x 4939
Post by GiveMeABreak »
I've included some additional parts on there, so please refresh the page to see the updated post Husky.
moizeau
Donor 2022
x 267
Post by moizeau »
Is there an official part no. for the oval rubber blanking plug in the lower face of the sill of my 407, it's about in line with the centre pillar? It is hidden under the stone chip protection and you wouldn't normally know it even exists.
Cheers
x 4939
Have a look here Pete. These are the listed 'Body Blank Fillers and Plugs' listed. Let me know which ones you need info on and I can give you the measurements and part number:
Viorika123
Donor 2022
Post by Viorika123 »
Hello, I have a Citroen DS 5, hybrid, 2012. VIN. VF7**************[VIN obfuscated, can be read by forum staff] Sorry for the irregular language :)
1. Is it possible to get a diagram of the rear reducer and what are the original parts inside the reducer?
2. Still interested in this machine, what should be the original generator belt and tensioner?
moizeau
Donor 2022
x 267
Post by moizeau »
Cheers Marc. The nos. similar are 7, 9, 10, 12 and 14. It's a rubber blanking plug and the oval hole in the sill measures 20mm x 45mm. However looking at the other side it does have a form similar to 17 with little cut outs along the sides.
x 4939
moizeau wrote: 02 Sep 2022, 12:39 Cheers Marc. The nos. similar are 7, 9, 10, 12 and 14. It's a rubber blanking plug and the oval hole in the sill measures 20mm x 45mm. However looking at the other side it does have a form similar to 17 with little cut outs along the sides.
(7) 7518G6 (18X40), £0.83p
(9) 7518S2 (90X180), £25.93
(10) 7518H2 (20X50), £2.89
(12) 7518J3 (DIAM 75), £3.04
(14) 698852 (37X65), £3.71
(17) 7518R8 (20X45 SHEET METAL), £0.86
x 4939
Viorika123 wrote: 02 Sep 2022, 12:20 Hello, I have a Citroen DS 5, hybrid, 2012. VIN. VF7**************[VIN obfuscated, can be read by forum staff] Sorry for the irregular language :)
1) Are you referring to the rear electric window motor and components or the roof blind motors?
2) Are you asking for the alternator pulley belt and tensioner roller or the timing belt kit?
moizeau
Donor 2022
x 267
Post by moizeau »
Thanks Marc
Viorika123
Donor 2022
GiveMeABreak wrote: 02 Sep 2022, 13:05
Viorika123 wrote: 02 Sep 2022, 12:20 Hello, I have a Citroen DS 5, hybrid, 2012. VIN. VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] Sorry for the irregular language :)
1. I am asking about the reductor/differential thats in the back of the car (hybrid), im searching for reductors diagram to find out what parts are inside of it.
2. And searching for codes of original alternator belt and timing belt kit. (Its snapping a lot even though Its as tight as it needs to be according to the internet)
moizeau
Donor 2022
x 267
Post by moizeau »
If anyone out there is interested it's no. 17, tested the good side with a magnet, thanks again Marc
eurofjr
Donor 2022
Post by eurofjr »
Hi Marc,
Hope your Friday is going well.
VIN VF7**************[VIN obfuscated, can be read by forum staff].
Part numbers requested:
Timing belt kit or individual parts
Water pump (if not part of kit)
Thermostat
Jim.
x 4939
Viorika123 wrote: 02 Sep 2022, 16:22
Here are the Alternator & Timing Parts
Timing
(2) Timing Belt
OEM Original, part: 0816K8 (116DTS-LARG25,4), £130.70
Cheaper part: 1633127280, £61.84
(4) Timing Tensioner Roller, part: 0829G6, £87.88
(5) Idler Roller, part: 083074, £60.40
(6) Timing Tensioner, part: 084922, £129.07
(13) Timing Kit (2, 4 & 5), OEM Citroen original part: 0831W1, £187.24
Cheaper Citroen Kit, part: 1614346980, £131.04
Alternator Belt
(4) Dynamic Tensioner Roller, part: 1611426080, £165.20
(5) Ancillary Belt (K6-LE-1080), part: 5751K3, £43.81
Traction Battery
These are the components of the traction battery.
x 4939
eurofjr wrote: 02 Sep 2022, 18:08 Hi Marc,
Thermostat
Jim.
Hi Jim, here you go:
(3) Idler Roller, part: 083075, £63.74
(4) Timing Tensioner Roller, part: 1610577380 (DIAM 60 MM), £87.88
(5) Timing Belt, part: 1610577680 (141 DTS), £121.18
(6) Timing Kit (all the above, including addition of water pump):
OEM Citroen Original Kit, part: 1610577780, £241.46
Cheaper Citroen Alternative Kit, part: 1681786080, £168.78
eurofjr
Donor 2022
Post by eurofjr »
muchas gracias, Marc.
eurofjr
Donor 2022
Post by eurofjr »
Hi Marc,
I think ya missed the thermostat?
Jim.
