- x 6398
Yes each pipe is separate and has a separate part number as they are pre-formed. If you need a specific one or all of them, let me know here.
- x 1639
Good morning, could I have part numbers for the following for the 308 SW,
VIN
- Gearbox output/driveshaft lip seals (both sides) - if any dimensions listed those would be useful too please.
- Gearbox drain plug / washer (again any dimensions would be useful as might seek out a magnetic replacement whilst it's off)
- will have a trawl on here as think I have asked for gearbox oil capacity previously.
- front suspension anti roll bar drop links (think all 308 are the same but just to check)
- track rod ends (just the outer ball joint "ends", not the full rods, hopefully not changing them!)
Thank you no great rush
VIN
- Donor 2023
Hi Marc,
Yes please, I would appreciate the part numbers for all of them.
- x 1122
Jeff
Cyl 1 - 3 (items 2-4) are priced at £16.34, Cyl 4 is £16.55
Note there is an outstanding recall on your car, related to the timing belt, certainly worth following this up with the dealer as you might get a free belt change!
HCJ - Timing belt
The operation involves replacing the timing front face parts.
HCJ - Timing belt
- x 1122
Matt
Drain plug seems to be M16 x 1.5mm thread, but it doesn't give a length.
Thanks for the link, Marc (y)
I don't know if you have access to documents about particle filter type approval OEM 9677016880 (K632 F024), these documents should be StVZO, ABE and KBA if I have understood it correctly?
Also, if there is the same possibility for information, about a specific vehicle from VF3**************[VIN obfuscated, can be read by forum staff] ?
- x 6398
@Sponk: Please read the first post in this thread concerning part numbers
We don't supply technical documents unless we have them already as they are chargeable.
Yes, I have read that, but since you yourself referred to this forum part, I thought it was ok to write it here. But thanks for the answer that you don't have that access (y)GiveMeABreak wrote: ↑26 Mar 2024, 14:12 @Sponk: Please read the first post in this thread concerning part numbers
- x 6398
Yes, because this is the correct thread for official part number requests, but requires a membership upgrade for this service.
- x 1639
- Donor 2023
- x 472
VF7**************[VIN obfuscated, can be read by forum staff] head gasket kit numbers needed , plus thrust bearing . Cheers .
Husky.
- x 1122
There isn't a head set as such, suggest you would need CHG, head bolts, and rocker cover gasket. Upper cam carrier is silicone sealed AFAIK. No of notches will show the thickness, should be no different to that fitted if you are not decking the block.
Release bearing
Release bearing
- x 9
Hi Marc,
Thank you again for offering this excellent service, hugely useful. I have just realised my last donation was in 2022, apologies - have happily donated again this morning.
When you get a chance, could you please share a part number, and ideally the parts schematic picture (prices would be great if you are able) for the following - 2016 DS3 1.6 HDi Prestige 120 (S/S) - VIN VF7**************[VIN obfuscated, can be read by forum staff].
- Main engine undertray, the large plastic piece that helps underfloor aero and provides some basic engine protection.
Martin.
Martin.
Helping my daughter with her first car, a 2016 DS3 Prestige 1.6HDi 120 (S/S) - 160,000 miles.
I have some high mileage german stuff, and a selection of motorbikes.
- x 6398
Hi Martin, thanks for your Forum Donation.
Please see below, if any other items apart from the ones I've listed, let me know.
(1) Soundproofing Under Engine and Gearbox, part: 7013GL, £327.59
(2) Air Deflector Under Engine, part: 9802381980, £167.57
- x 9
Hi Marc,GiveMeABreak wrote: ↑31 Mar 2024, 09:55 Hi Martin, thanks for your Forum Donation.
Wonderful, now I can see a schematic - I can see which parts we actually need.
We need the two parts labelled #5. Not sure if they need to be ordered separately, or come as a set - if you are able, please let me know part number(s) and price(s) for those 2 parts labelled #5.
Many thanks,
Martin.
