x 6922
Re: Important Information concerning access to PSA parts data
Ok, so the front shim set is part: 440732 priced at £25.33 inc. VAT from Peugeot.
As for the exhaust - I can't see mention of a flexible pipe, so let me know which one you need - this is the intermediate and rear sections:
colinsunderland
Unread post by colinsunderland »
GiveMeABreak wrote: 13 Nov 2021, 09:12 Ok, so the front shim set is part: 440732 priced at £25.33 inc. VAT from Peugeot.
Thanks very much Marc
I think the exhaust section is the part before the centre pipe you posted the pic of, it's certainly hidden by the engine tray as it was only when we removed that that we found the small split in the pipe
EDIT: Just looked on ebay and if it's not this one, it looks similar
https://www.ebay.co.uk/itm/153057054720 ... SwU4hbHV9y
x 6922
I misread your post and put the mid and rear up :roll:
Here you go, sorry about that - I was dealing with another 3008 at the time and got mixed up.
Genuine Peugeot OEM: 1706V0 £149.66
Peugeot Recommended Cheaper part: 1607338480 £107.94
colinsunderland
GiveMeABreak wrote: 13 Nov 2021, 21:38 I misread your post and put the mid and rear up :roll:
How much :cry:
I'll put up with the very slight blow I've had for a couple of years I think :-D
Cheap ones are on ebay for £24ish, brand new, is there any reason not to buy a cheapie, considering what it is and the car is 10 years old?
I have a feeling I'll need the clamps for both ends too, as they are likely to drop apart if I remove them, is there a specific part number for those too please?
Thanks very much for your help again :)
x 6922
Re: Citroen and Peugeot Parts Requests
Ok, so the clamp (13) is part 171366 (Diam 66)
and the clamp (2) on the previous diagram is part 171367 (Diam 54).
I can't get prices on these at present as the parts service is closed for 19 hours undergoing maintenance.
But to answer your question, the exhausts are probably more expensive as these will be original parts and so 10 years is fair game. As for aftermarket that part on ebay you linked to is a used part - so 11 year old itself - so no guarantees how long that will last.
As with anything, it's a price v quality issue - cheaper systems may not be made of the same quality materials and may wear / corrode more quickly, so down to choice.
An unbranded one here for £65 inc. VAT plus £15 delivery (http://www.exhaustdirect24.co.uk/shop-e ... ivery.html)- or take a chance on an OEM used one like that £26 one with free delivery...
colinsunderland
GiveMeABreak wrote: 14 Nov 2021, 07:32 Ok, so the clamp (13) is part 171366 (Diam 66)
Thanks Marc
I wasn't meaning the used one, just popped that up to show what it looked like so you could identify it easier :)
https://www.ebay.co.uk/itm/234271795317 ... SwZuNhhOIs
thats a brand new one, £30 and theres 20% off at the moment, so £24 delivered. Cant find much out about BM Cats with regards to exhaust sections, although their cats seem to get ok reviews, only thing that keeps being mentioned is the weld isn't the neatest, but as you can't see it that doesn't matter :)
x 6922
Yes, I'm sure it will do and at that price, can't go wrong if it only lasts for a few years (hopefully more!).
C5_Jack
Unread post by C5_Jack »
Hello
I have be rear ended and I'm looking for a complete rear bumper for a C5 X7 2013 estate with all the pieces of trim.
Thank you
Jack Morgan-Smith
x 6922
Hi Jack, is this a part number request or a ‘wanted’ request for spares?
C5_Jack
Hi Mark
It is a part(s) number request.
Once I have them I can start looking for them if that make sens.
Jack
x 6922
Ok in that case Jack please see the table in post number one for info regarding parts requests:
viewtopic.php?p=685750#p685750
Rhothgar
Donor 2023
x 136
Unread post by Rhothgar »
Hi Marc,
Can I have parts fiche for M728 GDL please for suspension tops? Looking for the rubber bungs specifically. I have a knocking from the front end that mate says isn't any of the bushes or ball joints. TIA
x 6922
(4) is the rebound stop 96044687 (no longer available)
(5) is the Bumper Spacer 96127005 (also no longer available)
(14) is the Shock Absorber Fix Cover, 503531 (still available).
If it's anything else, let me know the item number on the diagram.
Rhothgar
Donor 2023
x 136
Thanks Mark but...
Oh damn! The diagram doesn't really appear to correlate with what I have. The gaiter fixes by friction to what I assume is the bumper stop but in this image, it doesn't look as though the diameters match anywhere near!
x 6922
This is for your VIN ending 785, so bear in mind it's an exploded diagram.
