Citroen and Peugeot Official Part Number Requests
- Donor 2022
Re: Citroen and Peugeot Official Parts Requests
Ok thanks Marc
- Donor 2021
Cheers Marc!GiveMeABreak wrote: ↑24 Feb 2022, 23:02Hi Dan
Item (1) Fan, Part: 9828719880, £178.56
Item (6) Fan Electric Control Assembly (note this is the replacement control module assembly, so also requires a different assembly cover (item (7)), which is essential as the old one will not fit.
Item (6) New Control Module Part: 9829220580, £84.30
Cover for revised assembly Item (7), Part: 1308CX, £4.76
- Donor 2021
- x 58
I need one thing right away and that's the wiring harness+plug for the LH brake pad wear warning. The plug frayed and broke off in the past. I'm just wondering if someone (Marc?) Could find the diagram / part number/ is it still available from the database.
- x 3404
Here you go Graeme:
Item (12) Part: 443303, £34.68
This is for a single harness and is the same for both sides.
- Donor 2021
- x 58
Hiya Marc, thanks for that although I don't see the harness I'm referring to. Item 12 in the drawing is the little pair of wires you get new with new pads. The part I'm looking for is the plug that these two plug into. It's an elongated plastic plug with two circular sockets for each of these plugs (item 12) and it has an earth wire that emerges right out the back of the plug with a ring connector about 70mm away (fixes on to the hub upright) the harness then runs alongside the likes of the ABS cable up to the inside of the wheelarch. I don't know where it goes on the C5 but on a Xantia it has a plug.GiveMeABreak wrote: ↑02 Mar 2022, 11:58Here you go Graeme:
- x 3404
Bad news then Graeme, as if it's missing, whoever has cut it off has cut the main wiring harness! As far as I can see the connectors that the brake pad wear lead plug into is part of the main harness (1):
- Donor 2021
Hi, Marc! Please can you give me the part number for the Hub cap centre wheel cover trim. Vin is VF3**************[VIN obfuscated, can be read by forum staff]. This is plastic black trim with Peugeot emblem. Thanks
- x 402
- Donor 2021
- Donor 2021
P508 Window mechanism
Hello, can someone help me please.
I would need the part number for the front left window lift mechanism (left hand drive).
VIN number is VF3**************[VIN obfuscated, can be read by forum staff]
Thanks, Igor
Thanks, Igor
- x 3404
Here you go:
Item (3) Left Side
OEM Original Part: 9806086980, £448.00
PSA Cheaper Alternative Part: 1619991780, £150.89
Note, the OEM original includes the electric motor, whilst the cheaper alternative does not contain the motor.
All available direct from Peugeot inc. UK VAT@ 20%
Item (3) Left Side
- Donor 2021
Thanks Marc
- Donor 2021
Re: Citroen and Peugeot Parts Requests
Thanks MarcGiveMeABreak wrote: ↑12 Feb 2022, 11:40@207Peugeot14: Here you go. The DPF element is separate and as you can see from the diagram is clamped on with the kit item (19), which I have included in case you need one of these in case it is rusted.
Particle Filter, item (11):
OEM Original Part: 9677468180 £913.06
OEM Alternative Exchange Part: 1606857180 £619.40
Exhaust Kit for DPF, Part: 1606644780, £68.48
All direct from Peugeot including VAT, prices as of today.
Any ideas of the part number for the pipe that's just past the dpf and goes to the differential pressure sensor please, item 17 in the diagram i think please, the end of mine has come off..
Many thanks Simon
- x 3404
(17) is the outlet particle filter pressure pipe, part: 1714P2, £30.10
- Donor 2021
Perfect Marc
Many thanks ordered
Many thanks ordered
