- x 6405
(Note: this is now a different shape due to supplier change, but part can be fitted.)
- x 1643
Hi, few queries on the 308 SW 1.6 HDi, six speed manual.
VIN
Can you please confirm part number for the following:
- Engine bay undertray (aftermarket seems to be two types a long one and a short one!)
- oil filter (Autodoc putting the wind up me with two different types looking at the pictures!)
- coolant: should I be looking for an OAT type (or one without porridge?)
- alternator: part number and / or confirm if this is clutch pulley type?
- gearbox oil type / part number? (I'm assuming 75W80 API GL4 but thought best to check) actually quantity too would also be helpful.
I've just renewed my membership, hopefully has shown up.
Extra waffle/ detail here:
viewtopic.php?p=785715#p785715
Thanks as usual
Matt
VIN
Thanks as usual
Matt
- x 6405
(8) Oil Filter
OEM part: 1109AY, £18.54
Cheaper Alternative, part: 1687120580, £9.40
Coolant
PSA use Freecor
Part: 1637756380: Freecor DSC Fluid (Ready for use), 2 litre container, £11.06
Part: 1637756080: Freecor DSC Anti Freeze 1 Litre Container, £9.31
Alternator
This is a 'Reversible Alternator' type.
New 180 Amp Valeo (IST60C028) or (IST60C017) OEM, part: 5705PA, £1720.15
Valeo Exchange (IST60C028) or (IST60C017), part: 1625944380, £871.70
Gearbox Oil
Total Transmission BV SAE 75W80 (Before the 01/01/2012 or up to the RPO number 12836)
Your RPO is 12748, so this is the recommended oil.
- x 1643
Brilliant, thank you Marc!
- x 4
Would it be possible to get part numbers for the front wiper blades on my 2015 c4 grand picasso ?
Vin number is VF7**************[VIN obfuscated, can be read by forum staff].
Many thanks
Many thanks
- x 6405
OEM Original, part: 1642333780, £41.82
Right
OEM Original, part: 1642336080, £41.82
- x 4
Hi Marc,
Please could I have the part number for the blower motor resistor vin VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks in advance.
- Donor 2023
Hi Marc,
Hope you are well
I guess my message from 4 January was missed
Can I have the numbers of these parts please?
- FRONT SHOCK ABSORBER CUP KIT
- FRONT BRAKE DISCS
- FRONT BRAKE PADS
Oh and also the number for the part, don't know the proper name but I need to replace the small motor on the rear wheel which enables/disables break pads when hand break is used.
Thank you!
Hope you are well
- FRONT BRAKE DISCS
- FRONT BRAKE PADS
Thank you!
- x 6405
Sure, but first of all please be aware that your vehicle has an outstanding After-Sales Campaign, reference HTM, that concerns a Safety, Emission or Compliance Recall. It requires an engine management software download. The work will be free of charge, so I would arrange to have it booked in at your nearest dealership.
(4) Heater Motor Control Module, part: 1618030980, £204.28 inc. VAT direct from Citroen.
- x 6405
Sorry, must have missed that.dave101ua wrote: ↑07 Jan 2024, 15:34 Hi Marc,
Hope you are well
- FRONT BRAKE DISCS
- FRONT BRAKE PADS
Thank you!
Do you mean the cup for the front springs?
I'll put these in case this is what you mean:
(2) Front Suspension Rest Cup, part: 9817592480, £38.14
(3) Front Suspension Bump Stop, part: 9831145480, £23.26
(6) Cup, part: 9806642780, £8.72
(7) Cup, part: 9678749180, £5.48
(7) Back-Up Caliper Motor, part: 1617535580, £147.60
(1) Original OEM Ventilated Front Discs (DIAM 304 EP 28), part: 4249K1, £146.78
Cheaper Alternative Discs, part: 1687772080, £68.86
(4) Set of 4 Front Brake Pads, part: 1647863680, £149.98
- x 4
Hi, would it be possible to get the part number for the near side mirror indicator repeater led on my c4 grand Picasso please? Vin is VF7**************[VIN obfuscated, can be read by forum staff].
Many thanks
Many thanks
- x 6405
(8) Side Flash Unit (Left) , part: 6325J4, £90.02
- x 4
Many thanks again!
- Donor 2023
- x 6
Good evening. I'm getting the runaround on the correct brake disks and pads for my car. Two different sizes apparently. Could you possibly tell me the part numbers used for the front and rear. Both pads and disks please.
I also need to know the correct battery aswell please.
Kind regards
Duncan.
Kind regards
Duncan.
