Please can you give the part number of the missing inner liner (Front Driver side) for my van as in picture.
My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
Citroen and Peugeot Official Part Number Requests
- Donor 2021
Re: Citroen and Peugeot Parts Requests
Reason: Corrected Image Tags
- x 3393
Sure, here you go, item (10), part: 9808363380, price £131.81 inc. VAT from Peugeot.
If it's another part of the trim you need, then let me have the item number from the diagram.
- Donor 2021
- x 1652
I would pay a visit to your local scrapyard. I had to get an arch liner, and Citroen wanted £85 for a new one. My local scrappy had one (intact with all of the fixing points) for £15.
- Donor 2021
Thanks Marc. Will also look at the scrapyard, Hell Razor5543, thanks.
- Donor 2021
Peugeot dealer does not have in stock. Only small piece is missing as in above picture. Any ideas for modification or other model which can fit in the place, please?
- x 3393
I'm not sure which 'small' piece you are referring to - the liner is quite a large piece.
You'll find that most spares, apart from service items are order-in only now in common with lots of suppliers. It depends on whether they have to order them in from France or they have some stock in the supply chain storage. I was recently waiting for a rear wheel arch trim and the first 3 were damaged on arrival - all from France. Finally got the fourth one undamaged, but all came in from France - about 5-7 days for each order.
- Donor 2021
Marc, if you look at the picture the section where u can see the intercooler, went missing after my van intercooler was damaged. All the other part of the arch liner is intact. From this hollow section all the dirt goes into the engine from the front wheel.
- Donor 2021
- x 3393
Hard to see if that hole is from the arch trim or one of the other bits (3) or (9). Probably have to compare with the other side to confirm which it is, but anyway if you need the part number if any of the other items, let me know.
- Donor 2021
https://www.ebay.co.uk/itm/GENUINE-PEUG ... 635-2958-0
Is this the right item to purchase from EBay? Thanks .
- x 3393
Yes, that cross references with the part number I gave you if you scroll down to the details.
- Donor 2021
- x 5
Hi Marc
I have three fault codes for parking sensors rear and front.
Is the sensor same in all positions for VIN VF7**************[VIN obfuscated, can be read by forum staff]?
Also - I gave fault code 4AC5 - short to plus on the third brake light.
- x 3393
Hi, yes they are all the same. The only difference is whether you want the black plastic (un-primed) or the primed versions, but same for front and back.
Black, Part: 1611735580 £140.95 each.
Primed Ready for Painting, Part: 1611735680, £140.81 each.
Prices UK sterling inc. our VAT @ 20%
- Donor 2022
- x 22
Hi Marc, could you please get me the part number for the little bolt that holds the nearside rear abs sensor in place. I have a suspicion it might only come with the sensor but with the bolt being seized in it might be as well for me to get a sensor as well.
VF3**************[VIN obfuscated, can be read by forum staff] & has Lucas brakes on it.
Thank you.
Thank you.
- x 3393
Sure, here you go:
If it's item (70), then it is an (MUL) CHC R D L SCREW, part: 6913J1 (DIAM 6X100-20), priced £1.90 each from Citroen / Peugeot
