Wish I had seen that ^ a few days ago, my son was trying to get an O-ring for his motorbike and had a struggle, had to order one.
There is an Eriks only four miles from me that I have used a lot in the past but never for o-rings and never thought of them.
Citroen and Peugeot Official Part Number Requests
- x 1955
- Donor 2022
- x 4
Re: Citroen and Peugeot Official Parts Requests
Thanks much!!!GiveMeABreak wrote: ↑04 Apr 2022, 11:53OK, so the housing is (1) and includes A, (3) & (6), part: 191144, £163.64Ohfishalee wrote: ↑04 Apr 2022, 03:25![]()
Thank you very much!!
The Filter Housing (ref A) part number is what I am after, not the filter itself.
The pipes are ref C & D
Pipes
Item (16) is the correct one for your vehicle and this is a complete set of pipes, (A, B, C & D) as shown. They are not available separately. Part: 1574L3, £97.25
All VAT inclusive direct from Peugeot as of today.
P/N for Fuel Injection pump is next on my list for same vehicle
- x 3393
@ Ohfishalee:
Sitting comfortably?
New OEM Fuel Injection Pump (1), Part: 1920AT, £4,148.63
Peugeot Exchange Injection Pump, Part: 1921F9, £1,998.20
Probably cheaper to buy a new van!
- Donor 2022
- x 4
Is the pump the same as in the DW8 engine?
- x 3393
No, the DW8B has electronic management and there are sensors / electronics on the pump where the DW8 doesn't, so wouldn't be compatible.
- Donor 2022
- x 4
Cheers!GiveMeABreak wrote: ↑06 Apr 2022, 09:29No, the DW8B has electronic management and there are sensors / electronics on the pump where the DW8 doesn't, so wouldn't be compatible.
- Donor 2022
- x 3
Hi there, looking for part number for the NS front Splashguard for C4 Grand Picasso 2014 1.6eHDI:
cheers!
cheers!
- x 552
Item 10?
£120.44 inc VAT, oddly the RH one is £25 cheaper....
- Donor 2022
- x 3
- Donor 2021
Hi, could I get the part number for the water pump for my car please?
Cheers
Cheers
- x 400
Whats your VIN or Reg?
- Donor 2021
Reg is ST11 BVU
- x 3393
Here you go Dan:
(1) OEM Genuine Water Pump, part: 9801573380, £107.65
(1) Citroen cheaper alternative, part: 1637171880, £58.32
(2) Water Pump Gasket in case you need it, part: 1206E8, £7.94
- Donor 2022
- x 35
Hi again Marc, I'm looking for the part no fir a front sub frame for a C3 SV08FRR VIN VF7**************[VIN obfuscated, can be read by forum staff] I'm trying to find out if it's a common number to all c3s and c2s that would make my search easier.. I've got a bolt I can't remove from the frame and replacing the frame would make more sense.
- x 400
Part no 9808011780 £349 inc VAT and you have to take another £24 worth of bolts & fixings.
