- x 6373
(4) Front Disc Padfs Set, part: 1617274580, £35.74
- x 21
Can i get the strut top mounts please?
- x 797
They dont sell a kit like aftermarket ones, you need all the bits seperate.
- x 797
This is the only thing i could find that looks close & its showing a no longer available. Part no 699529
- Attachments
- Donor 2023
- x 382
Hi Marc,
Could i have a part number for an engine oil dipstick for Vin VF3**************[VIN obfuscated, can be read by forum staff] please. The yellow plastic puller has broken off.
thanks
Colin
thanks
Colin
- x 6373
(4) Engine Oil Gauge, part: 117461, £24.40
- Donor 2023
- x 382
Thanks Marc star as always
Colin
Colin
- Donor 2023
- x 472
Same vin need part numbers for Vacuum Pump GasketsHuskyxantia wrote: ↑15 Dec 2023, 18:36Post here for the same vin.. part number for the oil pump and possible diagram of where it goes and so on Richard mentioned about some oil flange ? Behind the camshaft or crank , sprocket ? When blocked can throw upstream high pressure warning could you just clarify this please marc, thanks.Huskyxantia wrote: ↑13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Many thanks Happy Christmas & all the best for 2024
Husky.
- x 6373
Thanks, best wishes
(2) Vacuum Pump Seal Assembly, part: 455624, £20.66
- x 246
thanks Wheeler, the car is not the best example, and I'm reluctant to buy a pack of 10. So I will try to make something that will do the job......
Stu
- Donor 2023
- x 472
Same vin , could i have part numbers please marc for the front suspension components , leg,spring,mount,lower wish bone arm , top tie rods both inner & outer & drop links for both sides of the car. Thank you. All the best for 2024Huskyxantia wrote: ↑23 Dec 2023, 10:39Same vin need part numbers for Vacuum Pump GasketsHuskyxantia wrote: ↑15 Dec 2023, 18:36Post here for the same vin.. part number for the oil pump and possible diagram of where it goes and so on Richard mentioned about some oil flange ? Behind the camshaft or crank , sprocket ? When blocked can throw upstream high pressure warning could you just clarify this please marc, thanks.Huskyxantia wrote: ↑13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Husky.
- x 6373
Thanks, best wishes for 2024
1) Spring, part: 5002XC, £151.27
2) Bump Stop, part: 5033E5, £30.20
3) Displacement Limiter, part: 503389, £4.08
8) Protector, part: 525448, £15.94
10) Mounting Kit, part: 5031F2, £63.08
1) OEM Front shocks left / right
Part: 9804586980, £101.09
Part: 9804587080, £101.09
Cheaper Alternative Left, part: 1674698580, £83.77
Cheaper Alternative Right, part: 1674698680, £83.77
5) Wishbone
OEM Left, part: 3520W5, ££198.72
OEM Right, part: 3521S8, £219.59
Cheaper Left, part: 1682734280, £116.47
Cheaper Right, part: 1682734180, £128.70
ARB
OEM Left, part: 508769, £28.72
OEM Left, part: 508768, £28.72
Cheaper left, part: 1634908180, £14.05
Cheaper right, part: 1634908280, £7.50
1) Rod Kit
OEM, part: 3812E8, £71.03
Cheaper, part: 1635769980, £23.66
2) Ball Joint Kit
OEM Left, part: 1628950480, £106.24
OEM Right, part: 1628950380, £106.24
Cheaper Left, part: 1635772380, £44.14
Cheaper Right, part: 1635772180, £44.14
6) Nut, part: 4010F5, £3.60
5) Wishbone
ARB
1) Rod Kit
2) Ball Joint Kit
- Donor 2023
- x 472
Same car same vine , part numbers for the exhaust system cheers marc.Huskyxantia wrote: ↑31 Dec 2023, 10:46Same vin , could i have part numbers please marc for the front suspension components , leg,spring,mount,lower wish bone arm , top tie rods both inner & outer & drop links for both sides of the car. Thank you. All the best for 2024Huskyxantia wrote: ↑23 Dec 2023, 10:39Same vin need part numbers for Vacuum Pump GasketsHuskyxantia wrote: ↑15 Dec 2023, 18:36
Husky.
- x 6373
Front, intermediate or rear, Cat / DPF?
- Donor 2023
- x 472
Front and intermediate please marc
Husky.
