Citroen and Peugeot Official Part Number Requests
- Donor 2022
- x 35
- Donor 2021
- x 93
Re: Citroen and Peugeot Official Parts Requests
Having some weird issues regarding wiper blade sizes for a 206cc ive got one saying 22 inch another 16 one even 14 ? !
Now pulling my hair out
Please can i have the actual size(s) many thanks
- x 552
Both 550mm seemingly, which would be 22"
- Donor 2021
- x 93
Many thanks Richard.
- Donor 2021
- x 4
Hi
looking for part number for the glow plugs on a 1997 XM 2.1 TD XUD11BTE please
Cheers
Cheers
- x 3393
Here you go:
OEM Original Plugs, Part: 5960G7, £27.60
Citroen cheaper Alternative, Part: 1616054080, £8.66
VAT inclusive direct from Citroen, prices as of today.
- Donor 2021
- x 4
brilliant. thanks
- Donor 2022
- x 4
Hello. I am looking for the part in the image below which sits above the original clock display. You can see the clock (original part) in the background of the person's hand.
[it is a modifed clock display. unsure if it is a stock item from another model Peugeot/Citroen]:
- Donor 2021
Thanks a lot Marc, appreciate it!GiveMeABreak wrote: ↑18 Apr 2022, 16:06Here you go Dan:
(1) OEM Genuine Water Pump, part: 9801573380, £107.65
(1) Citroen cheaper alternative, part: 1637171880, £58.32
(2) Water Pump Gasket in case you need it, part: 1206E8, £7.94
- x 3393
That doesn't look like the correct stock faceplate, so can't help you if it's not an official part. I've checked without filters and there are no parts supplied for other telematics / display systems that are of the larger type, so this may well be a replacement for an aftermarket unit.Ohfishalee wrote: ↑21 Apr 2022, 19:40Hello. I am looking for the part in the image below which sits above the original clock display. You can see the clock (original part) in the background of the person's hand.
[/img]
This is your faceplate:
Your faceplate as shown in the diagram Item (3), part: 8211N9, £70.54 from Peugeot.
- Donor 2022
- x 181
Morning, The lad I've helped before with his Boxer / Relay (unsure which) is having more problems. There is a water block at the front of the engine that is cracked and he needs to get a replacement.
https://www.frenchcarforum.co.uk/forum/ ... hp?t=69777
Is the part number shown in the photos a recognised PSA P no. so he can use that to track one down please?
Thanks very much
The vin is available on this posthttps://www.frenchcarforum.co.uk/forum/ ... hp?t=69777
Thanks very much
- x 3393
9643212080 is the part number Pete. This is for the water Outlet tank, no longer available from PSA, which had the original part number of 1336 V4.
A quick search finds a new one here for £74.99:
https://www.ebay.co.uk/itm/363133741875 ... 9be4d3d5c4
- Donor 2022
- x 181
Thanks very much Marc, much appreciated
- x 58
Ay up!
We have some creative thieving little scrotes round here!! I am missing both the bolts that secure the rear of the front bumper on my C5 LY52MXO. It's also missing 2 Torx bolts above the grille so may as well get them while I'm at it!
What fixings do I need? Goooooooogling only finds the plastic rivets. And I got loads of them!
- x 3393
@ Xantianut: Please see the first post: viewtopic.php?p=685750#p685750
