x 4947
Post by GiveMeABreak »
Huskyxantia wrote: 12 Sep 2022, 09:25 Hi, needing part number for turbo complete unit also just the cartridge , then maybe i can decided which root to take.
Peugeot 206cc 2.6hdi 06 plate. Can add vin if needed
Many thanks.
Turbo:
Item (1) OEM Hemeywell Turbo New, Part: 0375J6, £1,467.68
Item (1) Reconditioned Exchange Honeywell Turbo, Part: 0375J8, £773.10
There are no repair kits shown except for the items under (20) and no separate cartridge, so you may have to source that elsewhere.
Huskyxantia
Donor 2023
x 250
Post by Huskyxantia »
Cheers marc, im not seeing to many cartridges yet. Ill keep looking and cross reference with the numbers given here
x 660
Post by wheeler »
KennyW wrote: 12 Sep 2022, 08:09 Thanks wheeler, is there an alternative part number . All searches I do return 6208H9 which has headlamp motor otherwise same spec as mine.
Some sellers have this without motor, will this fit ?
Kenny
6208H9 supersedes onto 6208R7 This is an X7 N/S headlamp but its not showing as the one for your car, not to say it wont fit but I don't know what the difference is, they look the same at a glance. This one is also no longer available anyway.
The dealer one comes with everything highlighted in the picture. Bulbs, caps, brackets (I would hope so too at that price) but no adjustment motor .
Aftermarket ones often come without all the extra bits & you can just swap them over from the old unit.
KennyW
Donor 2022
x 127
Post by KennyW »
Thanks Wheeler, I may have found an OEM spec headlight.
Steve Walsh
Donor 2023
x 292
Post by Steve Walsh »
Hi all
Got a mate arrived at mine today with a very noisy crankshaft pulley / damper. Any chance of a part number. and dimensions if poss to try and get an after market one. VIN is VF3**************[VIN obfuscated, can be read by forum staff] 206. 2.0hdi
I can't find the build code number as it has had a paint job in the past
Steve
x 4947
Flywheel: Item (12) Part: 0532H8, £557.23
Pulley (7), part: 0515V6 (DIAM 162X30 EP 37 6V) , £276.10
Steve Walsh
Donor 2023
x 292
Sorry for not being clear, Number 7 Pulley / damper
x 4947
Just realised - updated ^
Steve Walsh
Donor 2023
x 292
Cheers Marc, You are a star... have a good eve
Steve
jamescarruthers
Donor 2023
x 46
Post by jamescarruthers »
jamescarruthers wrote: 11 Sep 2022, 17:27 Sorry, I don’t have the VIN to hand for my sister’s 2001 2.2 C5 but I think the sensor to detect the presence of the fuel cap has broken.
If possible, can one of you please tell me the part number and if it is still available?
Magnets still present in cap… I think! Warning on screen to unblock diesel filter.
Found the VIN again! VF7**************[VIN obfuscated, can be read by forum staff]
Would you be able to tell me of this cap sensor is available and also the part number of I have to look elsewhere, please?
x 4947
Item (6) is the version with a lock and is still available in 2 separate versions:
Part: 1508J4 for a combination specified on order, £72.88 or
Part: 1508J3 for a random combination, £101.77
Item (10) without a lock is no longer available, but was part 1508J3, £19.09
jamescarruthers
Donor 2023
x 46
GiveMeABreak wrote: 14 Sep 2022, 12:14 Image
Thanks very much. However, this time I need the sensor that actually detects the presence of the presence of the cap.
Number 11 in the picture maybe?
x 4947
Item (21) James: Plug Detect Harness, Part: 6534HY, £169.25 :shock:
jamescarruthers
Donor 2023
x 46
GiveMeABreak wrote: 14 Sep 2022, 22:45 Image
Thank you. I’ll get searching for a cheaper one but will have to buy if it needs it.
moizeau
Donor 2022
x 267
Post by moizeau »
Morning Marc, could you have a look please to see if the knuckle joint that joins the steering rack to the track rod end on my 407 is available as a single item or does it come as part of the rack.
Cheers
