- x 6
Hi, Marc! My van injector seals are leaking and I can smell the fumes in the cab. Please can you provide the part numbers.
VIN VF3**************[VIN obfuscated, can be read by forum staff]. Thanks.
- x 1198
Appears to be available separately; although maybe the pin is worn?Huskyxantia wrote: 30 Nov 2024, 18:13 VF7**************[VIN obfuscated, can be read by forum staff] hi marc im back again need the part number for clutch pedal . Is it clutch & break pedal box ? My mechanic has found the problem why mine keeps killing master cylinders. Thanks marc.
Pedal itself is £99.04
- x 1198
The copper washers (9) are £5.06 and the top seal (8) are £1.85cs101 wrote: 30 Nov 2024, 19:36 Hi, Marc! My van injector seals are leaking and I can smell the fumes in the cab. Please can you provide the part numbers.
- Donor 2023
- x 1466
That's surely for a packet? Hopefully of 10 but probably less.
- x 508
is there a part number for the pin & what look like bushes ?RichardW wrote: 30 Nov 2024, 19:53Appears to be available separately; although maybe the pin is worn?Huskyxantia wrote: 30 Nov 2024, 18:13 VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] hi marc im back again need the part number for clutch pedal . Is it clutch & break pedal box ? My mechanic has found the problem why mine keeps killing master cylinders. Thanks marc.
Husky. Thinking outside of the box is better than sitting in a dark one.
- x 1198
No, the price is per item, but they often make you buy multiples (of more than you need - I had to buy 2 crank pulley bolts for a 1.6 HDi. Cos you always need more than of those )
- x 1198
The bushes (8) are on that diagram - 450330 @ 8.38 each. The pivot bolt (74) is 6925F6 @ £4.01. Says it's M8x1.25mm thread x 90mm. The brake pedal diagram shows a bolt with the same part number, I assume it's a common bolt for the both.Huskyxantia wrote: 30 Nov 2024, 21:23is there a part number for the pin & what look like bushes ?RichardW wrote: 30 Nov 2024, 19:53Appears to be available separately; although maybe the pin is worn?Huskyxantia wrote: 30 Nov 2024, 18:13 VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] hi marc im back again need the part number for clutch pedal . Is it clutch & break pedal box ? My mechanic has found the problem why mine keeps killing master cylinders. Thanks marc.
- x 6664
No, pack of 4
Hi what is the part number of the tailgate rear light cluster? Is it possible to add LED lights (I have the model with halogen lights and therefore it does not light up)
Ds3 Crossback Puretech 130 Automatic Performance Line 2021
- Donor 2023
- x 8
Thanks Marc, I thought it was one piece and included the part across the top of the door also, obviously not the case.
Can I have the number of the upper section too please.
- x 6664
@Dunkah:
This?
(5) Door Entry Seal, part: 9025CN, £130.66
This?
- x 6664
No, these are totally different units and are not interchangeable. Never try and replace halogen bulbs with LEDs - it's illegal as LED bulbs are not approved for use in halogen lamp housings and can blinding for rear drivers (apart from invalidating your insurance if you cause an accident as a result). The LED approved housing units generally have non-replaceable LED bulbs, so it's a new unit if these go.GIOCAR99 wrote: 01 Dec 2024, 16:45 Hi what is the part number of the tailgate rear light cluster? Is it possible to add LED lights (I have the model with halogen lights and therefore it does not light up)
(4) Left Hand Tail Light, part: 9836711380, £173.46
Hello Marc,
Could you possibly obtain the part numbers for the front and rear brake discs and pads for my Citroen C4 grand picasso, as I am getting no where with a couple of online brake suppliers and I wish to replace all four sets of discs and pads.
Many thanks.
Many thanks.
- x 6664
Hi
Front Brakes (1) OEM Original 2 Front Disks (Kit), part: 1647883280, £245.59
(4) OEM Original Set of Front Pads, part: 1647873580, £124.55
PSA Cheaper Alternative Front pads, part: 1619791080, £58.33
Rear Brakes (1) OEM Original 2 Disk Kit, part: 1609583080, £169.32
PSA Cheaper Alternative Disk Kit, part: 1687772680, £124.44
(2) OEM Genuine Rear Brake Pads, part: 1647860380, £111.13
PSA Cheaper Rear Brake Pads, part: 1619791280, £54.80
All direct from Citroen, inc. VAT.
Ok thanks MarcGiveMeABreak wrote: 02 Dec 2024, 00:10No, these are totally different units and are not interchangeable. Never try and replace halogen bulbs with LEDs - it's illegal as LED bulbs are not approved for use in halogen lamp housings and can blinding for rear drivers (apart from invalidating your insurance if you cause an accident as a result). The LED approved housing units generally have non-replaceable LED bulbs, so it's a new unit if these go.GIOCAR99 wrote: 01 Dec 2024, 16:45 Hi what is the part number of the tailgate rear light cluster? Is it possible to add LED lights (I have the model with halogen lights and therefore it does not light up)
