Thanks Marc, I appreciate your time spent on my request.GiveMeABreak wrote: 09 Mar 2025, 10:58The only other parts showing:Dave J65 wrote: 08 Mar 2025, 18:36 Marc,
Thanks for this, unfortunately I meant inner wheel arch, not wing.
Apologies.
Dave
(10) Front Wheel Arch
Right, part: 7120G2, £144.62
Left, part: 7119E1, £168.73
On my previous post diagram below, item (6) is the Front Wing Mudflap Frame:
Left, part: 7136FK, £50.81
Right, part: 7136FL, £53.11
Is it possible to get a part number please for heater resistor for c4 grand picasso picasso 2016 with
vin VF7**************[VIN obfuscated, can be read by forum staff]
Hi Marc,
According to the schematics number 1.)
It will be number 15 and 7. Most likely number 6 as well.
From fasteners - the ones used to mount above, but I see 6997T2 you already mentioned. Also door card clips and this type Cheers.
Thank you for that info. Well I contacted them to double check and it turns out that they have lumped them together and it’s actually a 4541 JH. I am at a loss. I do t understand why there are so many part numbers.GiveMeABreak wrote: 08 Mar 2025, 13:38 So as I said I can't comment on after-market sellers, but they are listing that as a compatible part (4541QE), so you would have to take them at their word. But you may still need to have the configuration checked if the vehicle has a different equipment to your vehicle and it will definitely need to have the steering wheel angle sensor calibrated too.
Much less. What are these other part numbers that all begin with 9. Are they after market numbers? Sorry to ask all these questions. I’m just really stressed as I am meant to be driving back with the car from Thursday.
- x 6880
4541JH is not listed as a current or previous part for your vehicle.
4541AF was the original part number (to be configured)
4541QE is the replacement part (to be configured)
4541AG was the Pre-configured part based on the vehicle's options
Either way you can't just replace it without configuring it for the correct vehicle and undertaking the steering wheel angle calibration otherwise it will be going mad beeping at you all the time and all ESP functions will be disabled.
- x 6880
Your VIN is incorrect. It should be 17 long not 16pcb007 wrote: 10 Mar 2025, 12:57 Is it possible to get a part number please for heater resistor for c4 grand picasso picasso 2016 with
- x 6880
(6) Bulkhead Soundproofing, part: 7481CP, £58.18Modami wrote: 10 Mar 2025, 13:18 Hi Marc,
Cheers.
(7) Bulkhead Soundproofing (Left), part: 7481CS, £113.94
(15) Bulkhead Soundproofing (Right), part: 7481CR, £92.18
- Donor 2023
- x 126
MOT Failure on the green S1 today!
Nearside front CV gaiter
Nearside front indicator unit.
Please may I have the relevant part numbers?
Also the rev counter has stopped working. I haven't tried the fix as suggested in one post I have just read but please could I also have the part number for the sensor which sits on the differential?
TIA
TIA
Hi Marc / Richard,
I’m after the original part numbers for the front bumper, bumper mounts and the cowling that goes under the front of the car please.
My car details are:
2001 Citroen Berlingo 1.4i petrol
Engine No.: FS873499453
Thank you so much
My car details are:
Thank you so much
- x 1262
Item 3 - 9821291880 - £194.08 Don't but a cheap one off ebay, they mostly don't work!pcb007 wrote: 10 Mar 2025, 12:57 Is it possible to get a part number please for heater resistor for c4 grand picasso 2016 with
- x 1262
Can you post the VIN, I'm not as organised as Marc....!Rhothgar wrote: 10 Mar 2025, 17:47 MOT Failure on the green S1 today!
TIA
Thanks for that and I've found out already they don't work
- x 1262
Bumper was 7401H7, but unsurprisingly NFP! If you want more parts than are shown on the that drawing let me know.Old Berlingo wrote: 11 Mar 2025, 13:22 Hi Marc / Richard,
My car details are:
Thank you so much
I can't see an obvious undertray, it may not have had one originally.
Hi Richard,
NFP seems to be my new best friend
Regarding the undertray, it’s made of a flexible rubber similar to lay flat floor vinyl. I’ve still got my original so I might try and do some magic with it. I’ve had the car since new and it definitely came with that. Perhaps it was fitted to Australian Berlingos to comply with some local law at the time, who knows?
Anyway, thank you so much for your help
Could you please help me with the part number for the BSM and air con compressor clutch for my C3 A51 - VIN VF7**************[VIN obfuscated, can be read by forum staff]. Numbers on the BSM and compressor assembly are 9667199580 and 9670318880, although I'm not sure if they've been superseded. Hoping there is a separate part number for the clutch.
