Citroen and Peugeot Official Part Number Requests
- Donor 2022
- x 22
Re: Citroen and Peugeot Parts Requests
Great, thank you Marc, it is item number 70 i'm after, i'll contact PSA and order one (might replace the osr one too).
- Donor 2021
- x 93
Hi Marc
Time to sort the front brakes on the xsara picasso.
Part numbers needed for front brake discs & pads for my picasso 03 2.0hdi might As well have there rear shoes plus brake drums too while I'm asking.Thanks in advance.
- x 3393
Ok, here you go:
Front Brakes
Discs (1)
OEM Original, Part: 4249G1, £151.51 (pair)
OEM Cheaper, Part: 1618890480, £58.42 (pair)
Pads
OEM Original, Part: 425475, £81.86
OEM Cheaper, Part: 1617282980, £26.21
Shim Set
Part: 440719, £23.29
Rear Brakes
You have the following options:
OEM Drum only, Part: 424724, £190.73
OEM Shoes Only, Part: 1610091280, £108.28
or
A complete shoe mounting kit (4) that includes shoes and cylinders and the bits as identified:
OEM Part: 1610091380, £215.38
OEN Cheaper Kit Part: E170042, £66.50
Front Brakes
Discs (1)
Pads
Shim Set
Rear Brakes
or
- Donor 2021
- x 93
Thanks Marc , im all sorted now , thank you.
- Donor 2022
- x 80
Marc,
Looking for part no’s for rear discs and pads for my C5x7
Vin no VF7**************[VIN obfuscated, can be read by forum staff]
Kenny
Kenny
- x 3393
Here you go Kenny:
(1) OEM Genuine Disks Kit Pro, part: 4549C1, £109.25
OEM Cheaper Alternative, part: 1618861880, £59.00
(2) OEM Pads, Part: 425405, £92.10
- Donor 2022
- x 80
Thanks Marc
- Donor 2021
Hi Marc
After part numbers for the DPF please, also wondered if just the bottom of mine comes off or is it a complete unit as one.
Diesel particular filter for 207 1.4 hdi please
- x 3393
@207Peugeot14: Here you go. The DPF element is separate and as you can see from the diagram is clamped on with the kit item (19), which I have included in case you need one of these in case it is rusted.
Particle Filter, item (11):
OEM Original Part: 9677468180 £913.06
OEM Alternative Exchange Part: 1606857180 £619.40
Exhaust Kit for DPF, Part: 1606644780, £68.48
All direct from Peugeot including VAT, prices as of today.
- x 3393
@Moizeaux
C4 Petrol
Pete, as per your post in your other thread:
Air Filter
OEM Part: 1444VW, £30.35
OEM Cheaper Alternative, Part: E147177, £8.45
Oil Filter
OEM Part: 1109AL (Purflux), £14.48
OEM Cheaper: E149134, £6.76
Fuel Filter (shown as not fitted for this vehicle)
Pollen Filter
OEM part: 647975, £42.65
OEM Cheaper Alternative, Part: E146177, £
OEM Premium Anti Allergen Filter, Part: 647941, £17.50
Timing Belt Kit
Belt, Water Pump, Timing Tensioner and Retractor Roller
OEM Original Kit Part: 1609525280, £192.07
OEM Cheaper Kit, Part: 1609120680, £135.48
Spark Plugs
OEM Original (Bosch) Part: 5960F3, £12.49
OEM Alternative, Part: 1625935580, £6.00
Coil Pack
OEM Part: 597098, £147.91
C4 Petrol
Air Filter
Oil Filter
Pollen Filter
Timing Belt Kit
Spark Plugs
Coil Pack
- Donor 2022
- x 181
Thanks Marc.
Could you confirm the aux belt kit please?
1611279280
You've given me numbers for a coil pack. Is this a recommended service item?
Thanks again
1611279280
Thanks again
- x 3393
Here you go Pete, sorry I missed of the Alternator parts you wanted.
Alternator Tensioner Roller (6) Part: 1611425380, £122.22
OEM Drive Belt (20) Part: 5750 XG, £32.80
Alternative Approved Cheaper Belt, Part: 1612162780, £13.94
As for 1611279280 - No such part listed for this vehicle.
- Donor 2022
- x 181
Thanks Marc, much appreciated
- Donor 2022
- x 2398
Marc, could you please confirm which type of eolys system, bag or tank, and fluid I need for my C4 Picasso on maintenance fleet. The VIN is VF7**************[VIN obfuscated, can be read by forum staff] which I believe you already have?
Cheers
Mick
Cheers
Mick
- x 3393
You have a tank reservoir variant, so no pouch Mick.
With a build date of 12495, that means you need Powerflex Additive.
Incidentally Mick - are you aware there is still a recall (aftermarket campaign) outstanding on this vehicle?
If not, give Citroen a ring and get it booked in. I can't tell you what it's for, but it will be F.O.C.
