- x 1122
High and low use the same valve seemingly:
£37.10 each from Citroen.
- x 6
Hi. Vin. VF7**************[VIN obfuscated, can be read by forum staff]
A number request please for a suspension fluid pipe, offside rear.
And a power steering pipe/hose. Nearside front. (To oil cooler).
The brackets are as printed on my MOT cert today.
But at least my front shock hasn't failed yet!
Thanks very much.
Thanks very much.
- x 3
Hi, could I get the parts number for the oil filter, and air filter, on a MK1 Peugeot 3008 (1.6 eHDi 2014) please?
- x 4
Hi Marc, Can you help with part no. for aircon compressor for my C4. I think you have the VIN no. on file, but I don't know how long you keep them. Also can you advise if this compressor has a clutch or is clutchless please ( I hope the latter cos I can't hear a click when I switch on aircon. Thanks once again ( or Diolch if you prefer)
- x 21
Please could you check the part number for Turbo Value Solenoid for VF7**************[VIN obfuscated, can be read by forum staff]
I'm seeing part number 1618PE but want to check if it's correct or been superceded.
- x 1122
Suspension pipe - No 6?
PAS pipe - No 2?
Both are NFP. They were £26.52 and £97.13 respectively when they were available.
- x 1122
Oil filter originally 1109Z5 now 1109 AY @ £18.54NorfolkVroom wrote: ↑12 Jul 2024, 17:38 Hi, could I get the parts number for the oil filter, and air filter, on a MK1 Peugeot 3008 (1.6 eHDi 2014) please?
VIN:
Air filter 1444TV @ £35.74
- x 1122
If you post the VIN I will check.Daibach wrote: ↑12 Jul 2024, 20:48 Hi Marc, Can you help with part no. for aircon compressor for my C4. I think you have the VIN no. on file, but I don't know how long you keep them. Also can you advise if this compressor has a clutch or is clutchless please ( I hope the latter cos I can't hear a click when I switch on aircon. Thanks once again ( or Diolch if you prefer)
- x 1122
1618PE is right, no replacement part no.danlat1415 wrote: ↑12 Jul 2024, 21:21 Please could you check the part number for Turbo Value Solenoid for
- x 4
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6398
(1) New OEM Denso Compressor (DENSO THERM SYS 5SEL12), part: 9822101380, £ 1070.30Daibach wrote: ↑12 Jul 2024, 20:48 Hi Marc, Can you help with part no. for aircon compressor for my C4. I think you have the VIN no. on file, but I don't know how long you keep them. Also can you advise if this compressor has a clutch or is clutchless please ( I hope the latter cos I can't hear a click when I switch on aircon. Thanks once again ( or Diolch if you prefer)
Standard Denso Exchange Compressor (DENSO THERM SYS 5SEL12), part: 1622731080, £574.55
Although not specified, I believe this has a magnetic clutch.
(There's a Denso one here: https://www.autodoc.co.uk/denso/11010131 for a lot less).
Hi, me again
Can I please have the part number for the selected rubber hose, plastic flange and its seal? And maybe also the hose that is not present in the photo but attaches to this plastic tee.
The image is from 206 engine, but location is similar/identical. Thanks
Hi Guys.
Part number for my catalytic converter please
Reuben
Reuben
- x 6398
You'll have to let me know if what you want is on any of the following, let me know the Diagram (A or B) and the item number.jakuboz wrote: ↑15 Jul 2024, 09:52 Hi, me again
Diag A Air Intake Manifold Diag B Cooling Hoses
- x 6398
(11) Catalytic Converter:
OEM Original, part: 9800523680, £1328.68
PSA Cheaper Option, part: 1609435180, £1024.22
