x 6875
@Markyt1980:
We do not comment on third party databases - but you should be aware that these are NOT official sources, and are often 15 years out of date!
We only use official parts data direct from Citroen via your VIN. The part number I have provided is the latest replacement part for your vehicle. Ignore anything else from anywhere else is my advice.
Markyt1980
Unread post by Markyt1980 »
Thank you so much Marc. That is a huge relief
Markyt1980
GiveMeABreak wrote: 08 Mar 2025, 13:10 @Markyt1980:
I have just found this on eBay. Does this look like the right part? So hard to find the parts.
x 6875
So as I said I can't comment on after-market sellers, but they are listing that as a compatible part (4541QE), so you would have to take them at their word. But you may still need to have the configuration checked if the vehicle has a different equipment to your vehicle and it will definitely need to have the steering wheel angle sensor calibrated too.
Dave J65
Unread post by Dave J65 »
GiveMeABreak wrote: 05 Mar 2025, 16:01
Dave J65 wrote: 05 Mar 2025, 13:19 Looking for N/S & O/S front inner wing repair panels if there's such a thing.
VIN; VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Your VIN is (18) too long, should be 17 - please correct.
Apologies,
Thanks once again.
x 6875
These are the wing components, so let me know which items you need part numbers for.
Dave J65
Marc,
Thanks for this, unfortunately I meant inner wheel arch, not wing.
Apologies.
Dave
Msig
Unread post by Msig »
Hello,
Is there a part number for the 5 pin plug on the wiring harnes for the egr valve motor on a 207 1.6hdi?
Vin No: VF3**************[VIN obfuscated, can be read by forum staff]
x 6875
Dave J65 wrote: 08 Mar 2025, 18:36 Marc,
Apologies.
Dave
The only other parts showing:
Left ArchRight Arch
(10) Front Wheel Arch
Right, part: 7120G2, £144.62
Left, part: 7119E1, £168.73
On my previous post diagram below, item (6) is the Front Wing Mudflap Frame:
Left, part: 7136FK, £50.81
Right, part: 7136FL, £53.11
GiveMeABreak wrote: 08 Mar 2025, 15:20 Image
x 6875
Msig wrote: 09 Mar 2025, 10:31 Hello,
All the wiring connections are part of the engine harness. However there is a front harness connection repair kit:
But these are only shown for your vehicle as (1), (2) and (3), none of which are 5 pin connectors:
Having looked at spare parts connections catalogue, there is a standard 5 pin connection as shown below (ignore the picture which shows a 3-pin plug - that's just an example), but I can't advise as to whether these contain the pins or clips - you'll need to check with the dealer, but I've included them below (60) & (61). Note there were 2 versions of 5 pin plugs - so included them both - not sure what the difference is apart from the colour.
(1) 5 Pin Holder, part: 6541AR, £6.19
(1) 5 Pin Holder, part: 6541V3, £9.72
(60) Harness Clips
Part: 6541E6, (A=1,5 B=0,35 A 0,75), £.96
Part: 6541V4, (A=1,5 B=0,5 A 1 MM2), £1.32
Part: 6541E7, (A=1,5 B=1 A 2 MM2), £.96
(61) Clip Plug, part: 6541LS, £.97
Msig
Amazing, thank you.
6541AR seems to be the one. You've saved me hours of searching.
Cheers 👍
quintet
x 41
Unread post by quintet »
Hi Marc, please can i have the part numbers for the following,
1, (plastic) tool kit tray that's suitable to fit (inside) an alloy wheel, the only thing is is my car probably came with a "steel" spare wheel originally but when i bought it it had nothing so i purchased an alloy wheel to use as a spare. Apparently there is a version available from the dealers but I dont know if it's a suitable size (if indeed there is different sizes/types available) and at £74.59 + vat I'm fairly certain I can find a second hand one cheaper elsewhere if I know which one to look for.
2, Rear upper shock absorber mounts, also available from a dealer so i might get them yet but not particularly cheap at £64.05 + vat each so again I see if i can get some "GENUINE" ones elsewhere but there's different types available (standard/heavy duty suspension) and I'm not sure which I actually need.
3, rubber bump stop to fit on the inner, lower edge of the tailgate where the tailgate rests against the vehicle body.
Thanks in advance.
Music keeps me going.
Modami
Unread post by Modami »
Hi all,
I'm looking for few part numbers.
VIN is VF7**************[VIN obfuscated, can be read by forum staff] (PS. This is '05 not '07 isn't it?)
1. The "foam" inside engine compartment located under windshield/behind engine.
2. All plastic fasteners used in the car.
3. Cabin air filter cover
Thanks in advance
x 6875
quintet wrote: 09 Mar 2025, 15:36 Hi Marc, please can i have the part numbers for the following,
Thanks in advance.
There are different shaped versions (rectangular), but these are for models with different build dates. The only one showing up for your vehicle specifically, is the following:
(1) Lifting Jack Box, part: 673687, £89.51
(2) Shock Fixing Cover, part: 503542, £2.88
(3) Rear Shock Absorber Bracket:
OEM, part: 514232, £76.86
Cheaper Peugeot Option, part: 1638383680, £29.70
x 6875
Modami wrote: 09 Mar 2025, 18:09 Hi all,
Thanks in advance
Neither! Your vehicle was actually built on 25th November 2004. :)
1) Let me know which items from the diagram:
2) This is not a practical request - there are too many and I don't have the time to list these are they are area / diagram specific. You will have to be more reasonable by providing the ones you need for a specific item, like Door Card clips, or Centre Console Clips for example.
But in case you are referring to the clips for the bulkhead in the first diagram, these are:
(11) General Fixing Clip, part: 7481Q6, £2.63 (Pack of 3)
(12) Removable Rivet, part: 6997T2, £1.24 (Pack of 6)
(13) Retaining Clip, part: 7584AQ, £1.45 (Pack of 6)
(14) MUL Clip, part: 896477, £0.32 (Pack of 4)
(16) Bulkhead Closer, part: 645450, £16.40
(70) Retaining Clip, part: 6995X9, £0.41 (Pack of 4)
Note that where these are in pack quantities, you will likely have to multiply the cost up by the minimum quantity shown.
3) Pollen Filter Cover:
(8) Filter Closer, part: 6447KN, £20.34
