x 6405
Yes, these are both the same part numbers for both vehicles.
(6) Wishbone Front:
OEM Original, Left, part: 9666244080, £476.41
OEM Original, Right, part: 9666243980, £484.04
Cheaper Citroen Alternative Left, part: 1682731680, £212.95
Cheaper Citroen Alternative Right, Left, part: 1682731380, £157.31
dylan26__
x 21
Unread post by dylan26__ »
GiveMeABreak wrote: 24 Feb 2024, 19:54
dylan26__ wrote: 24 Feb 2024, 18:12 Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
The Springs are on a separate diagram:
Let me know item numbers
9 please
x 6405
(9) Front Suspension Rest Cup, part: 5033C3, £22.34
dylan26__
x 21
Hey do you have a diagram for the timing belt for VF7**************[VIN obfuscated, can be read by forum staff]
does a kit include waterpump and is it driven by the timing belt ?
x 1124
This is the 1.2 Puretech engine with the wet belt system.
Full timing belt kit
Or alternative just the belt (and other parts as you fancy)
This engine has the water pump driven externally
The full kit is £226.57
x 1643
Unread post by MattBLancs »
Evening all,
308 SW 2011, 1.6 HDi
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could you let me know the part number / type + quantity of additive fluid for the DPF system please?
Is it a sensible tank or silly soft pouch thing and if there's a handy diagram of where it lives: yes please too
Thanks as always,
Matt :)
x 6405
You need Powerflex Additive Matt.
This 308 has a reservoir not a pouch system. You need to add a minimum of 1 litre, but it does not specify capacity. It is usually at the rear left of the vehicle hidden behind a heat shield near the rear exhaust.
x 1643
Thanks Marc :)
x 1643
GiveMeABreak wrote: 28 Feb 2024, 00:22 You need Powerflex Additive Matt.
Thanks, can I ask a follow up question or two:
Is there a part number for the bottle/refill kit (an eBay result suggests it could be 9736A1) ?
And is there a cost listed for it on your system please?
I know the stuff isn't cheap, not sure on how cost from Peugeot direct compares. :)
Thanks,
Matt
x 6405
Any decent brand of Powerflex will do Matt, but if you want the official stuff it will of course cost more:
1Litre 9736A0, £85.01
3 Litre 9736A1. £202.37
playtequ
Unread post by playtequ »
Hi everyone
Vin: VF7**************[VIN obfuscated, can be read by forum staff]
Can I get part number for rear height sensor for hydraulic suspension please? And any place where I can buy it?
Many thanks
Catalin
x 6405
@playtequ
(8) Rear Body Height Sensor, part: 5273J9, £94.88
(10) Angular Pickup Link, part: 527381, £8.09
(11) Anti-Roll Bar Lever, part: 1687269980, £321.41 :shock: :shock:
x 1643
GiveMeABreak wrote: 29 Feb 2024, 16:00 Any decent brand of Powerflex will do Matt, but if you want the official stuff it will of course cost more:
Thanks Marc
(Flipping heck!) :-D
x 6405
This is a good brand Matt:
https://www.ebay.co.uk/itm/264494712412 ... R87n8uK-Yw
£136 inc Postage, 3 litres and kit.
x 1643
GiveMeABreak wrote: 29 Feb 2024, 19:45 This is a good brand Matt:
Thank you Marc - much appreciated
