popular items if enough interest in certain hard-to-get models?
x 6373
Spareto do the complete wishbone with the bushes for about £100 inc VAT and shipping - so may be worth considering that.
Peter Morgan
(Donor 2021)
Unread post by Peter Morgan »
Hi again Marc,
If I want to get a second hand one, do you know if its fitted to other models (eg C4)?
Best regards
x 6373
Hi Peter - this part was unique to the Citroen C8 and the Peugeot 807. Same part number, so if you search the part number it should be relevant to both vehicles.
Beware just searching for similar units by name as they will not be compatible from different models - for example the C4 Picasso used a completely different mechanism for those models equipped with a wheel carrier.
Peter Morgan
(Donor 2021)
Great, Thank you very much Marc
207Peugeot14
(Donor 2021)
Unread post by 207Peugeot14 »
Hi
I'm after the part number for the turbo position sensor on my peugeot 207 1.4hdi 2011
Vin number VF3**************[VIN obfuscated, can be read by forum staff]
I understand you can buy the whole actuator from peugeot for a small mortgage but i am just after the sensor on the end of it, that can be bought on ebay, or turbo suppliers.
Many thanks Simon
x 6373
The turbo Actuator item (3) is part 9815218180, priced £287.81. They don't sell or have a part for the sensor at the end.
A brand new Turbo from Peugeot is part: 0375Q9. £1290.24
Or an exchange turbo is part: 0375R0, £715.81
Prices inc. VAT direct from Peugeot.
Huskyxantia
Donor 2023
x 472
Unread post by Huskyxantia »
Ive 2 chuffing injectors on my picasso, i need the seal kit its a mine field went to a motor factor and was told there are 6 types of sets ?? any help on the part numbers ..
Husky. :?
x 6373
Guys - you need to be specific, I'm not a mind reader for those that have multiple cars in their profiles...
Either quote the VIN or if I have it already from past requests, just tell me the vehicle in your profile.
Huskyxantia
Donor 2023
x 472
GiveMeABreak wrote: 29 Nov 2021, 12:16 Guys - you need to be specific, I'm not a mind reader for those that have multiple cars in their profiles...
Sorry marc, im hunting all over the net at the mo,
Ok here my details, 2003 2.0l hdi vin ...VF7**************[VIN obfuscated, can be read by forum staff]
-6 ! Not the best temperature for this sort of task cold hands...
Husky. :?
x 6373
Just as well I asked then as this is for a Xsara Picasso - not listed with you. :wink:
The Injector Seal is shown. Choices are below - both the same price and prices are for each seal.
OEM Original, part: 198196 £3.61
Eurorepar alternative, Part: 198145, £3.61
Huskyxantia
Donor 2023
x 472
Your a GOD ... was going to add my injector number 0445110076.. mine has black top sleeve bottom copper washer whats no9 ?
Husky. :?
x 6373
(9) is the Injector Protector, Part: 198260, £3.78 each.
Huskyxantia
Donor 2023
x 472
Mine looks like it has a black sleeve that sits top on the inner injector hole thats what it looked like when they all had to come out because of flood water, would dare i say ebay be a place to check too ? Im getting muddled now theres lots
Husky. :?
x 6373
Just get them from Citroen using the part numbers I provided if you want to be sure. This diagram is for your engine as per the VIN you gave me. I'm not sure what you're referring to but if it's part of the injector it won't be shown here as a separate part other than what is on the diagram. Is it possible someone else has been there before you and fitted wrong parts?
