x 6880
MattBLancs wrote: 05 Feb 2025, 14:08
GiveMeABreak wrote: 05 Feb 2025, 11:21 Only just picked this up via the parts thread Matt (always best to request parts there so they're not missed anywhere else).
Sorry Marc, it is on the parts thread, just a bit further up (a few other queries came in directly after mine which have been answered, hence my cheeky post as I reckoned I'd got lost in the noise somewhat :) )
Thanks for the comprehensive answers. Bit confused the fascia is correct (which is the one with a CD shaped hole in it!) but no CD drive coming up, very strange!
Not sure I've got the internal jukebox, or else I'm feeling daft not noticing it if so!? :-D will check when back at the car again this evening.
Will get digging for lead and drive.
Wheel arch liner image is spot on - number 18 is the grille I tried to describe. Current liner has a removal panel in same spot, but it's solid!
As said intercooler is ahead of it so a route for airflow seems eminently sensible. More digging for me!
Thanks again
No my fault - I got confused with your other thread and missed the parts thread request earlier.
There's no physical jukebox Matt, it's a feature of some Head Units that would allow you to copy a CD (rip a CD if you like) when inserted, to the Hard Drive on the older units that had Hard Drives, to save swapping CDs all the time. It's not available for CD Ripping on the SMEG units as they don't use HDD,s only flash memory and space is likely limited.
The CD Fascia and CD Harness are only available and shown on the Accessories section for your car, for those wanting one which was not factory supplied and fitted.
x 6880
GORAX wrote: 05 Feb 2025, 18:34 Hi everybody,
I need part number for gearbox oil seal and drain cap seal.
(5) AUTOMATIC GEARBOX PLUG SEAL, 17,8 X 22,6, part: 220953, £3.35
(6) AUTOMATIC GEARBOX PLUG SEAL 6,07 X 9,63 - 1,78, part: 220945, £2.28
GORAX
x 10
Unread post by GORAX »
Thanks Marc!
GOOGLE TRANSLATE
x 1765
Unread post by MattBLancs »
GiveMeABreak wrote: 06 Feb 2025, 12:41 No my fault - I got confused with your other thread and missed the parts thread request earlier.
No problem at all, I don't know how you manage to keep up with all the requests that come flying your way as it is!
There's no physical jukebox Matt, it's a feature of some Head Units that would allow you to copy a CD (rip a CD if you like) when inserted, to the Hard Drive on the older units that had Hard Drives, to save swapping CDs all the time. It's not available on the SMEG units as they don't use HDD,s only flash memory and space is likely limited.
More interesting info, spot on, thank you
x 6880
MattBLancs wrote: 06 Feb 2025, 16:07
Matt - Urgent! Please ignore previous advice regarding the CD Player itself. I have just had another look in a different section of the accessories and can see that the specific CD player for your vehicle is part: 1610916280, £185.58
Here is the entire listing for reference:
Click Image to Zoom
Hope that sorts it. The reference for the CD I previously gave is likely not compatible as it will be for RD4 or one of the other Head Units, so please use part reference 1610916280.
Micko
Unread post by Micko »
Can i get the number for the lower control arm bushings.
x 1765
GiveMeABreak wrote: 06 Feb 2025, 17:34
Click Image to Zoom
Spot on Marc, thanks for the updated information. I'll get researching
Steve Walsh
x 433
Unread post by Steve Walsh »
Could I have a part number and price please for a leak off pipe, from injectors back to pump,
Peugeot 3008 2.0 hdi. VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanx
Thanx to Marc and all the admins & knowledgeable people that make this the best forum on the interweb. =D> =D> =D>
x 6880
Here you go:
(8) Diesel Injector Return Pipe, part: 1574AJ, £37.94
x 6880
Micko wrote: 06 Feb 2025, 18:30 Can i get the number for the lower control arm bushings.
Ok, so Citroen do not provide the bushings separately, they are only supplied with the wishbones (2):
(2) Wishbones:
Citroen Original (Left), part: 9846329780, £154.22
Citroen Cheaper Alternative (Left), part: 1682729680, £47.28
Citroen Original (Right), part: 9846329280, £154.22
Citroen Cheaper Alternative (Right), part: 1682729580, £49.66
x 6880
Micko wrote: 05 Feb 2025, 12:35 Can i get the number for the bolt thats holds the joint/yoke that connect the steering colum with the steering rack.
Hi, again they don't provide the yoke separately - all part of the column - only the bolts and nuts:
(1) Steering Column, part: 96748611ZD, £890.36
(3) Column Fixing Safety Clip, part: 9807514580, £2.92
(5) Steering Universal Joint Bolt, part: 410562, £2.87
(70) Bolt, part: 9802186380, £2.56
(71) Self-Locking Nut, part: 6939C2, £0.42
Steve Walsh
x 433
Thankyou Marc
Steve
Dustysweeper
Donor 2023
x 12
Unread post by Dustysweeper »
Good morning all. Could I please have the part number for the fuel injectors. No.4 has crapped on me.
The gift that keeps giving eh...🙄
Many thanks.
Huskyxantia
x 548
Unread post by Huskyxantia »
If I'm in the wrong place , sorry ,
Hi Marc part numbers for the injectors VF3**************[VIN obfuscated, can be read by forum staff] Many thanks.
:-D
x 6880
Dustysweeper wrote: 09 Feb 2025, 12:45 Good morning all. Could I please have the part number for the fuel injectors. No.4 has crapped on me.
Many thanks.
(7) Siemens New Injector, part: 9802448680, £644.56
Standard Continental Exchange Injector, part: 1608518380, £491.93
All VAT inclusive.
