x 1198
trollkarlen wrote: 04 Dec 2024, 21:58 Hi all!
Can i get the part no, price and image for wire harness (communication can and flex bus not high voltage) that connects to the rear electric engine. It goes over the gas tank and then down to connects to the rear engine.
Thx in advance
It might be item 2 in this diagram? There is a separate diagram for the HV cables, but no control cables on it.
9834893580 - £409.28
oli3442
Unread post by oli3442 »
Hi, would I be able to have part no and diagram for the rocker cover and CCV valve if you have it?
Excessive oil consumption, turbo replaced under warranty but no change. Thought I might investigate this before any further work. Thanks!
trollkarlen
Unread post by trollkarlen »
RichardW wrote: 05 Dec 2024, 09:21
VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Thx in advance
Could i get partno and price for the bands holding the tankup also ?
x 5163
Not at all sure of this.
Daughter's C3 has had a flat battery twice this week, have it charging now again
It is highly likely that the battery is buggered and I expect to replace it.
Unfortunately there is no useful info on the battery:
That's it, nothing anywhere else. Probably not the original battery of course, dimensions not quite the same, a bit shorter than the sizes they give.
245x175x185 mm as oppose to 278x175x190 mm.
The green light on the battery is unlit.
According to Tayna:
Manufacturer: CITROEN
Model: C3 HDI AIRDREAM PLUS
Year: 2011
Fuel: DIESEL
096 AGM Stop Start Car Battery 12V 70Ah
Also can't be sure of Tayna's advice, drawn from the registration number.
Would love to know if their info is correct before buying, I suspect it is not stop/start capable and doesn't need an AGM battery capable of that.
If it does have stop/start it has never worked.
x 1198
oli3442 wrote: 06 Dec 2024, 08:52 Hi, would I be able to have part no and diagram for the rocker cover and CCV valve if you have it?
PCV and upper rocker cover comes complete:
9848586380 @ £254.50
The hose item 6 (which may have a heater in it) is 9674810880 is £103.75
x 1198
trollkarlen wrote: 06 Dec 2024, 12:27
Assume you mean the fuel tank:
Item 10 - Part number 9829671180 - £77.95
x 1198
It says without Stop Start, Steve. Battery is listed as L2D 540 CCA 60 AH - doesn't give a size. Yuasa lookup comes up with an 027 battery which is the first dimensions you have stated (I assume what's fitted?). 096 will no doubt fit, and has slightly more reserve capacity (at slightly more price no doubt!)
x 5163
excellent, thanks Richard.
As Marc has said many times, the databases of independent/aftermarket suppliers are often suspect and unreliable.
Donor 2023
x 1466
Unread post by Paul-R »
I'm getting a P20E8 00 error on the 308 which I've been clearing for a little while now by re-initialising the Denox system. However the interval between resettings is becoming increasingly shorter. As a new Adblue tank was only fitted four years ago I'm hoping that it's the Adblue injector at fault. Could I have the part number please? Also, the replacement procedure if I may ask for that here.
"Trying is the first step towards failure" ~ Homer J Simpson​
Donor 2023
x 1466
myglaren wrote: 06 Dec 2024, 14:39As Marc has said many times, the databases of independent/aftermarket suppliers are often suspect and unreliable.
Ha! Marc says invariably which is probably over the top. But they aren't as good as the PSA one for sure.
x 6664
(25) Catalytic Fluid Injector, part: 9802763880, £208.31
I don't have the procedure for this vehicle , sorry.
x 5163
Rechecked the dimensions and refined them, only a few mm difference but finding a suitable one is proving difficult.
If only the label on the old battery was of more use.
I doubt that an 027 would fit. It is a very tight fit on the width, difficult to get out and back.
Not made any easier by having an ECU crammed down the side, where the retaining gizmo is, and having a battery cover trapped under the brake fluid reservoir and a distribution thingy clipped onto it.
Spiderweb of wires all over the place.
Found a couple of Varta ones that should do. Was hoping to get a Yuasa from Tayna but not having much luck with that.
x 1198
027 and 096 are the same width / height. 096 is about 35mm longer.
x 5163
Found one from Tayna at last.
A lot less that the Amazon price but they list it as a leisure battery, probably why it was so well hidden.
Or perhaps it is :(
x 5163
Scratch that, probably not up to the job.
The Amazon one is actually from ECP, so there's another worry.
