x 4930
Post by GiveMeABreak »
admiral51 wrote:
03 Dec 2022, 16:53
Hi
Could i have the part number for the Brake Pedal Switch for my C5 X7 and if it is possible can i trust GSF/ECP to have a decent one and the location of said switch .
Thanks in advance:)
Colin
Colin
See my detailed post here concerning this issue including pictures parts and the TSB related to it:
viewtopic.php?p=737797#p737797
x 755
Post by RichardW »
@Matt
1422A3 looks like the right thing, 2 off at the top of the housing? £6.49 each
Banjo washers are 015708 stated as 12.2x18 EP3 [which I would take to be 12.2mm id x 18mm od x 3mm thick?) £2.86 each (!)
Middle VIN is not recognised?
Inlet manifold seal is 1635T8, but it's NFP
@ Colin
Part No 453467 at £55.13. In the passenger foot well.
x 4930
MattBLancs wrote:
03 Dec 2022, 16:12
Hi Marc,
Please could you confirm the part numbers and cost for the following when you get chance, no rush:
- 1.6 HDi DV6 air filter housing rubber mounts - think is 1422A3 - rather expensive on eBay.
- Also turbo banjo bolt copper washers - are there any dimensions given in the description, not just part number+ cost? Having trouble getting a seal at this joint.
Associated VIN
Item (3) Intake Air Filter Bracket, part: 1436S4, £20.98
(Note the individual parts are not shown as separate - so may be included in the bracket as per the exploded view).
(15) Manifold Uncoupling Stud, part: 1422A3, £6.49
- EW10J4 oil filter housing seal (between block and filter bracket)
Associated VIN
Invalid VIN or VIS Matt
- EW10J4S inlet manifold to throttle body gasket
Sorry don't have a VIN associated with this. Engine fitted to 206 GTi 180, C4 VTS, 307 CC, etc
This is for a C4 180:
Item (9), Intake Valve Seal Piece, part: 1635T8, but no longer available.
Donor 2022
x 940
Post by MattBLancs »
RichardW wrote:
03 Dec 2022, 18:08
@Matt
Banjo washers are 015708 stated as 12.2x18 EP3 [which I would take to be 12.2mm id x 18mm od x 3mm thick?) £2.86 each (!).
RichardW, Marc, thanks both! Sorry I'd forgotten about the two at the bottom (changed previously) you were correct guessing the upper two. Wow they have gone up, am sure I bought some previously from the dealer as was a good price, turns out the eBay ones are now cheap!
Will measure the existing banjo washers tomorrow (enough out in the cold today, brrrrr!) ID and OD sound about right but the current ones (which may still be incorrect) are pretty thick but never 3mm! That's a mega washer! Can't think what EP might stand for in French that would give us the answer.
EDIT to avoid adding off topic additional posts on here.
Current washers are
ID 12.21
OD 18.35
Thickness 2.76
So going to say all guessed dimensions absolutely spot on correct :)
Donor 2022
x 940
GiveMeABreak wrote:
03 Dec 2022, 18:20
Associated VIN
VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Whoops, try again! Never before spotted the Coupe's dash mounted VIN is so low down it's behind the black "dotty section" bordering the bottom edge of the screen! (and keys were inside so being lazy to pop the bonnet)
Part number gives me something to search for, so appreciated all the same - thank you!
I knew I would forget something, could I have part number for the 206's fuel tank cap sensor too please?
I'm not sure if will be listed separately as seems to be on a shared plug as far as I can see (not ascertained what the other cables are doing)
For ease of reference that is against
Thanks again
x 4930
Item (3), Filter Cartridge Support Seal, part: 110437, £6.49
206
Item (20) Fuel Cap Presence Harness, part: 1503Y1, £208.56
Dormouse
Donor 2022
x 418
Post by Dormouse »
Marc, do you never get a break?
I think you are long overdue a big thank you.
cheers
Donor 2022
x 940
Brilliant, thanks Marc!
Ouch, that sensor isn't cheap! (Seen various others online, not this part but "PSA cap sensors" generally, in the sort of £30-£50 region... Oh well, the gasket is cheap! :)
dave101ua
Donor 2023
Post by dave101ua »
Hello Marc!
Could you please give me part number of a part that I don't know what is proper name in English,
I found that in German it is Spurstangenkopf Google translate says that English version is tie rod head
Here is URL for example to see what I mean https://www.autodoc.lu/ridex/14539955
I need part numbers for both left and right parts please
Also, what are break pads numbers as well, please? (rear and front ones cause they are different)
car is Citroen C4 Grand Picasso
Thank you !
x 4930
Here you go:
Item (5) Steering Rod Ball Joint Kit
Citroen Original Left, part: 1610817780, £109.26
Cheaper Citroen Equivalent Left, part: 1682729980, £31.30
Citroen Original Right, part: 1610817880, £109.26
Cheaper Citroen Equivalent Right, part: 1682730180, £31.30
C5X7_2_2HDI
Donor 2022
Post by C5X7_2_2HDI »
Hello Marc!
My rear camera on C5 tourer let water in the housing and the rust got better of it.
So I was wondering if you could be so kind and tell me the part number for the rear camera?
My VIN VF7**************[VIN obfuscated, can be read by forum staff].
Thanks in advance!
C5X7_2_2HDI
Donor 2022
I actually need the camera itself, so that would be the item number 1.
The housing of the actual camera itself cracked, not just the outer protective plastic housing that secures the camera in the tail gate.
x 4930
Sorry - I provided the support only (thought that was a bit cheap for the camera!), I'll delete the previous post to avoid confusion.
Here you go:
Item (1), Reversing Camera, part: 98135828XT, £252.38
I should note that this part is for the updated revised camera that provides a better image and especially at night. There was an issue with original cameras fitted regarding the photosensitive sensor on several models. This later part is the replacement for the original camera.
dave101ua
Donor 2023
Post by dave101ua »
GiveMeABreak wrote:
06 Dec 2022, 14:14
Here you go:
Thank you Marc!
Could you please also provide numbers for break pads both rear and front ones
x 4930
Front Disc Pads
Item (4), Front Pads set, part: 1647863680, £149.98
Rear Disc Pads
Item (2):
Citroen OEM Pads, part: 1647860380, £108.88
Citroen Cheaper Alternative, part: 1619791280, £48.29
