x 6398
(2) Bumper Frame, part: 7414PQ, £363.28
(3) Bumper Absorber, part: 7422H6, £103.28
(6) Stone Guard Grille (there are 2 possibilities) either:
Black Cornelie, part: 7422C3, £123.25
Lion Grey, part: 7422C5, £156.34
KennyW
x 133
Unread post by KennyW »
Thanks Marc
C3 1.4 petrol (SWMBO)
Dustysweeper
Donor 2023
x 6
Unread post by Dustysweeper »
Good evening. I'm investing whether it is possible to fit a spare wheel on my 2014 GP. I'm seeing loads on Ebay at different prices but I'm not sure which one is right for my car.
Is there a part number for the parts needed for VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
Duncan
x 1122
This is the arrangement of the spare wheel (not yours obviously, since yours came without!)
x 6398
If your vehicle had an SCR system fitted with Adblue Urea tank (which it hasn't), then you may not have had the space for a spare - but you still need to check to make sure all the bits shown can fit.
Sloppysod
x 246
Unread post by Sloppysod »
Hi Marc, I think the Front to Rear pipe has burst, could you please help me out with a part number? Problem Pipe in red
Do you know if it's still available or is one of those discontinued pipes?
Are there any repair kits around, so I just have to repair the back end?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6398
Hi Stu, still available, but get some tissues ready...
(1) Hydraulic Pipe, part: 9807562180, £410.26 :shock:
The 2-way union is also available (5), part: 5280T3, £26.64
Also see Kennys' post here about this same pipe:
viewtopic.php?p=658388#p658388
KennyW
x 133
Marc,
Looking for the part number for item 5 on front bumper diagram for Peugeot 207.
Kenny
x 6398
Kenny:
(5) Stone Guard Grille, either:
Black Cornelie, part: 7422C0, £99.78 or
Lion Grey, part: 7422C2, £159.92
DaveS
Unread post by DaveS »
Hi
Could I please get the part numbers for the glow plugs and its accompanying control module for the VIN VF3**************[VIN obfuscated, can be read by forum staff]
Could you please grab me the engine code also?
Thanks in advance!
x 1122
Dave
Plugs are £38.65 each, control unit £254.47.
It just lists the engine as: ENGINE DIESEL TURBO PUMA C 96 EURO5 130HP
Sloppysod
x 246
GiveMeABreak wrote: 15 Apr 2024, 17:33 Hi Stu, still available, but get some tissues ready...
Hi Marc, Can't find a pipe anywhere, can't even get a pipe made up as the ends are odd, any suggestions where to go next.
I used Rigbys in Preston and they checked all the UK warehouses.
Cheers
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6398
Rhothgar
Donor 2023
x 106
Unread post by Rhothgar »
Afternoon Marc,
I've scoured this thread using certain search as I imagined I'd previously requested part numbers for pads and discs for X435 JGJ previously but couldn't trawl anything up.
Please, when you have a moment, could you let me know the parts numbers for discs and pads all round on X435? Maybe an idea to have a note of the fitting kits too as I feel sure they will be very tired now.
All the best
x 6398
(2) Front Disk Kit Ventilated
OEM, part: 4249H1, £241.10 (for both)
Cheaper, part: 1687775580, £107.96 (each)
(3) OEM Front Pads - NFP
Cheaper Pads. part: 1617280380, £46.28
(2) Rear Discs
OEM - NFP
Cheaper, part: 1618860880, £38.12 (each)
(3) Rear Pads
OEM - NFP
Cheaper, part: 1617255680, £15.50
