tearing hair out
Donor 2023
x 19
Unread post by tearing hair out »
Thanks - I wasn't sure if the extra strength (and less stretch) meant that it needed the extra torque to hold. If not, I'll just get the 12.9 spec ones and be done with it!
Paul
I would have more Citroens if I had the space...
Expertamateur
x 5
Unread post by Expertamateur »
RichardW wrote: 02 Jan 2025, 20:37
Expertamateur wrote: 02 Jan 2025, 16:32 307cc door handle problem. The driver's side door handle keeps triggering the electric window to go up and down about half an inch. I understand it is designed to do this to clear the weatherseal at the top when opening/closing the door but the sensor in the handle seems to do it randomly while I'm driving along. I am guessing that other models of 307 don't have this sensor in the handle so just buying another handle won't cure the problem. Anyone know what the part number might be for the sensor? VIN: VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
"The Door Handle (part) that contains the sensor is the same for both sides." according to GiveMeABreak.
The door handles are part no 9101X2, and the diagram shows them with connectors on:
They are £216.59 each - plus painting!
Other variants of the 307 show handles without connectors. They seem to be 307 only, so 2nd hand ones might be scarce.
Thanks for that.
Absolutely hate modern cars and being ripped off by garages that play parts roulette.
Expertamateur
x 5
Paul-R wrote: 02 Jan 2025, 20:47 If the door handles are not handed, and you seldom use the passenger door, could you possibly swap them over with the faulty sensor disconnected?
That is and option to consider. Thanks.
Micko
Unread post by Micko »
RichardW wrote: 29 Dec 2024, 10:58
Micko wrote: 28 Dec 2024, 23:22 Can i please get the parts numbers for
Right side driveshaft
Left side driveshaft
Right side driveshaft seal
Left side driveshaft seal
The car i a 2016 c4 Grand picasso 2.0 bluehdi with aet6 gearbox. Lefthand drive.
Vin number is
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Prices quoted are for UK dealers, inc VAT at 20%.
Driveshafts:
Left:
98054895280 (new) £536.23
1609610280 (exchange) £321.95
Right
98054895180 (new) £536.23
1609609280 (exchange) £339.84
New shafts and the Left exchange one carry a £72 each surcharge for return of the old item. No charge on the Right exchange - they obviously don't want that back!
Seals
Left - 312157 £28.57
Right - 312163 £28.28
The diagram gives the sizes of these seals.
Oil - 9734R7 - £64.61 (probably per litre. Listed as JWS 3324)
Kan i get the parts number for the right and left cv joint.
x 1198
Citroen don't supply them separately, but there are likely to be aftermarket options.
x 1198
GORAX wrote: 03 Jan 2025, 11:26 Hi,
I would like to know the part number for a new fuel filter and where exactly it is in the vehicle.
Thanks!
It's hidden under a cover, front RH side (LH as you look at it) of the engine:
Filter element part no 9801366680 £51.49 / cheaper part for older cars 1643624980 £17.33. Quality filters will be available much cheaper than this aftermarket!!
kevmax1uk
x 5
Unread post by kevmax1uk »
Hi, Please can I have the correct battery details for my car I think GSF tried to sell me the wrong one which is 70Ah CCA 650 and not sure if mine should be a start stop even though it’s hybrid. My vin number is VF7**************[VIN obfuscated, can be read by forum staff] and many thanks in advance
umut
Donor 2023
Unread post by umut »
Hello!!!
Does anyone know the o-ring size or part number for the part: 9801000980, its the one, Air intake Pipe/hose that goes in to turbo for Citroen c4 Grand Picasso:
C4 PICASSO / C4 SPACETOURER (B78) ESTATE - LEISURE 1.6 HDi 120 PEF (DV6FC) AUTO GBOX 6-SPEED STT
Thanks in advance
Umut
x 1198
kevmax1uk wrote: 04 Jan 2025, 18:03 Hi, Please can I have the correct battery details for my car I think GSF tried to sell me the wrong one which is 70Ah CCA 650 and not sure if mine should be a start stop even though it’s hybrid. My vin number is VF7**************[VIN obfuscated, can be read by forum staff] and many thanks in advance
It just says Battery L3 800 which is not that helpful, but does quote part number of 5600 TC (superseeded by 1638948680)
x 1198
umut wrote: 04 Jan 2025, 18:56 Hello!!!
Thanks in advance
Umut
The O-ring is not listed separately:
The complete hose is £49.66
It's not shown on the Turbo page either
kevmax1uk
x 5
RichardW wrote: 04 Jan 2025, 21:44
kevmax1uk wrote: 04 Jan 2025, 18:03 Hi, Please can I have the correct battery details for my car I think GSF tried to sell me the wrong one which is 70Ah CCA 650 and not sure if mine should be a start stop even though it’s hybrid. My vin number is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] and many thanks in advance
Thanks the code 1638848680 is giving me the 70Ah and CCA 760 which I think is the correct one. Thank you
sar77
Unread post by sar77 »
GiveMeABreak wrote: 28 Dec 2024, 11:15
sar77 wrote: 22 Dec 2024, 21:38 Hello
2014 Citroen C4 Picasso blueHdi 2.0 110 kW (diesel), VIN: VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].
Can I get vehicle factory build sheet.
Thank you in advance.
Hi
Please check your private messages, I'll provide your build sheet there in a few minutes. :wink:
Hi Marc, Happy New Year!
I didn't receive your PM message. Maybe as a newbie to this forum I did something wrong with the PM settings. Please repeat if possible.
Sarunas
Together we can do more
x 6664
Hi Sarunas, no problem, please check your PMs.
GavinPJ
Donor 2023
Unread post by GavinPJ »
Hi guys, looking for the part number for the EGR cooler for FL036205.
Thanks,
Gav.
x 6664
(1) OEM Emission Control Module, part: 9807593080, £937.92
Standard Exchange Module, part: 1679828280, £443.45
(2) Exhaust Gas Water Exchanger, part: 9820966280, £410.42
