GavinPJ
Donor 2023
Unread post by GavinPJ »
Hi Marc,
Can I get the build sheet for my 508 please. VF3**************[VIN obfuscated, can be read by forum staff]
Never knew these existed.
Thanks a million.
x 1262
Paul-R wrote: 27 Feb 2025, 14:51 Peugeot 308 T9 1.6 BlueHdi VF3**************[VIN obfuscated, can be read by forum staff]
Cover on top of the engine that covers the cam cover and injectors. Has hole cut out for oil filler. Please.
9805762880 - yours for a mere £87.59 :-D
It's widely used, so a scrapper should yield one - e.g. comes back against these for Peugeot, I imagine a similar number for Citroen:
Information about the search
4 document(s) found for 2008 (A94F)
4 document(s) found for 208
3 document(s) found for 3008 (P84E)
2 document(s) found for 3008 (T84)
1 document(s) found for 301
3 document(s) found for 308 (T9)
3 document(s) found for 5008 (P87E)
2 document(s) found for 5008 (T87)
2 document(s) found for 508
3 document(s) found for PARTNER TEPEE (B9)
3 document(s) found for PARTNER UTILITY VEHICLE (B9)
2 document(s) found for PARTNER VU (K9)
2 document(s) found for RIFTER (K9)
x 1262
GavinPJ wrote: 28 Feb 2025, 10:20 Hi Marc,
Thanks a million.
Not as pretty as Marc's version, but here it is!
[I've replaced it for ease of Viewing Richard, Marc]
Vehicle Characteristics
Vehicle family508
AS/RP N°14165 CJ 1 0129
Warranty Start Date21/09/2015
Engine serial number10 DYZH 4025126
BERe2*2007/46*0080*26
P4A9810108999
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILY508
SILHOUETTE5 DOOR ESTATE
TRIM LEVELHIGH MEDIUM PLUS
ENGINEDW10FD FAP 110KW DIESEL
TRANSMISSIONSTT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPEMETALLIC LACQUER
BODY COLOURKCA - ARTENSE GREY PAINT
INTERIOR TRIM TYPEMID-LEATHER MARSTON "3F"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)ML6CW
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)EW/DW
OTHER BADGE, " MISC. "BLUE HDI
STEERINGPOWER STEERING
SPEEDOMETER DRIVEWITHOUT SPEEDOMETER RATIO
Fuel Supply-Engine
FUEL SUPPLYINJECTION SUPPLY
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.1 ENGINE EMISSION CONTROL
EXHAUSTLONGITUDINAL REAR SILENCER
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
CATALYTIC CONVERTERCATALYSEUR INFERIEUR 500PPM 70GR
OIL COOLERMNTG EXCHANGER ON ENG & G/BOX
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONNORMAL FUEL CONSUMPTION OPTIMISATION
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)PUISSANCE MOTEUR 110 KW 370 NM
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 DUAL-SPEED ELECTRONIC FAN 140W
INJECTION ASSOCIATED VARIANTMOUNTING DELPHI
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT)MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND STARTSTOP & START ALTERNO STARTER BOOST
Gearbox Transmission
FINAL DRIVE RATIOCP 19X70
WHEEL STYLESTYLE 07 18"
CLUTCHWITHOUT CLUTCH
SEAL, WHEEL ENDWHEEL-SIDE SEAL RZ20
SEAL, DIFFERENTIAL ENDJB3T AXLE-SIDE SEAL
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 86
RIM/TYRE SIZE18 INCH TYRE FITMENT
TYRE (SIZE, TYPE)235/45 R18 98W REINFORCED TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORLOSS OF INFLATION PRESSURE INDICATOR EU STANDARD 64.02
GEARBOX TYPEML6C
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 20
STEERING COLUMNMANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BARFRONT ANTI ROLL BAR DIAM 23,5
SUSPENSIONNORMAL SUSPENSION
ACTIVE SUSPENSIONWITHOUT VARIABLE SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMWITH ESC SYSTEM
BRAKE ASSOCIATED VARIANT8 1 BOSCH ESP
STEERING (OPERATION)ASSISTED ELECTROHYDRAULIC STEERING
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALAERIAL + GPS
PAYLOADLOAD CAPACITY 815 KG
FINISHER (SELF-ADHESIVE)BLACK FRONT/REAR SIDE + REAR DOOR WINDOW TRIM
SIDE MOULDINGS (TYPE)WITHOUT LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION)WITHOUT BODY SILL PROTECTORS
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
REVERSING LAMPSWITH 1 REVERSING LIGHT
SILL ILLUMINATION LAMPFRONT SILL LIGHTING LIGHT
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)WITH DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXT REAR VIEW MIRROR NO MEMORY
ENGINE BAY SOUNDPROOFINGBONNET SOUNDPROOFING
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPERWITH REAR WIPER
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITH AIR INTAKE MODULE FR FACE CLOSER
ROOF GLASSWITH ROOF WINDOW
REAR TAILGATE GLASSFIXED TAILGATE WINDOW
BUMPERSTANDARD BODY COLOUR FR/RR BUMPERS + CHROME GRILLE
MUDFLAPWITHOUT REAR MUDGUARD
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFRONT FOG LIGHTS
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
SPARE WHEELEMERGENCY WHEEL
EXTERIOR ACCESSORIESEXTERIOR HANDLE AND SLIDE TRIM, CHROME
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
SUN ROOFFIXED ROOF
BUMPER TRIMBUMPER WITH CHROME INSERT
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
HANDS FREE ACCESS AND STARTINGWITH ACCES AND HANDSFREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITH THEFT PROTECTION ALARM
REAR SEATSEPARATE FOLD BACK BENCH SEAT
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTDOUBLE PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORFLOOR GEAR CONTROL
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENTCUBIC MINIWEAVE DECOR
MISC. INT. LAMPSFR + RR LED MAP READER
LOAD SPACE TRIMBOOT CARPET + CARPET SIDES
INSTRUMENT PANEL (CHARACTERISTICS)MAX:260KM/H-160M/H,MAT WHITE
DOOR TRIMCLOTH DECOR
LOUDSPEAKER4 HP FRONT (2 TW + FR) + 4 HP REAR
RADIO CONTROLSSTANDARD AUDIO SYSTEM REMOTE CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROLPASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT ELEC CONTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT ELEC CNTRL
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER LUMBAR ADJUSTMENT
FRONT SEAT ARMREST (OPERATION)FRONT ARMREST MANUAL
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYTOUCH DIGITAL SCREEN DISPLAY
COURTESY MIRRORDRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGEOIL TEMP + LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTHEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER + FR+RR PASS FOOTWELL LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMPWITHOUT DIRECTIONAL LIGHTS
RADIO RECEIVERSMEG DIGITAL RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED BI-ZONE
CARPET COVERTRAMONTANE MATS
LOAD SPACE STORAGEWITH BOOT TIDY
TUNER RADIOTRI RADIO TUNER
OBSTACLE DETECTION SYSTEMFR RR RADAR OBSTACLE DETECTOR + RR CAMERA
LATERAL BLINDSWITHOUT SIDE BLINDS
TRIM ADAPTATIONLEATHER KNOB + PLASTIC GAITER
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEAD LOCKING
STEERING WHEELLEATHER STEERING WHEEL 3 BRANCHES
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREENWITHOUT REAR VIDEO SCREEN
AUDIO PACK AUXILIARY SOCKET1 JACK PLUG + 2 USB
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORISTT53
BATTERYL3 760 VRLA2 EN AGM
STARTER MOTORSTARTER MOTOR CL 5
SPECIAL LIGHTINGAUTOMATIC LIGHTING + FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
LIGHTING OF LAMPSMANUAL SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEAR2ND MINOR MODIFICATION
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
RADIO HEADPHONE SOCKETQUADRUPLE ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SET OF KEYS2 HF PLIP KEYS
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
ADDITIONAL TYPE APPROVAL PLATEW/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNITBSI EVOLUTION
EMERGENCY WARNING TRIANGLEWITHOUT WARNING TRIANGLE
GavinPJ
Donor 2023
Thanks a million lads. Nice to keep with the original book pack and all the other
old documents I have for it. If I can sort the rattle from the radio/heater control
area this weekend I'll be happy. Bought the car as a write off so I might do a little
thread on the highs and lows or sorting the "little" problems.
Donor 2023
x 1493
Unread post by Paul-R »
RichardW wrote: 28 Feb 2025, 14:139805762880 - yours for a mere £87.59 :-D
Flip! I'll have a look at repairing what I've still got.
"Trying is the first step towards failure" ~ Homer J Simpson?
Old Berlingo
Unread post by Old Berlingo »
Hi Marc,
Thanks for the diagram but the hoses I’m after aren’t on it. The thermostat housing is but it doesn’t show the original part number which would be good to have so I can try and source the part.
The hoses I’m talking about go into the firewall and connect to the heater. I’ve included photos of them from two different angles. They’re actually joined to each other at the top end. My mechanic had to separate them to get them off that’s why they look like two separate hoses in the pics. I’ve also included pics when they’re attached to the firewall. I’m after the original part number or where I can source the part itself.
2001 Citroen Berlingo 1.4i petrol
Engine No.: FS873499453
Oh yes, the Engine Code would be great too.
Thanks so much for the help 😄
x 1262
Old Berlingo wrote: 01 Mar 2025, 11:38 Hi Marc,
On here, Item 6:
646697 - no longer available unfortunately (that's what NFP means). It looks like Berlingo / Partner only.
Engine code is TU3JP
Micko
Unread post by Micko »
]Can i have the number for the bushings 17 and 16. Thanks in advance.
wurlycorner
x 98
Unread post by wurlycorner »
Could I please request the part number for what I think is an idler pulley on my X7 (marked "Idler" on the sketch I've done below) and the Power Steering Pump (marked P.S)?
Also, are there any instructions on replacing the pulley and power steering pump (I can't see down there from the top well enough to work out how they're secured right now)?
I have done a search on the forum but didn't turn anything up unfrotunately.
I assume the belt change procedure on the 3.0 V6 is the same as for the 2.7 V6 here?
Also if not too much trouble while in there, is it possible to have the build sheet for my car please?
Iain
CX DTR T2 Safari (silver)
x 1262
Micko wrote: 02 Mar 2025, 15:54 ]Can i have the number for the bushings 17 and 16. Thanks in advance.
Here's the diagram for your car:
The joints are:
1610828180 Left (£4.58)
1610828280 Right ($.74)
However these are generally no longer available, there is a link to another sheet that probably tells us this, but it's not working. You have to buy the complete arms:
9830026180 Left / 9830026080 Right at £173.62 each.....
x 1262
wurlycorner wrote: 02 Mar 2025, 19:40 Could I please request the part number for what I think is an idler pulley on my X7 (marked "Idler" on the sketch I've done below) and the Power Steering Pump (marked P.S)?
Idler, item 3:
1611422780 - £78.64
Pump:
Only available exchange now - 1673621080 - £401.77 + £120 surcharge for the old one. (Original part number 4008 74).
Build details, I'm sure Marc will re-format!
Duly Reformatted! :-D
Vehicle familyC5 (X7)
AS/RP N°12790 CJ 1 0035
Warranty Start Date30/11/2011
Engine serial number10 TRK1 0590085
BERe2*2001/116*0360*19
P4A9666040099
General Information
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC5 (X7)
TRIM LEVELUPPER LOW PLUS
ENGINEDT20C TURBO DIESEL
TRANSMISSION6-SPEED AUTOMATIC GEARBOX
PAINT TYPEMETALLIC PAINTWORK
BODY COLOURKGN - BOURRASQUE PAINT
INTERIOR TRIM TYPELEATHER CLAUDIA MISTRAL L019 "QR"
GEARBOX (CHARACTERISTICS)BVA AM6C
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)TYPE ENGINE DT
OTHER BADGE, " MISC. "EXCLUSIVE
BADGEC5
STEERINGVARIABLE POWER STEERING
SPEEDOMETER DRIVEW/O TACHO TORQUE
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITH DIESEL FILTER WATER DETECTOR
EMISSIONS STANDARD (ENGINE)EURO 5 L6 UPPER ENGINE EMISSION CONTROL
EXHAUSTTRANSVERSE REAR SILENCER
CAPACITY3000 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER LESS THAN 10PPM
OIL COOLERENGINE+GBOX OIL/WATER EXCHANGER
COOLING MOTORRADIATOR TH : 33 - 27 DM2 ALUMINIUM BRAZIER
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONTECHNICAL VEHICLE EMISSION CONTROL EURO 5
FAN2 ELECTRONIC FANS 33W INTEGRAL CTRL
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
STOP AND STARTWITHOUT STOP AND START
FINAL DRIVE RATIOCP 15 X 53
WHEEL STYLEWHEEL ATLANTIQUE 18 INCH
SEAL, WHEEL ENDSEAL WHEEL SIDE AC 3300I
SEAL, DIFFERENTIAL ENDJOINT COTE PONT AAR 3300A
TYRE (SIZE, TYPE)245/45 R18 100W REINFORCED TYRE
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 3
INFLATION PRESSURE LOSS INDICATORTYRE DEFLECTION INDICATOR
GEARBOX TYPEAuto gearbox AM6
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 21.5
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 25
STEERING TRAVEL180 STEERING MECHANISM TRAVEL
ACTIVE SUSPENSIONACTIVE SUSPENSION MANUAL ADJUSTMENT
SUSPENSION (ARCHITECTURE TYPE)HYDRAULIC SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)ASSISTED MANUAL STEERING
Body Fittings
PAYLOADNORMAL PAYLOAD
SIDE MOULDINGS (TYPE)CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION)PLASTIC + CHROME SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE)WHEEL TRIM ATLANTIQUE 18 INCH
EXHAUST TAILPIPENON CHROME PLATED EXHAUST TAIL PIPE
INDICATORSLUMINOUS SIGNATURE
SILL ILLUMINATION LAMPSILL LIGHT FRONT AND REAR
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR ELECTRIC-FOLD BACK
WINDSCREEN WIPERFRONT WIPER AUTO SPEED 16 SPEED
HEADLAMP WIPERHEADLAMP WASHWIPE
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERBODY COL BUMPER + CHROME PROT + CHROME GRILLE TRIM
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE)TINTED EXT REAR VIEW MIRROR
EXTERIOR ACCESSORIESCHROME EFFECT EXTERIOR HANDLE
SUN ROOFFIXED ROOF
BUMPER TRIMBODY COLOUR BUMPER STRIP
GLASS (APPEARANCE)DEEP TINTED WINDOW
HANDS FREE ACCESS AND STARTINGWITHOUT HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMALARM ULTRASONIC+PERIMETER STD
BOOT AND LOAD SPACE LIGHTINGBOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENTPALEA METAL DECOR
MISC. INT. LAMPSSOFT AMBIANCE LIGHTING
LOAD SPACE TRIMCARPET+MOULDING AND CHROMED HANDLE
UNDERSEAT STORAGEWITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS)GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIMGLOSS ARGENT BLACK DECOR
CHILD SEAT ANCHORING POINTSWITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER4 FR SPKRS (2TW=2SPKRS)+5 RR SPKRS (2TW+2SPKRS+1C
PASSENGER COMPARTMENT SOUNDPROOFING7 KG BULKHEAD SOUNDPROOFING
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROLMEMORY CTRL DRIVERS FRONT SEAT
DRIVER SEAT ADJUSTMENTDRIV SEAT BACK ANGLE+LUMB ADJ FIXED SIDE UPPER BK
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
HEADLAMP BULBSDISCHARGE BULB
REAR WINDOW LIFTSEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDISPLAY DG4
OIL GAUGESTD OIL LEVEL INDICATOR
FRONT LATERAL AIRBAGFR+RR CURTAIN THORAX LAT AIR BAG
FOOTWELL LIGHTINGDRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMPWITH DIRECTIONAL LIGHTS
RADIO RECEIVER4TH GENERATION "NG4" RADIO NAVE SYSTEM
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT-REAR RADAR OBSTACLE SENSOR
LATERAL BLINDSSIDE BLINDS
TRIM ADAPTATIONLEATHER GEAR LEVER KNOB + LEATHER GAITER
EQUALISER AMPLIFIERWITH EQUALISER AMPLIFIER
STEERING WHEELSMOOTH LEATHER STEERING WHEEL
DRIVER’S KNEE AIRBAGWITH KNEE AIRBAG
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
SEAT LUMBAR SUPPORT (OPERATION)AUTOMATIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET1 AUDIO RCA SOCKET
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR CLASS 22
BATTERYBATTERY L3 500
STARTER MOTORSTARTER MOTOR CLASS 6+
SPECIAL LIGHTINGFRONT DAYTIME LIGHTS
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Miscellaneous
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
LABELWITHOUT
SET OF KEYS2 HIGH FREQUENCY REMOTE CONTROL KEYS
wurlycorner
x 98
Thanks Richard, much appreciated.
In case anyone else is interested, the drive belt is a 6PK1885.
Also - apologies - I meant to ask for the engine mount part numbers as well :oops:
By searching the forum I've found a thread with the replacement instructions for the right model here but can't find the part numbers (all the part numbers I can find are for x7 engine mounts with other engine types).
Iain
x 1262
wurlycorner wrote: 02 Mar 2025, 22:30
Here's the diagram, lots of parts! I've marked the ones that look like the flexibles (only 2 are stated as such)
Some of the prices are a bit :shock: :twisted:
If you need other ones, let me know which ones and I'll look them up.
Old Berlingo
RichardW wrote: 01 Mar 2025, 17:39
VIN: VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
On here, Item 6:
Thank you so much for your help Richard. :-D
Old Berlingo
Thanks Richard, you’ve been super-helpful. :)
