Citroen and Peugeot Official Part Number Requests
- x 58
Re: Citroen and Peugeot Official Parts Requests
Thanks, Marc!!
- Donor 2022
DS5 power steering pipes
Hi just wondering if someone could help me with the power steering pipes part number. One of them has a split in the needs changing.
I'm thinking there the same as my c4gp 2 but want to double check
Thanks in advance
Rich
Thanks in advance
Rich
Reason: Moved to Official Citroen Peugeot Parts Requests
- x 3393
@gouldie: If it's the High Pressure Steering pipe shown at (1), then it is part 4014SN (for your vehicle, VIN ending 829).
Priced at £188.18 inc. VAT direct from Citroen.
The C4 Picasso MK II (B78) doesn't have any power steering pipes - it uses an electric Power steering system.
The C4 Picasso MK I only used the same part number on models from a specific build date (10 December 2010) on specific engines.
- Donor 2022
Hi no it's the return hose that's leaking do you have the part number for that one? Thanks
- x 3393
That's the only part listed as you can see from the diagram, and no other part number shown, so they possibly come as one set. Best to check with the dealer's part department for confirmation.
- Donor 2022
Ok thanks Marc
Have a great weekend
- Donor 2021
- x 4
Hi. Looking for the part number for the 3 bolts which hold the doseur valve bracket to the bulkhead on a series 2 RHD XM please
Cheers
Cheers
- x 3393
Let me know the item numbers:
- Donor 2021
- x 4
Hi , thanks for that. But it was the ones which attach the bracket with the actuation arm to the bulkhead (3x Internal torx bolts with washers) not the ones for the valve itself. Sorry if I wasn't clear in my first post
- x 3393
I have to pop out now, but can you be more specific as the above was from the toe board assembly! There's nothing showing obviously for the doseur. Do you have a picture of location and I'll have a look when I get back.
- Donor 2021
- x 4
someone from Club-Xm has provided the part number
p/n 6921 17, or 6915 36
For reference They are the m6 cap bolts which hold the bracket which holds the doseur to the bulkhead and contains the mechanism to actuate the doseur from the pedal
- x 400
692117 is the old part number, they have now been superseded to the 691536 which are 94p each inc VAT
- x 866
94p each seems a might excessive for what look to be ordinary setscrews.
- x 552
They are M7 though so might be a challenge to get elsewhere!!
- x 866
Hmm, 100mm long seem difficult to find so statement retracted!
