x 6398
Front Springs
There are 2 possibilities you can have, so you would need to look at the existing springs for the colour bands to determine which ones you need:
(1) Front Suspension Spring
COLOUR MARK: 1 RED + 1 WHITE + 1 YELLOW, part: 9806878080, £175.98
COLOUR MARK: 1 BLUE + 1 WHITE + 1 YELLOW, Part: 9806762680, £80.53
Rear Springs
(12) rear Suspension Spring
COLOUR MARK: 1 BLUE + 1 WHITE + 1 RED, part: 9810331080, £137.12
Front Damper
(1) Original Front Damper, part: 1628565880, £108.01
(1) Cheaper Front Damper, part: 1635532480, £89.44
Rear Damper
(1) Rear Damper OEM, part: 9817348880, £102.88
perrye
Donor 2023
x 9
Unread post by perrye »
Thanks Marc, very quick again!
dylan26__
x 21
Unread post by dylan26__ »
Think my msg got lost, Can I get the steering rack part number for VF7**************[VIN obfuscated, can be read by forum staff] please
x 6398
Richard already answered it here, (viewtopic.php?p=793072#p793072), but there was no image, so I've gone back and added the diagram for you - note the after sales campaign info, details of which are in my next related post shortly after.
dave101ua
Donor 2023
Unread post by dave101ua »
Hello RichardW,
thank you for the answer
yes my VIN IS VF7**************[VIN obfuscated, can be read by forum staff]
following my request, which is related to my front left wheel where I have strange sounds:
at car service I was also told to replace this:
SATZ FEDERBEINLAGER Vorderachse SKF --> Google translate SET OF SPRING STRUT BEARINGS Front Axis
I think it means both left and right
I hope you know what it means, could you please give me the part number for it?
Thank you!
x 6398
They probably mean something from the pivot / Hub setup. Have a look below and advise us of the item numbers on the diagram for which you need the part numbers:
x 1122
I imagine they mean the bearing mount at the top of the strut ( equivalent to 2 in the diagram a few posts up). However what sort of noise is it making?
Mexico14
Donor 2023
Unread post by Mexico14 »
Could I have the part number for anti roll bar link please?
x 6398
RichardW wrote: 14 Mar 2024, 11:40 I imagine they mean the bearing mount at the top of the strut ( equivalent to 2 in the diagram a few posts up). However what sort of noise is it making?
That's (2) for the rear strut though Richard, so unless it's lost in translation... I can't see any other 'bearing' though.
x 6398
Mexico14 wrote: 14 Mar 2024, 13:17 Could I have the part number for anti roll bar link please?
There's an issue at present with the original and replacement part for the original, so I can't add them and therefore can't provide a price.
The Cheaper Citroen alternative is:
(2) ARB Drop link Cheaper version, Part: 1679755380, £19.78
x 1122
GiveMeABreak wrote: 11 Mar 2024, 16:52 Front Springs
GiveMeABreak wrote: 14 Mar 2024, 14:24
No 2 on the above drawing
Oliver53
Unread post by Oliver53 »
Can I get the part numbers of the input shaft bearings for MLUC gearbox please? VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Thanks!
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
x 6398
(7) Primary Bearing Kit, part: 1611557680, £179.96
Oliver53
GiveMeABreak wrote: 16 Mar 2024, 22:51 Image
Many thanks Marc!
2000 ZX 1.4i
1985 2CV6 Special
dylan26__
x 21
Can I have the rear shock absorbers for VF7**************[VIN obfuscated, can be read by forum staff] please. Also, what are the top mountings like on this? Got an awful clacketing noise coming from my rear right
