Thanx for a super serviceGiveMeABreak wrote: ↑04 Aug 2024, 23:33
(2) Number Plate Lamp, part: 9815226680, £20.36
(10) Bulb, part: 6216A1, £2.16
I need to check but i think its LED on my car but maybe its after market lights.
I took them out and they where LED but they look original, had a Peugeot stamp on the back and everything. Can it be different configurations?GiveMeABreak wrote: ↑05 Aug 2024, 05:42 Yes, someone has changed them for LEDs, the above are original bulbs.
Hehe, I interpreted the image/parts exactly the same as youGiveMeABreak wrote: ↑05 Aug 2024, 21:37 @trollkarlen: Don't panic, there are 2 types of units, one with a holder and conventional bulbs and the second one (2) that is a combined unit with LED that has to be changed as a whole.
So the part number is correct as I provided in the last post with the diagram, just ignore the bulbs as they are only relevant for the holder type (1).
Sorry about the confusion - I didn't see the (1) on the diagram for the other type and assumed the bulbs were for type 2 holder!
I think you posted in the announcements section (which I thought a bit odd), so I will remove that post.mickthemaverick wrote: ↑07 Aug 2024, 00:30 Evening all,
I am considering retrofitting a rev counter to the C4. Could you determine whether the wiring loom has a connector for it and if tthis is the correct display: https://www.ebay.co.uk/itm/364760299335 ... media=COPY
If not could I have the part number for the correct display for a tacho. Thanks as always.
