Crankshaft position sensor for xsara picasso 2.0hdi,
Also whats the purpose of the camshaft sensor & crankshaft sensor, ? And part numbers and locations of both .
Thanks mark
Citroen and Peugeot Official Part Number Requests
- Donor 2021
- x 94
- x 3404
Re: Citroen and Peugeot Official Parts Requests
The crankshaft sensor detets the position of the crankshaft and the TDC (Top Dead Centre) of the piston, and lets the engine ECU know, so that it can determine injection and also the RPM. It's also referred to as the engine Speed Sensor.
The Camshaft sensor determines the position of the Camshaft when running and is similar.
(6) Engine Speed Sensor (Crankshaft Sensor) Part: 1920EN, £27.95
(15) Camshaft Position Sensor Part: 1920QN, £50.33
- Donor 2021
- x 94
Many thanks Marc.
- Donor 2021
- x 94
Back again , needing front strut , spring & top mount for my 206cc 1.6hdi 06 model allure, my top mount has decided to get noise yesterday number and diagram would be very appreciated
Thanks Marc.
Thanks Marc.
- x 3404
Ok, so the front shocks have alternative parts now and as you know must be replaced in pairs.
Struts (1) OEM Strut, parts, left and right:
9810758580, £87.18
9810758680, £87.18
Cheaper PSA alternatives parts:
1674698080, £53.11
1674698180, £53.11
Item (3) Strut Rod Protector, part: 525430, £6.47
Springs OEM (1) Front Spring (1 Yellow +2 Red), part: 5005X4, £149.80 (each)
(2) Front Rest Cup, part: 503184, £37.14
(4) 503360 Front Suspension Bump Stop, part: 503360, £24.32
(6) Shock Absorber Bracket Left, part: 5038C5, £60.43
(6) Shock Absorber Bracket Right, part: 5038C6, £60.43
(9) OEM Shock Mounting kit Left, part: 5031A2, £53.48
(9) OEM Shock Mounting kit Right, part: 5031A1, £53.48
(9) Cheaper Shock Mounting kit Left, part: 1638381480, £49.70
(9) Cheaper Shock Mounting kit Right, part: 1638381580, £49.70
9810758580, £87.18
9810758680, £87.18
1674698080, £53.11
1674698180, £53.11
- Donor 2021
- x 94
Thank you so much this is brilliant .
- Donor 2022
- x 7
Missing EGR mounting bolt
Replaced the EGR today but when I removed the old one there was only one bolt holding it in place (which was also loose). What type is it - does it have to be a PSA specific one or will any aftermarket 6cm bolt do the job?
Reason: Moved to Official Parts Thread
- x 3404
I've highlighted the obvious looking bolts if these are what you need - click the image to zoom:
(8) MUL Flanged Screw Diam 6 x 100-60, Part: 101116, £2.15
(9) MUL Flanged Screw Diam 6 x 100-20, Part: 025057, £1.96
If anything else, let me have the item number form the above diagram.
- Donor 2022
- x 2412
Hi Marc,
Peugeot 406 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could I have the part no for the harmonic balancing pully please
Cheers
Peugeot 406 HDI
Cheers
- Donor 2021
- x 94
Would it be possible to have a part number for this item and if possible a diagram of how it goes to the fuel tank also the part i have highlighted is that a breather of some sort ?
Many thanks.
Many thanks.
- x 3404
Mick, that VIN is incorrect (18, when it should be 17) and also, can you confirm you want the pulley for the accessory belt?mickthemaverick wrote: ↑15 Mar 2022, 13:54Hi Marc,
Peugeot 406 HDI
Cheers
- x 3404
That is the fuel filler pipe and yes that is the breather.Huskyxantia wrote: ↑15 Mar 2022, 23:26Marc
Many thanks.
Item (1) Part: 1503T5, no longer available.
- Donor 2022
- x 2412
Sorry Marc, I copied the vin from the screen in bright sun straight onto the phone and possibly had big finger slip! I got the model wrong, it is a 206 not a 406 - post covid brain fade -. Hopefully that explains the VIN issue? Yes it is the crankshaft rubber mounted pulley at the bottom of the accessory belt run. ThanksGiveMeABreak wrote: ↑16 Mar 2022, 01:14Mick, that VIN is incorrect (18, when it should be 17) and also, can you confirm you want the pulley for the accessory belt?mickthemaverick wrote: ↑15 Mar 2022, 13:54Hi Marc,
Peugeot 406 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Cheers
- Donor 2021
- x 94
Thank you Marc, top man .
- x 3404
That's not helping Mick - the VIN you edited in the previous page is still incorrect. Also, please note that you can't quote an obfuscated VIN in a new post as the VIN has already been converted to asterisks, so I can't read it. Please always retype the VIN in full. Once I have this I will save it for future requests for you.mickthemaverick wrote: ↑16 Mar 2022, 03:01Sorry Marc, I copied the vin from the screen in bright sun straight onto the phone and possibly had big finger slip! I got the model wrong, it is a 206 not a 406 - post covid brain fade -. Hopefully that explains the VIN issue? Yes it is the crankshaft rubber mounted pulley at the bottom of the accessory belt run. Thanks
