- x 6664
Parts thread now open for requests, although there may be some further disruptions.
Please could I get a part no. for the BPGA on a 2017 DS5?
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Symptoms are as per this thread: viewtopic.php?t=73480 which gives part no. 9666851480, but for an older car, so just wanting to check.
- x 1198
- x 30
Hi
Can I get the part number for a High Pressure Fuel Pump for my 2009 C5 X7 2.0 Hdi 138 Auto please?
Steve
Steve
- x 6664
Here you go:
(1) New OEM Delphi Roissy High Pressure Pump, part: 1920LP, £1832.23
Standard Exchange HPP Delphi Roissy, part: 1921N3, £975.43
- x 239
Hi Marc,
can you give me a part number for the clock spring Comms unit for my 508 the air bag squib is showing high resistance.
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Darren
- x 6664
(1) Multifunction Control Unit, part: 98199434ZD, £602.26
Could I please have the part numbers for the engine ECU and BSI.
Many thanks in advance!
- x 1705
Good afternoon
Could you tell me the price for a bottom ball joint heat shield for the grey 308?
eBay seems to suggest 3623 13 could be the correct item. eBay also £17.99 each!? Autodoc has them listed to but out of stock (£4-£6 if they do come back in stock)
A pretty crusty mess of what's left of the two on this car!
Thanks as always!
Thanks as always!
- x 239
- x 6664
Here you are MattMattBLancs wrote: 18 Oct 2024, 15:56 Good afternoon
Thanks as always!
(6) Ball Joint Protector, part: 362313, £6.05
- x 4
Hello
What is the OE part numbers for the front and rear breaking system (discs and pads) for a Citroen Picasso c4 (5 sitter) , 2018, 1.6 petrol with the vin number VF7**************[VIN obfuscated, can be read by forum staff]
Thx
Thx
- x 1705
Spot on, thank you!
- x 6664
Parts Request Service Back Up (for now anyway )
- x 254
Hi Marc
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Handbrake cable Part No and length if listed for my Xantia OSF please?
I'm guessing it's 1330mm for OSF
Cheers
Cheers
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
Gone
