colinsunderland
Re: Citroen and Peugeot Parts Requests
Post by colinsunderland »
Hi Marc
Any chance of a part number for the rear left abs sensor
Had it in a garage this afternoon who said the back of the discs rust up quite often and cause the sensor to knock against it so I might have to change the pads and discs too, is that right or is he trying to scam me lol
Are the sensors easy to change does anyone know?
I know the brake switch goes commonly on these, as the auto handbrake isn't working either, and they cause all sorts of errors, it wouldn't be that would it? Diagbox isn't giving a handbrake error but it shows on the dash
Thanks again
x 4937
Post by GiveMeABreak »
Huskyxantia wrote: 29 Dec 2021, 10:43
GiveMeABreak wrote: 29 Dec 2021, 03:55 Item (12) Part: 0515T3 £161.40
I'll have to try and get the other info later
I take it item 12 is the modified pulley ?
No indication of this - it is the original part number with the following dimensions: DIAM 157,75X30 EP 30.
x 4937
Huskyxantia wrote: 29 Dec 2021, 15:23 Needing part number for the spring clamp that holds the pipe onto the turbo intake side. For my 206cc 1.6hdi
Thanks marc.
If its (16) - Elastic Collar, then part: 1434G7
x 4937
Rhothgar wrote: 29 Dec 2021, 13:10
Rhothgar wrote: 26 Dec 2021, 18:02 Whilst I think about it, is 1854.24 the part number for the engine rear lower mount which straps the engine mount (which the intermediate driveshaft goes through) back to the subframe please?
Sorry to pester Marc. Any chance of confirming this pretty please? :oops: That's an embarrassed face by the way. Hope you had a good Xmas.
Yes, as far as Christmas this year goes - locked away and stuffing!
These are the engine mountings - no part with number listed. Let me know which item you need from the diagram.
x 4937
colinsunderland wrote: 29 Dec 2021, 16:10 Hi Marc
Thanks again
Couldn't tell you Colin - I've never had one fail ever, but certainly knocks and weathering can cause issues.
Rear ABS Sensor, item (2), Part 4545K8, £74.99
KennyW
Donor 2022
x 127
Parts Diagram Please
Post by KennyW »
Please can the parts diagram be posted for the Underbody protection for my C5 x7
VRN : VF7**************[VIN obfuscated, can be read by forum staff]
Kenny
Reason: Moved to Parts Requests Forum
x 4937
Here Kenny:
I have indicated the main parts you have. If you need part numbers, let me know the item numbers.
Rhothgar
Donor 2023
x 70
Post by Rhothgar »
GiveMeABreak wrote: 29 Dec 2021, 21:10
I’ll have a 10 please, Bob!
If cross referencing is available great. If not, no problem 1854.24 I hope.
Huskyxantia
Donor 2023
x 250
Post by Huskyxantia »
GiveMeABreak wrote: 23 Dec 2021, 17:40 Here you go:
If it's the gas temperature pipe / sensor that is item (1), part 1618LS, £135.44
Item (4) is the actual DPF Differential Pressure Sensor and that part may no longer be available (1618LP), so they recommend using part 1618Z9, £96.59
Pipes:
(7) is the pipe upstream of the sensor 1618P2 (no longer available)
(9) is the pipe upstream pf the particle filter 1618P4, £19.91
(8) is the pipe downstream of the sensor 1618P3 (no longer available)
(10) is the pipe downstream of the particle filter 1618P5 (no longer available)
4 number 72's , i checked my routing of these pipes today and they were on the other way, so i changed them, things is my engine light came on this evening while driving so tomo im putting them back how they were .
Reason: fixed quote code
x 4937
@ Husky:
Item (72) Part: 6981P4, 67p each. Be aware, I've known PSA to sell minimum order quantities of these types of clips - I ordered another type some years back for the boot fizings and ended up having to buy a bag of 25!
Huskyxantia
Donor 2023
x 250
GiveMeABreak wrote: 29 Dec 2021, 22:39 @ Husky:
Ive been had that way many moons ago
Huskyxantia
Donor 2023
x 250
Hello marc
Have you part number for Turbo air pipe sleeve for 206cc 1.6hdi, why do mine split so easy ?
x 4937
Huskyxantia wrote: 30 Dec 2021, 12:35 Hello marc
Turbo Air Piping: Let me know item.
If Air Hose from Air Intake, advise of item number from Diagram from other post here:
viewtopic.php?p=705811#p705811
Huskyxantia
Donor 2023
x 250
GiveMeABreak wrote: 30 Dec 2021, 12:42
Other side of the turbo its the orange rubber piece, air in take seal ? I think
Huskyxantia
Donor 2023
x 250
GiveMeABreak wrote: 29 Dec 2021, 21:06
Thanks marc.
Number 14 is the part ive had 2 go within a few months
