- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: Citroen and Peugeot Official Parts Requests
Hi Dan
Item (9) is Part 503563, £27.46
As for the suspension part numbers you queried, these are the latest part numbers. PSA change specifications or revise parts according to problems encountered / other issues or for general improvements.
We therefore only provide the latest official parts data direct from PSA (Stellantis) which most aftermarket suppliers are probably unaware of and are still supplying their own versions that may or may not have the latest improvements or may not be equivalent to the latest parts.
- (Donor 2021)
- My Cars: CITROЁN C4 II Hatchback 1.6 VTi 120 88 kW/120 HP from 2011
Hi Marc,
Can I please ask for the parts number for the radiator fan and associated fan control module for my car please? Let me know if you need my VIN
Cheers,
Dan
Cheers,
Dan
Dan
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Dan
Item (1) Fan, Part: 9828719880, £178.56
Item (6) Fan Electric Control Assembly (note this is the replacement control module assembly, so also requires a different assembly cover (item (7)), which is essential as the old one will not fit.
Item (6) New Control Module Part: 9829220580, £84.30
Cover for revised assembly Item (7), Part: 1308CX, £4.76
- My Cars: Peugeot partner 16hdi 2010
Hi Marc
If its possible for the,code/part number for new clutch.
Thanks in advance
Thanks in advance
Reason: Obscure VIN
Reason: Obscure VIN
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@Steve007: PM Sent
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Steve:
I've listed individual parts and also the complete clutch kit:
(1) Clutch, Part: 2004AV, £247.88
(2) Clutch Plate, Part: 2055HT, £225.41
(3) Clutch Release Bearing, Part: 1611266780, £39.17
(5) Clutch Fork, Part: 211766, £52.63
Clutch Kit
Item (8) (which includes Items 1, 2 & 3) above:
OEM Original New, Part: 1611269280, £387.00
Cheaper Kit, Part (Eurorepar): 1636264380, £163.50
Standard Exchange Kit, Part: 2051W4, £201.00
Ok thanks Marc
- (Donor 2021)
Cheers Marc!GiveMeABreak wrote: ↑24 Feb 2022, 22:02 Hi Dan
Dan
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
I need one thing right away and that's the wiring harness+plug for the LH brake pad wear warning. The plug frayed and broke off in the past. I'm just wondering if someone (Marc?) Could find the diagram / part number/ is it still available from the database.
Graeme M
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Here you go Graeme:
Item (12) Part: 443303, £34.68
This is for a single harness and is the same for both sides.
- Donor 2023
'Old Katy'
Hiya Marc, thanks for that although I don't see the harness I'm referring to. Item 12 in the drawing is the little pair of wires you get new with new pads. The part I'm looking for is the plug that these two plug into. It's an elongated plastic plug with two circular sockets for each of these plugs (item 12) and it has an earth wire that emerges right out the back of the plug with a ring connector about 70mm away (fixes on to the hub upright) the harness then runs alongside the likes of the ABS cable up to the inside of the wheelarch. I don't know where it goes on the C5 but on a Xantia it has a plug.GiveMeABreak wrote: ↑02 Mar 2022, 10:58 Here you go Graeme:
Graeme M
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Bad news then Graeme, as if it's missing, whoever has cut it off has cut the main wiring harness! As far as I can see the connectors that the brake pad wear lead plug into is part of the main harness (1):
- cs101
- (Donor 2021)
- My Cars: EXPERT 4 (KO) VAN L2 1.6 HDI 115 FAP (DV6FCU) STT TYPE 6-SPEED GEARBOX
- x 6
Hi, Marc! Please can you give me the part number for the Hub cap centre wheel cover trim. Vin is VF3**************[VIN obfuscated, can be read by forum staff]. This is plastic black trim with Peugeot emblem. Thanks
