Citroen and Peugeot Official Part Number Requests
- Donor 2022
- x 39
Thx that will help alot, so the internal diameter is 12mm?
- x 3478
Again, it depends on which pipes you need - some are and some aren't:Rp0thejester wrote: ↑04 Jun 2022, 19:03Thx for the info Marc, that was what I was expecting. My garage told me the brake pipe lines aren't available, is that correct??
Available: 1, 2, 7, 8, 9, 10, 11, 14, 15,
Unavailable: 5, 6, 12, 13
- x 3478
- Donor 2022
- x 39
I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
- Donor 2021
- x 1673
One of my (myriad of) sayings is "There is no such thing as a stupid question". If you don't have the information you require you have to enquire.Rp0thejester wrote: ↑04 Jun 2022, 19:15I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
- Donor 2022
- x 39
Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
- Donor 2021
- x 1673
I have an addendum to that saying; "...but stupid, avoidable mistakes do exist".Rp0thejester wrote: ↑04 Jun 2022, 19:37Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
- Donor 2021
- x 26
Thanks very much. Got a second hand on the way now. Cheers.GiveMeABreak wrote: ↑04 Jun 2022, 17:23James, if this is for your VIN ending 665, then there were 2 options - a locking cap and a non-locking cap:jamescarruthers wrote: ↑04 Jun 2022, 16:43Hello all. My sister has managed to loose the fuel filler cap for her 2001 2.2 C5… it’s the magnetic type that tells the car to inject Eolys fluid so I’d better get it replaced pronto!
Can I have the part number, please, and is it still available to buy from Citroen? If not I’ll get a second hand one.
(6) Locking
Combination specified on order, part: 1508J4, £72.88
Random Combination, part: 1508J3, £101.77
(10) Non-locking was part: 1508F7, £19.09, but no longer available.
- Donor 2022
- x 42
Hi all
I have a D9 406 SV, VIN VF3**************[VIN obfuscated, can be read by forum staff], which is currently refusing to start. The starter no longer spins - best I was able to get was a very weak part-turn. This has been brewing for a while, but at first it was just occasionally, and after a few retries it would suddenly just work.
It is definitely not the battery - it's showing 12.7 volts. Just to be sure I connected jumper leads from a running vehicle - measured voltage at 13.8v - no difference.
Now I realise that there are other possibilities, but is 438087 the right starter motor? Looks like Spareto could fly one out to me for about $100 less than I could buy one in Australia.
Cheers
Alec
Cheers
Alec
- x 3478
Alec, PM sent.
- Donor 2022
- x 4
Hello. I'm searching for a blower fan, complete and the resistor. VIN VF3**************[VIN obfuscated, can be read by forum staff]
THANKS IN ADVANCE
THANKS IN ADVANCE
- x 3478
You'll have to be more specific:- The radiator fan and control unit or the internal passenger heating blower motor and blower control module?
But on the basis you mentioned resistor, I'll assume you meant the heating blower motor...
Item (2) Part: 6441N4, £315.68, but no longer available from Citroen
Item (4) Part: 644178, £195.83, blower motor control module.
- Donor 2022
- x 4
GiveMeABreak wrote: ↑08 Jun 2022, 10:14You'll have to be more specific:- The radiator fan and control unit or the internal passenger heating blower motor and blower control module?
Thanks. Yes. I was referring to the internal blower motor and resistor.
Appreciate your assistance as usual.
- Donor 2022
- x 39
Okay had the car 10 years but never noticed this.
I only noticed because I lost 1. is their a part number for this? And also what are they there for?-
- x 428
Its the covers for the headlamp washer jets. The part number is 6438K7 & the come as a set of 2. £57.07 inc VAT but they will come un painted.
Get a set from a breakers from the same colour of car is your best bet.
