Citroen and Peugeot Official Part Number Requests
- Donor 2022
- x 2412
Re: Citroen and Peugeot Official Parts Requests
Could I have the part number for my fleet C4 picasso vin VF7**************[VIN obfuscated, can be read by forum staff]. Throttle pedal please? Cheers
- x 3404
Hi Mick
Part: 1601EE, £206.36 inc VAT
- Donor 2022
- x 2412
Thanks Marc!!
If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
- x 402
The VIN will give you The Citroen part number but i suspect the repair people are after the manufacturers part number which is normally on the actual part itself either embossed on the plastic or on a sticker. The part number on the unit will not be the same as the dealer part number.Remithevan wrote: ↑25 Mar 2022, 18:28If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
This is turning out to be a pain, guessing they can only reapir certain brands of BSi unit.wheeler wrote: ↑25 Mar 2022, 19:40The VIN will give you The Citroen part number but i suspect the repair people are after the manufacturers part number which is normally on the actual part itself either embossed on the plastic or on a sticker. The part number on the unit will not be the same as the dealer part number.Remithevan wrote: ↑25 Mar 2022, 18:28If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
Make see how much stealers want to replace it.. really just need it sorted.
- x 402
An exchange BSI from Citroen is around £260 (new on is around £440) just for the part and at a guess they would want at least 1.5 hours labour for fitting & programming.
- Donor 2021
Peugeot 207 1.4 hdi 2011
Scuttle panel please Marc
Thanks simon
Thanks simon
- x 402
- Donor 2022
- x 4
Hello. I'm looking for part numbers for rear shocks, fuel lines and fuel filter housing.
My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
Peugeot Partner 2006
Shocks
Filter housing/fuel lines
Shocks
- x 3404
Rear Shocks
Rear Shock Absorbers (Original Part no longer available - these have been replaced with substitute shocks part: 9811401780, £88.70 each
Peugeot Cheaper Alternative rear Shock, part: 1623313380, £42.43 each
Fuel Filter
OEM Filter Cartridge Kit: part: 1906A9, £36.56
Alternative part: E148119, £6.17
Fuel Pipes As for the pipes, you'll need to let me know the item number of the relevant pipes on the above chart.
Fuel Filter
- Donor 2022
- x 4
- Donor 2022
- x 28
Are the green o-rings on LDS pipes available separately? And if they are can I get parts number and price please?
- x 3404
OK, so the housing is (1) and includes A, (3) & (6), part: 191144, £163.64Ohfishalee wrote: ↑04 Apr 2022, 03:25![]()
Thank you very much!!
The Filter Housing (ref A) part number is what I am after, not the filter itself.
The pipes are ref C & D
Pipes
Item (16) is the correct one for your vehicle and this is a complete set of pipes, (A, B, C & D) as shown. They are not available separately. Part: 1574L3, £97.25
All VAT inclusive direct from Peugeot as of today.
- x 3404
The O-rings are not listed as separate parts for suspension components except for suspension cylinders Jay.
I ordered my O rings from here, after recommendation from Stu (Sloppysod) when my third steering rack was being fitted. They do all sorts of sizes and materials.
https://o-ring.info/en/materials/vitonr--fkm/
