- x 246
Citroen C5 X7 steering rack identification. Please
Back in 2017 I had to replace my steering rack - three times 1st, the rack was stiff - apparently the reconditioning company used a different seal assembly, that was replaced with one that I could not get 'tracked' one track road end was holding on by about 1" on thread whereas the other was fully on! Eventually I got a refund and told to keep the 2nd rack.
I plan on selling the 2nd reconditioned non trackable rack, so what do I have?
Numbers on the rack are 7832.501.318 / 9506.7
It may have just been reassembled wrong an may even be my original rack as it took me a month to get it swapped.
Stu
- x 6373
None of those are official part numbers Stu, so can't help in this thread.
- x 6373
(1) Bare Hydraulic Reservoir, part: 96110023, (No Longer Available), £114 new when available.citroenroen wrote: ↑12 Jun 2024, 23:57 May I have part number for Xantia LHM Reservoir / expansion tank ?
VIN# for my car: VFX14D00004D1075
Is there is ONLY ONE reservoir for ALL Xantias? or are these varaiations ? If there are variations , what are the differences?
I have done the membership upgrade as requested previously.
"We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data "
- Donor 2023
- x 6
Good evening, hope you are well.
Looking for part numbers and pricing for the full exhaust system from the DPF onwards. Including the hangers screws/bolts etc. It sounds like a bloody tractor right now.
Many thanks.
Many thanks.
- x 6373
(2) Exhaust System Heat Shield, part: 1723JX, £59.40
(70) Flanged Nut, part: 1611567380, £1.21
(10) Catalytic Converter (TR OSA K683, Markings (K632), (K681), part: 9808330080, £1149.15
(11) Octo Square Particle Filter:
Options:
OEM New, part (TR PSA F026): 9803421880, £1183.94
Standard Exchange OEM Particle Filter (TR PSA F026), part: 1609532780, £764.48
Cheaper PSA Alternative Particle Filter, part: 1697077680, £516.92
(12) Fixing Clamp, part: 171360, £16.73
(13) Fixing Clamp, part: 171366, £11.99
(14) Flanged Nut, part: 9828646780, £1.99
(15) Exhaust Pipe Bracket, part: 9808547380, £41.58
(18) Exhaust Pipe Bracket, part: 1714R4, £10.73
(19)Exhaust Bracket Seal, part: 1606666580, £35.64
(20) Turbo Support Stud, part: 171845, £1.26
(21) Exhaust Front Pipe, part: 9673664580, £229.49
(71) TH Screw & Washer, part: 692395, £1.46
(1) Rear Silencer, part: 1609044180, £593.42
(2) Exhaust System Fixing Clamp, part: 171353, £10.93
(3) Exhaust Intermediate Pipe, part: 1609044080, £624.95
(5) Exhaust Rear Support, part: 9674325480, £58.51
(6) (Removed for your build date) N/A
(7) Exhaust Flexible Mounting, part: 9674325180, £18.71
(8) Exhaust Front Pipe Sleeve, part: 173632, £88.39
(10) Bolt, part: 9809840080, £0.48
(70) Flanged Nut, part: 6936C9, £1.21
- Donor 2023
- x 6
I think I'm going to attempt repair.
Evening!
Could I please get part numbers for discs/pads front and rear, as well as part numbers for the parking brake shoes/springs/cables.
Service Box is giving me multiple part numbers for discs (differing payloads) and the handbrake cables due to different track widths. Knowing my luck id order the wrong ones
Thanks in advance!
Thanks in advance!
- x 6373
Front Brakes
(1) OEM Original Brake Disc, part: 1612435180, £151.52 each
Peugeot Cheaper Brake Disc, part: 1687772280, £78.13 each
(3) Brake Pad Kit (A, B, C, D, E & F), part: 1647863980, £201.23
Peugeot Cheaper Set, part: 1639374380, £60.20
Rear Brakes
(1) OEM Non-Ventilated Disc (DIAM 280 EP 16), part: 1673602180, £117.05
Cheaper Peugeot alternative Disc, part: 1686717480, £117.08 (2)
(3) Disc Pad Kit
OEM, part: 1673603480, £124.01
Cheaper Peugeot Alternative Kit, part: 1675989880, £53.38
Parking Brake Bits
If there's anything you want that I haven't provided, let me know:
(3) Secondary Parking Cable, part: 1680794480, £220.76
(4) OEM Secondary Brake Cable, part: 1673595680, £81.68
Peugeot Cheaper cable, part: E074180, £40.00
(12) Secondary Brake Cable Guide, part: 1669575080, £8.56
(13) Handbrake Return Spring, part: 476807, £6.19
(18) Set of 4 Rear Shoes:
OEM, part: 4241N5, £296.04
Cheaper Version, part: 1690924180, £ (Price Unavailable)
(19) Handbrake Mechanism Kit, part: 43108, £120.13
(20) Handbrake Mechanism, part: 434112, £128.71
(21) Handbrake Mechanism Support, part: 433208, £281.77
(22) Brake Shoe Spring Set, part: 430871, £61.52
(23) Brake Shoes Retaining Assembly, part: 430872, £18.56
(24) RR Brake Backplate Fixing Bolt, part: 440610, £2.68
(25) Brake Caliper Fixing Washer part: 440808, £0.76
(26) Brake Caliper Fixing Screw, part: 440542, £7.07
Rear Brakes
(3) Disc Pad Kit
Parking Brake Bits
Cheers Marc!
Always appreciate the effort and time it must take to provide this service.
- Donor 2023
Hallo!
After a steep hill climb earlier this year, not only did a already weakened heater pipe blow open on my C5 X7, a wheel fastener (??) came loose:
I don't know the name for this, but hope the pictures will show it. This part is on the front, left side. I have circled where it has jumped off, nothing seems broken, but is it possible to jam it together again? If not I would need the whole thing. The VIN number for my car is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6373
Hi
These are your front Anti-Roll Bar Drop Links. No, they cannot be put back together, they need replacing. Be aware that a defective one of these will cause the vehicle to 'dip' inwards when cornering, so get it fixed as soon as possible.
(4) OEM Original Anti Roll Bar Rod, LEFT, part: 508752, £96.98
OEM Original Anti Roll Bar Rod, RIGHT, part: 508753, £96.98
Cheaper Citroen Alternative, LEFT, part: 1634903980, £18.04
Cheaper Citroen Alternative, RIGHT, part: 1634904080, £18.04
- x 6
PART NUMBER OF COMPLETE RADIATOR ASSEMBLY
Please can I have the part number of the complete radiator assembly for my van Peugeot Expert 2018 1.6 Hdi including the grill and fan.
Thanks.
Photo is attached.
Thanks.
Photo is attached.
- x 1119
That's the anti roll bar drop link - you will need to replace it. These are a bit of a pain as the top bolt is the bottom mount for the shock.
They are handed, but both the same price at £96.98. Looks like they come without nuts, top is £7.36 and the bottom £8.92 - which are both frankly ridiculous!!
Edit: Beaten by Marc, but the comment about the nuts stands!
- x 6373
I also included the cheaper Citroen variants in my post
- x 1119
No idea how they can justify a nut being 1/2 the price of the link!
