x 1122
Daibach wrote: 20 Aug 2024, 19:36 Hi Marc, could you provide part no. for radiator fan relay for my C4 please. Fan does not fire up at all, so I'm guessing that's what I need. The fan spins freely, so is there any easy way I can get power to it to check out the motor? My vin is VF7**************[VIN obfuscated, can be read by forum staff]. Thanks once again.
Fan is £222.14 / Controller £87.18.
It should be possible to unplug the fan and apply 12V direct to it to see if it will spin - corrosion of the relay controller is not unknown.
Daibach
x 4
Unread post by Daibach »
Thanks Richard.
trollkarlen
Unread post by trollkarlen »
I need the part number and the viewing of the clips/fastening of the outside wheel arch on the left side.
Thx in advance
x 1122
trollkarlen wrote: 21 Aug 2024, 21:37 I need the part number and the viewing of the clips/fastening of the outside wheel arch on the left side.
Thx in advance
Item 16 and 90 in this page:
Part number for the clip is 6991Z1, and they are £0.88 in the UK. trim is £163.50
Note, there is a recall on this vehicle, to replace the hybrid battery!
An after-sales campaign must be carried out on this vehicle. Advise your client to make an appointment with their authorised dealer as soon as possible
Safety, Emission or Compliance Recall Reference Launch Date Status
MQE - 3008 (P84), 508 (R8) - Traction battery
Replace the traction battery. Return the traction battery following the below described return procedure.
MQE
07/06/2024
Incomplete
PDF Not Available
x 6398
Friendly reminder to please only post your parts requests on this thread - anything else, please use the technical forums.
dulenator
x 9
Unread post by dulenator »
I'm sorry for being a pain in the bu... neck.
I need a part number for the upper oil return tube (I think that's what it's called). I found 1192WH, which seems to be the correct part, at least visually.
x 6398
No problem, yes, that's correct:
(4) Oil Vapour Hose, part: 1192WH, £30.96
dulenator
x 9
Thank you! Off to buy one!
MixerFistit
Donor 2023
x 12
Unread post by MixerFistit »
Could I please have info on the upper exhaust clamp for my 1.6 hdi (turbo to cat/dpf)
ECP have a klarius 66mm for a little over a fiver but doesn't clarify if it's the upper or lower clamp.
https://www.eurocarparts.com/p/klarius- ... -712545581
I suppose, part number aside, I only really need the diameter (mm) and whether to use sealant or not.
I did find this post from Marc viewtopic.php?t=66402 but doesn't say the diameter and searching for 171360 comes up with various diameters. Also I guess it's possible the diameters aren't the same for different vins, turbos, dpf or not etc.
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
x 1122
Parts diagram says part no 171360 and dia 64.5mm (£15.84). The one at the bottom is 171366 and 66mm (£11.99). No sealant, just make sure the cat is lifted up and pushed right onto the turbo before you do it up. These are also MUCH easier to fit (and remove) if you have the proper pliers!
MixerFistit
Donor 2023
x 12
Thank you Richard
RichardW wrote: 24 Aug 2024, 12:20 These are also MUCH easier to fit (and remove) if you have the proper pliers!
Don't I know it, its why I need a new one #-o
Sold/dead
1x mk2 C4 Pic
x 6398
Let me know which item numbers you require part numbers for.
DaveS
Unread post by DaveS »
Could I please have part numbers for:
Top mounts
Dampers
lower arms
VIN is VF3**************[VIN obfuscated, can be read by forum staff]
Is it also possible to get the RPO code for SB from the VIN, and is this the correct place to ask for it?
Thanks! :)
x 1122
Dave - assume you want part numbers for the front? We can look up the RP number for that VIN at the same time - what's SB though?
x 6398
Please ask for specific part numbers that you require for your own vehicles to avoid confusion Roger, thanks.
Yes Freecor is the coolant used now by PSA vehicles
