x 6397
Always replace in pairs!
(1) rear Shock Absorber, part: 5206VY (may no longer be available), £75.86
Citroen Cheaper alternative, part: 1623316380, £51.07
(3) Flanged Bolt, part: 522312, £1.45
(10) Cage Nut, part: 8530KP, £3.12
(2) Flanged Bolt, part: 522316, £6.11
(4) Cage Nut, part: 522076, £3.73
dylan26__
x 21
Unread post by dylan26__ »
awesome thank you. Whilst we're on the topic of the rear suspension could you also give me the rear bushes for my car pls
x 6397
What are you referring to - the rear hub bearings or the crossmember?
Hub Bearing
Crossmember Mountings
dylan26__
x 21
:rofl2:
GiveMeABreak wrote: 17 Mar 2024, 20:42 What are you referring to - the rear hub bearings or the crossmember?
Hub Bearing
Cross member mountings please. Looks like the bushing can be replaced by itself too?
x 6397
(3) Crossmember Mountings, part: 5131H4, £47.95
(Ignore (1), as that is the complete crossmember, the mountings are (3))
Romtag
x 8
Unread post by Romtag »
Thanks Marc, I need to source an under bumper tray for the front of the car. When scouting eBay it shows two models. Could you work your magic for the part number ?
Mark
Owner of a 2013 308 SW
x 6397
Assuming this is for the 308...
Let me know which item(s) you require.
508Allure
Donor 2023
x 5
Unread post by 508Allure »
Marc, could I get the part number for the eolys tank please:
kuhar
Unread post by kuhar »
Hi Marc,
Seems my Blower Motor Control Module is dead as per this thread viewtopic.php?t=63301 (fan won't stop blowing even when I switch off the car, a/c fans stuck on full), ODB is useless.
Should DENSO DRS21008 (citroen part 9821291880) be the right call?
Thanks!
- Marko
x 6397
508Allure wrote: 19 Mar 2024, 17:30 Marc, could I get the part number for the eolys tank please:
(16) Additive Reservoir, part: 9817154080, £269.64
x 6397
kuhar wrote: 19 Mar 2024, 17:36 Hi Marc,
Thanks!
Yes, that is the correct replacement part.
(3) Heater Motor Control Module, part: 9821291880, £185.27
508Allure
Donor 2023
x 5
GiveMeABreak wrote: 19 Mar 2024, 17:57
VIN: VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Thank you very much.
Romtag
x 8
GiveMeABreak wrote: 19 Mar 2024, 13:33 Assuming this is for the 308...
Its the large plastic tray in the bottom left of image, yes the dadvan has gone to the scrapyard in the sky so that can be removed from your vin database :)
Mark
x 6397
(2) Air Deflector Under Engine, part: 7013EF, £167.57
(70 Screw with washer, part: 692395, £1.46
(74) (MUL) CBLX RDL SCREW, Part: 6295N0 £0.78
dylan26__
x 21
GiveMeABreak wrote: 24 Feb 2024, 19:54
dylan26__ wrote: 24 Feb 2024, 18:12 Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
The Springs are on a separate diagram:
Let me know item numbers
thought my top mount came with them but 3 & 4 i appear to also need. Feel i'm the most active person here on this thread 😂
