Hello, could i have build sheet please, thank you VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Hi I am wondering if someone could help me find the correct part for my Citroen C4 Grand Picasso mk1
The vin is VF7**************[VIN obfuscated, can be read by forum staff]
And the orp number is 11254fv
I need to replace the ABS module but it seems there are many options. My mechanic has said that the one on my car looks like it’s a replacement and the part numbers have been scatched off. The car is left hand drive if that makes any difference. I don’t mind if it is the original part number and not the ones being used on eBay etc I just need to find out what the correct one is for my car. I have the Christmas tree lights on it. Abs esp/asr fault etc. I don’t even know if the car has ASR and this is what is confusing me as it comes up with that message that says esp/asr fault etc. but any help would be really appreciated.
Hello, had it posted in the general forum, just found out it belongs in here:
Looking to replace the curved oil hose feeding the steering pump with oil coming from the LDS tank. The part number would help me.
It is a C5 2.0 HDI, 2007. VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance!
Thanks in advance!
- x 10
Hi together
I need number of this part. I ad picture.
GOOGLE TRANSLATE
- x 6879
Here you go:bitsas004 wrote: 06 Mar 2025, 23:46 Hello, could i have build sheet please, thank you VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Vehicle Characteristics | |
Vehicle family | DISPATCH III |
AS/RP N° | 13848 U9 1 0269 |
Warranty Start Date | 31/10/2014 |
Engine serial number | 10 DYZG 4115915 |
BER | e2*2007/46*0045*12 |
P4A | 9803635699 |
General Information | |
PRODUCT TYPE | COMMERCIAL VEHICLE |
COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
VEHICLE FAMILY | DISPATCH III |
SILHOUETTE | LONG PANEL VAN H1 TYPE 12 |
TRIM LEVEL | MEDIUM MEDIUM |
ENGINE | DW10CD FAP 94KW DTR 1997 DIES |
TRANSMISSION | BVM6 |
PAINT TYPE | NON-METALLIC PAINT |
BODY COLOUR | EXY - ONYX BLACK PAINT |
INTERIOR TRIM TYPE | TRANSCODAGE CLOTH "DO" |
UPHOLSTERY COLOUR | "FR" |
GEARBOX (CHARACTERISTICS) | BVM ML6 CL |
DEFINITION TO FOLLOW | INITIALE RANGE |
ENGINE (TYPE) | EW/DW |
OTHER BADGE | WITHOUT FULLER BADGE |
OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
BADGE | WITHOUT BADGE |
SPEEDOMETER DRIVE | WITHOUT SPEEDOMETER RATIO |
Fuel Supply-Engine | |
FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
FUEL | DIESEL GRADE DA/DE/DE+ |
EMISSIONS STANDARD (ENGINE) | EURO 5 L6 UPPER ENGINE EMISSION CONTROL |
CAPACITY | 2000 CM3 |
CATALYTIC CONVERTER | 2-COMPOUND CATALYTIC CONV PRINTED FILTERS PT+PD |
CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
VALVE PER CYLINDER | 4 |
EOBD SELF-DIAGNOSIS SYSTEM | WITH "OBD" AUTO-DIAGNOSTICS |
DEVICE (ANTIPOLLUTION) | EXHAUST GAS RECYCING "EGR" + EXCHANGER |
VEHICLE TECHNICAL DEPOLLUTION | TECHNICAL VEHICLE EMISSION CONTROL EURO 5 |
PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
FAN | 2 300W + 460W 3-SPEED FANS |
FUEL VAPOUR RETRIEVAL | WITHOUT PETROL VAPOUR RECUPERATION |
INJECTION ASSOCIATED VARIANT | MOUNTING DELPHI |
DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
TANK FILTER | RESERVOIR FILTER INTERIOR |
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) | WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE) |
Gearbox Transmission | |
FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 14 X 67 |
WHEEL STYLE | 16 INCH GREY STEEL WHEEL |
CLUTCH | HYDRAULIC CLUTCH |
DIFFERENTIAL (GEARBOX) | DIFFERENTIAL DIAMETER 86 |
RIM/TYRE SIZE | 16 INCH TYRE FITMENT |
TYRE (SIZE, TYPE) | 215/60 R16 C (103 T) TYRE |
DRIVING WHEELS | 2 DRIVEN WHEELS |
WHEELS FITTED | 7" RIM ROAD WHEELS |
WHEEL (TYPE) | STEEL WHEELS |
INFLATION PRESSURE LOSS INDICATOR | WITHOUT TYRE DEFLATION INDICATOR |
GEARBOX TYPE | ML6C |
Suspension-Steering-Brakes | |
ABS | WITH ABS BRAKES |
STEERING COLUMN | MANUALLY ADJUSTED STEERING COLUMN |
BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
POWER STEERING FLUID COOLING SYSTEM | WITHOUT POWER STEERING OIL COOLING |
SUSPENSION | NORMAL SUSPENSION |
SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
STEERING (OPERATION) | ASSISTED ELECTROHYDRAULIC STEERING |
Body Fittings | |
TOWBAR | WITHOUT TOWBAR |
AERIAL | LONG ROOF AERIAL |
CABIN | WITHOUT CAB |
CHASSIS | LONG CHASSIS |
PAYLOAD | LOAD CAPACITY 900 KG |
SIDE MOULDINGS (TYPE) | LATERAL PROTECTOR MASS TINTED |
WHEEL EMBELLISHER (STYLE) | CABOCHON HUB COVER |
UNDERBODY SHIELD | REAR LATERAL PROTECTION |
INDICATORS | WITHOUT SIGNALING LIGHTS |
THIRD BRAKE LAMP | WITH EYE LEVEL REAR LIGHTS |
ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
DRAUGHT EXCLUSION | WITHOUT AERODYNAMIC SEALING |
EXT. LOAD RETENTION RING (ATTACHMENT) | BOAT EXT LASHING RING |
EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR ELECTRIC-FOLD BACK |
ENGINE BAY SOUNDPROOFING | BULKHEAD SOUNDPROOFING |
OPENING OF MOVING PANEL | DOOR OPENING AT 180 DEGREES |
WINDSCREEN WIPER | FRONT WIPER BLADE W/O RAIN SENSOR |
REAR SCREEN WIPER | W/O REAR SCREEN WASH WIPE |
HEADLAMP WIPER | W/O HEADLAMP WIPER |
REAR SCREEN WIPER (OPERATION) | WITHOUT REAR WIPER |
SIDE LOAD DOOR | LH/RH SIDE SLIDING METAL DOORS |
BUMPER | DYED FRONT/REAR BUMPER |
MUDFLAP | WITHOUT MUDGUARD |
ROOF | STANDARD ROOF PNL |
FRONT FOGLAMP | NO FRONT FOG LIGHTS |
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) | DRIVER’S DOOR MIRROR ELECTRIC CONTROL |
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) | PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL |
SPARE WHEEL | STEEL WHEEL + STANDARD TYRE |
EXTERIOR ACCESSORIES | NEUTRAL EXT MIRROR |
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | DOUBLE GLASS EXT MIRROR |
SUN ROOF | WITHOUT SUN ROOF |
BODY CONVERSION | WITHOUT |
BODY PROTECTION | WITHOUT |
REAR WINDOW (TYPE) | WITHOUT REAR WINDOW |
GLASS (APPEARANCE) | TINTED |
REAR QUARTER WINDOW (TYPE) | WITHOUT REAR QUARTER GLASS |
WINDOW (TYPE) | LAM W/SCREEN + SIDE + RR TOUGHENED |
SIDE WINDOW (COMM. VEH. ONLY) | WITHOUT SIDE WINDOW |
ROW 3 SIDE WINDOW | WITHOUT SIDE WINDOW 3ND ROW |
EXTERIOR STYLING PACK | WITHOUT BODY COLOUR EXTERIOR |
Interior Fittings | |
ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
CIGAR LIGHTER | WITHOUT CIGAR-LIGHTER |
REAR HEAD RESTRAINT | WITHOUT REAR HEADREST |
FRONT HEAD RESTRAINT | FRONT HEADREST ADJUSTABLE |
REAR SEAT | WITHOUT REAR BENCH |
SUPPLEMENTARY SEAT | WITHOUT SUPPLEMENTARY SEAT POSITN |
REAR SEAT ARMREST | WITHOUT RR SEAT ARMREST |
CABIN SEAT | 2 PLACES PASSENGER BENCH |
LUGGAGE COVER | WITHOUT LUGGAGE COVER |
REAR SEATBELT | WITHOUT REAR SAFETY BELT |
FRONT SEATBELT | DRIVER ALARM INERTIA + PASS 2 ALARM SS INERTIA |
CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
GRAB HANDLES | HANDLE FR PASS + HOOK |
SUPPLEMENTARY SEAT ADJUSTMENT | WITHOUT ADD SEAT ADJUSTMENT |
DRIVING POSITION | RIGHT HAND DRIVE |
REMOTE CONTROL | SEPARATE FRONT / REAR CONTROL |
ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
BOOT AND LOAD SPACE LIGHTING | WITHOUT BOOT LIGHT |
DASHBOARD EQUIPMENT | WITHOUT DECOR |
INT. TRIM AND EQUIPMENT VARIATION | ISOREL INT SIDE PROTECTION TRIM |
MISC. INT. LAMPS | W/O MAP READING LAMP |
WORK TABLE | WITHOUT WORK TABLE |
LOAD SPACE TRIM | W/O MAT |
FRONT SEAT RUNNER | WITHOUT RUNNER |
FRONT HEAD RESTRAINT (STYLE) | FULL FRONT HEAD RESTRAINT |
INSTRUMENT PANEL (CHARACTERISTICS) | GRADUATION 190 KM/H OR 120 MPH BLACK BACKGROUND |
LOUDSPEAKER | 2HP AV |
TIMER | WITHOUT TACHOGRAPH |
RADIO CONTROLS | REMOTE RADIO CONTROL |
ADDITIONAL BLOWER | WITHOUT ADDITIONAL PULSE |
SIDE DOOR CONTROL MECHANISM | WITHOUT SIDE DOOR CONTROL |
SUPPLEMENTARY SEAT HEAD RESTRAINT | W/O HEADREST EXTRA SITTING |
PASSENGER COMPARTMENT SOUNDPROOFING | 7 KG BULKHEAD SOUNDPROOFING |
DRIVER SEAT CONTROL | MANUAL DRIVER’S SEAT CONTROL |
FRONT PASSENGER SEAT CONTROL | W/O PASS FRONT SEAT CNTRL |
DRIVER SEAT ADJUSTMENT | RECLINING DRIVER’S SEAT BACK |
FRONT PASSENGER SEAT ADJUSTMENT | WITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT |
FRONT SEAT ARMREST | ASSEMBLY WITHOUT FRONT ELBOW REST |
EXTERIOR TEMP. INDICATOR | EXT TEMP INDICATOR |
COMPACT DISC | WITHOUT COMPACT DISC |
SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
REAR WINDOW LIFT | WITHOUT REAR GLASS LIFT |
CABIN CARPET | FRONT PASSENGER COMPARTMENT CARPET |
DRIVER’S WINDOW LIFT | SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT | SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
DISPLAY | DISPLAY (RADIO+CLOCK AND OR TEMP, CD) |
MISC. INT. ACCESSORY | WITH CUP HOLDER DRIVER’S SIDE |
SUPPLEMENTARY SEAT SEATBELT | W/O SUPPLY SEAT SAFETY BELT |
COURTESY MIRROR | WITHOUT VANITY MIRROR |
FOOTREST | DRIVER’S FOOTREST |
OIL GAUGE | INSTRUMENT PANEL LEVEL + TEMPERATURE |
HEATING ELEMENT | NON HEATED SEAT |
FRONT LATERAL AIRBAG | WITHOUT FRONT SIDE AIRBAG |
REAR PASSENGER PROTECTION | W/O RR PASSENGER PROTECTION |
PASSENGER AIRBAG | NO PASSENGER AIRBAG |
ADDITIONAL AIR CONDITIONING | WITHOUT ADDITIONAL AIR CONDITIONING |
HEATING DUCT | FRONT HEATING DUCT |
ON-BOARD COMPUTER | COMPUTER |
EQUIPMENT PACK | W/O EQUIPMENT PACK |
EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED DOOR MIRROR |
AIRBAG DEACTIVATION | WITHOUT AIRBAG DEACTIVATION |
REAR MOVING PANEL | 2 REAR HINGED METAL DOORS |
COURTESY LAMP | CTRL FR DOORS + FR CRT LIGHT AND RR CRT LIGHT MANU |
FRONT SEAT GUARD | NON-REMOVABLE PANEL + TUNNEL CONCEALER |
STORAGE (DRIVING POSITION) | LOWER STORAGE COMPARTMENT WITH LOCK |
RADIO RECEIVER | RD45 MP3 RADIO CD/REMOTE DISPLAY |
REFRIGERATION | SINGLE AIR CONDITIONING |
CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
DRIVER’S SEAT HEIGHT CONTROL | PASSIVE PARALLEL ADJUSTMENT |
INTERIOR REAR VIEW MIRROR | WITHOUT INTERIOR MIRROR |
DRIVER AIRBAG | DRIVERS AIR BAG |
LOAD SPACE STORAGE | W/O BOOT TIDY |
CARPET | RUBBER CARPET |
LIGHTING TIMER | WITHOUT TIMER |
INTERIOR PROTECTION | WITHOUT INNER PROTECTION |
OBSTACLE DETECTION SYSTEM | OBSTACLE DETECTOR |
LATERAL BLINDS | WITHOUT SIDE BLINDS |
FLOOR MAT | W/O CARPETMAT |
RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
LOCKING CONTROL | CENTRAL DEAD LOCKING |
STEERING WHEEL | RUBBER STEERING WHEEL |
SEATING ASSOCIATED VARIANT | BACKREST REAR SIDE NON-FABRIC |
CHILD OBSERVATION INTERIOR MIRROR | WITHOUT INTERIOR CHILD MONITORING MIRROR |
AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB + BLUETOOTH |
Electrical | |
ALTERNATOR | ALTERNATOR 150 AMP |
BATTERY | BATTERY L3 720 |
STARTER MOTOR | STARTER MOTOR CL 5 |
SPECIAL LIGHTING | WITHOUT PARTICULAR LIGHT |
ELECTRIC VEHICLE CHARGING PLUG | WITHOUT VEHICLE LOAD RECOGNITION |
BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
Component Manufacturers | |
Miscellaneous | |
SPECIAL SPECIFICATION | GB ANIMATION SERIES |
MODIF. DURING MODEL YEAR | 2ND MINOR MODIFICATION |
ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
LABEL | WITHOUT LABEL |
RADIO HEADPHONE SOCKET | SINGLE ACCESSORY SOCKET |
TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
PLATE | WITHOUT PLATFORM FLOOR |
SET OF KEYS | 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY |
EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
SURFACE CONDITIONS | GOOD TERRAIN |
SPEED MONITORING | WITHOUT SPEED CHECK |
- x 6879
We only need the VIN, we can get everything from that.Markyt1980 wrote: 07 Mar 2025, 00:35 Hi I am wondering if someone could help me find the correct part for my Citroen C4 Grand Picasso mk1
Here you are:
(1) ABS / ESP Hydraulic Block, part: 4541QE, £1,798.98
Note this is supplied unconfigured from the dealer, so will need configuring with Diagbox, especially if you are considering a used one, as that will be already be programmed for the vehicle from which it came from. You will also have to ensure that the steering wheel angle sensor is calibrated after replacement.
- x 6879
Are you referring to the low pressure steering pipe? If so,toolfan wrote: 07 Mar 2025, 08:29 Hello, had it posted in the general forum, just found out it belongs in here:
Thanks in advance!
(3) Steering Low Pressure Pipe, part: 4012A9, but no longer available from Citroen.
- x 6879
Not sure if mean the atual ECU or the screw, so here's both:GORAX wrote: 07 Mar 2025, 08:57 Hi together
(1) Automatic Gearbox ECU (must be configured with Diagnostic tool) , part: 1611078580, £1165.22
(2) Threaded Screw with Washer, part: 6923G6, £2.63
Hi Marc,
I hope these pictures tell the story. It's the weather strip that touches the window with a felt like strip and has a black painted strip on the outside. Left and right side of the rear windows.
Thanks a lot,
Bart
Thanks a lot,
Bart
- x 6879
Ok, so here you go:
(8) Door Window Lower Outside Seal
Left, part: 9687748180, £93.14
Right, part: 9687615880, £93.14
(9) Door Window Lower Internal Weatherstrip
Left, part: 9687619580, £31.36
Right, part: 9687619380, £31.36
Don't forget about the Airbag recall I mentioned in my last post....
Info about these here:
viewtopic.php?t=85443
- x 10
Thanks for the info. But I mean the one in the middle of the circle that I drew. It looks like a nipple or something. I don't have it. It looks like it's protecting the gearbox control unit from the air filter box. It is located exactly on the gearbox control unit.GiveMeABreak wrote: 07 Mar 2025, 11:29GORAX wrote: 07 Mar 2025, 08:57 Hi together
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
GOOGLE TRANSLATE
- x 6879
It's not shown as a part - only the seal! This bolt is part of the actual gearbox and holds the ECU in place.
(1) Automatic Gearbox Seal, part: 257525
As you can see below it is part of the gearbox assembly as far as I can see:
- x 10
Thanks! i never stop learning from you
GOOGLE TRANSLATE
GiveMeABreak wrote: 07 Mar 2025, 11:25Are you referring to the low pressure steering pipe? If so,toolfan wrote: 07 Mar 2025, 08:29 Hello, had it posted in the general forum, just found out it belongs in here:
It is a C5 2.0 HDI, 2007. VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Thanks in advance!
Thank you, thats the pipe I need. Found an original one in France.
Hi there thank you very much. I just want to check one thing. I have looked and searched and now I feel I’m in a rabbit hole. When I searched for the part number. It came up with a site that asked for my vin number. And it has brought up a load of options. Looking at the date of when mine was built using the OPR. Mine fits a few options. But they say replaced by what you suggest. Does this mean the part is a replacement for my original part or they were superseded. Becuase the OPR is from after when my car was built. I sadly the one in my car has had the details scratched off so working in the dark. If I get the 4541 qe will that still work or should I try to find the older version. I don’t want to get the wrong thing for my mechanic. Sorry if I am going on. I have had a nightmare with this car and just need it working once and for all. After just spending a fortune on other bits like the turbo going the otherGiveMeABreak wrote: 07 Mar 2025, 11:19We only need the VIN, we can get everything from that.Markyt1980 wrote: 07 Mar 2025, 00:35 Hi I am wondering if someone could help me find the correct part for my Citroen C4 Grand Picasso mk1
The vin is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Here you are:
Month. And my English mondeo dying in December and my January astra English purchase to replace the mondeo. And get me about in the uk while the Citroen turbo dying, deciding this week to need a new clutch. 3 cars since December going wrong.
Just trying to be 100% sure.
