Sighmoon
Donor 2023
Unread post by Sighmoon »
Hi - tyring to find original part number for lower front axle bearing to fit CITROЁN C5 III Estate (RW) 2.0 HDi 165 ( 2009 ). Thank you.
x 1122
dylan26__ wrote: 26 Jan 2024, 19:16 What reverse bulb does my car take? VF7**************[VIN obfuscated, can be read by forum staff]
I think item 14, which is H21, which seems to be a slender bayonet type.
x 1122
danlat1415 wrote: 26 Jan 2024, 21:26 VF7**************[VIN obfuscated, can be read by forum staff]
Please could I get the part number for rear wheel bearings?
Oddly, the one for older cars, which is usually a cheaper part, is actually more expensive.... £188.51 vs £134.28
x 1122
Sighmoon wrote: 27 Jan 2024, 18:34 Hi - tyring to find original part number for lower front axle bearing to fit CITROЁN C5 III Estate (RW) 2.0 HDi 165 ( 2009 ). Thank you.
Need VIN to confirm what's fitted, this is an example - which part are you looking for?
Sighmoon
Donor 2023
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Part Number 14
Thanks again!
x 1122
Ah, the infamous 'frip' joint!
OE part 364069 @ £196.03
Cheaper equivalent part for older cars 1682730080 @ £105.43
Rhothgar
Donor 2023
x 106
Unread post by Rhothgar »
HNY Marc!
Hope you had a nice Xmas too.
Please may I have part number / sizing of o-rings which fit in the strut tops. This is for M728 GDL but the strut tops have been upgraded to hydractive...
The rams fit so the internals are clearly the same bar the pipe diameters.
I have a leak on the strut legs.
Apparently, there are seals that sit above and below the LHM supply oil in the tops.
Sectioned strut top photo copyright and courtesy of Andrew Cox.
x 6398
Ok, so I think you are after (11) Suspension Cylinder O Ring, which for your original vehicle is part: 96145321 (TOR A 18 T2),
(7) In case you need it is no longer available, but was part 96127273 (53,9X53 E5).
Now for the ES9J4 Injection and other variants, (11) is part 527140 (DIAM 27-TO 1,9) but no longer available.
These are the only 2 O rings shown for all the other variants for (11), your original one and the one above.
Rhothgar
Donor 2023
x 106
Thank you Marc.
That's very helpful.
So it looks like there is only ONE (96145321) required per strut top?
I wonder if the leak is designed to lubricate the rod.
I think they are no longer available but could I please have the part number for the gaiter for X435 JGJ. When I replaced the strut tops on that car, the gaiters fitted back fine so I will need a pair of those for the S1.
Thanks again.
x 6398
If I understand you correctly you want the gaiter for X435:
(6) Front Cyl Boot, part: 527192, No longer Available
Rhothgar
Donor 2023
x 106
Yes. Marc. That was absolutely correct.
One final thing - I've just noticed that no. 12 is also required for M728 please. I am sure that no. 12 for X435 is no doubt the same anyway.
Thanks in advance.
x 6398
No (12) for M728, Suspension Cylinder O Ring (TOR A 21 T2,45), part: 96065851.
BVL
Unread post by BVL »
Could i request some part numbers please ?
Looking for part numbers of the differential drive shaft seals on ML6C 20MB39 gearbox
And is there a procedure for changing the clutch as im going to replace that as well ?
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanx !
x 6398
Let me know which item numbers you need from the following, note that A, B, C, D, E & F are not available from Peugeot separately, but are included as parts of either 8, 9 or 10.
BVL
GiveMeABreak wrote: 29 Jan 2024, 22:09 Let me know which item numbers you need from the following, note that A, B, C, D, E & F are not available from Peugeot separately, but are included as parts of either 8, 9 or 10.
Hi Mark,
I like to know the part numbers from 1 and 13
Thanks,
Bart
