ekaftan
Donor 2023
x 4
Post by ekaftan »
GiveMeABreak wrote:
25 Nov 2022, 17:09
@ ekaftan
Fronts:
Item (3) OEM Original, part: 425289, £115.61
Citroen Cheaper, part: 1617274180, £48.47
Rears:
Item (3) (OEM Original, part: 425334, £103.15
Citroen Cheaper, part: 1617257280, £22.93
Thanks!
After arguing with them for about an hour they cancelled the ones they had sent me, and sent me the correct ones.
(and they corrected the publication)
Thanks!
C5X7_2_2HDI
Donor 2022
Post by C5X7_2_2HDI »
Hello,
I would like to know which gearbox oil is correct for my car with an AM-6 transmission.
I think its the euro5 which means it should be JWS-3324, but wanna make sure.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
x 4930
Post by GiveMeABreak »
Correct, your vehicle is Euro 5, so JWS-3324
admiral51
Donor 2023
x 363
Post by admiral51 »
Hi
Could i have the info for the starter motor on my C5 please as there seem many different versions.
Colin
x 4930
You have 3 choices Colin:
Item (1)
OEM Starter (CL 5 MITSUBISHI - M 000 T 20872ZE) or (CL 5 MITSUBISHI - M000T20873ZE), part: 9827007180, £544.66
or
Cheaper Exchange Starter, part: 1638116180, £136.45
or
Standard Mitsubishi Exchange Starter (CL 5 MITSUBISHI - M000T20872ZE) or (CL 5 MITSUBISHI - M000T20873ZE) part: 5802FK, £257.64
All direct from Citroen (note there is a refundable deposit of £84 for each of these)
admiral51
Donor 2023
x 363
Post by admiral51 »
Cheers Marc and there was me thinking it was going to expensive :(
Colin
Dormouse
Donor 2022
x 418
Post by Dormouse »
Hi Marc. could you give the part number and price for a 2013 3008 scuttle drain pipe as in the attached picture. It fits in either end of the plastic wiper / scuttle trim below the windscreen. Thanks.
x 4930
Item (20) Water Pipe
8103P7 (Left) £38.62
714140 (Right), £41.21
Direct from Peugeot, VAT inclusive.
Dormouse
Donor 2022
x 418
Post by Dormouse »
Cheers Marc
eurofjr
Donor 2022
Post by eurofjr »
Hi Marc,
Looking for the PN for right side mirror for VIN VF7**************[VIN obfuscated, can be read by forum staff].
Best,
Jim.
x 4930
Hi Jim
Item (1) Right Side Mirror (with Blind Spot Monitoring and Panoramic Visual Aid) part: 1610545980, £912.18 inc. VAT
mrhardware
Donor 2022
x 4
Post by mrhardware »
Hi Marc
I am looking for the part numbers and price for the rear ride height sensor, drop link and clamp for a 2011/12 c5 x7.
Looks like my sensor is on its way out it intermitantly raises at the rear to a strange height and has a c1146 permanent fault rear body height sensor fault..
x 4930
Ok, so here are the various part numbers (don't remove the clamp unless absolutely necessary, as if you move the clamping position by even a small amount, you will change the ride height and will have to use the suspension measurement calculation procedure and Diagbox to adjust the heights.
(Procedure for that here):
C5 X7 Hydractive Suspension, 4 Cylinder Vehicles only - Height Measurement Checking Procedure
(8) Rear Sensor, part: 5273J9, £87.28
(9) Bracket, part: 5273L3, £16.15
(10) Angular Pickup, part: 527381, £7.45
(11) Anti Roll Bar Lever, part: 1687269980, £295.63 (yes you read that right)!
Donor 2022
x 940
Post by MattBLancs »
Hi Marc,
Please could you confirm the part numbers and cost for the following when you get chance, no rush:
- 1.6 HDi DV6 air filter housing rubber mounts - think is 1422A3 - rather expensive on eBay.
- Also turbo banjo bolt copper washers - are there any dimensions given in the description, not just part number+ cost? Having trouble getting a seal at this joint.
Associated VIN
- EW10J4 oil filter housing seal (between block and filter bracket)
Associated VIN
- EW10J4S inlet manifold to throttle body gasket
Sorry don't have a VIN associated with this. Engine fitted to 206 GTi 180, C4 VTS, 307 CC, etc
Thanks very much, :)
Matt
admiral51
Donor 2023
x 363
Post by admiral51 »
Hi
Could i have the part number for the Brake Pedal Switch for my C5 X7 and if it is possible can i trust GSF/ECP to have a decent one and the location of said switch .
Thanks in advance:)
Colin
