Sloppysod
x 246
Unread post by Sloppysod »
Re:- Peugeot 206 Lower Fuse Box Cover Panel Fixing.
Hi Marc, could you please find me the part numbers of the fixing for this panel, the main number I need is the little screw but any plastic clips may also be helpful?
Thanks in advance
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6398
VIN please Stu.
Sloppysod
x 246
Ooops- Sorry.
Cheers
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
walter
Donor 2023
x 4
Unread post by walter »
Could you please supply me with the part numbers for the n/s and o/s front brake discs and pads for the Peugeot 208 69 plate VF3**************[VIN obfuscated, can be read by forum staff] thanks.
x 6398
Front
(1) Front Disk Kit Ventilated (2)
OEM Original, part: 1647868480, £196.12
Cheaper Alternative, part: 1686717180, £64.40
(3) Front Pads
OEM Originals, part: 1682206780, £107.54
Cheaper Alternative, part: 1617282980, £28.86
x 6398
Sloppysod wrote: 19 Dec 2023, 12:03 Re:- Peugeot 206 Lower Fuse Box Cover Panel Fixing.
Thanks in advance
A bit confused as to what you want Stu. Picture is from a left hand drive by the looks of it, so let me know what bits from the glovebox diagram if this:
LHD / RHD drive are different and the picture does not seem to even show the same fitting...
Sloppysod
x 246
Wrong side Marc, this panel covers the fuse box under the steering wheel. There is a small ½ turn screw that attaches it to the dashboard.
Cheers
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6398
Ok, so let's try this one:
(74) Clip part: 699278, £0.31p
(75) Clip part: 6992A7, £0.31p
Huskyxantia
Donor 2023
x 472
Unread post by Huskyxantia »
Sloppysod wrote: 19 Dec 2023, 16:24 Wrong side Marc, this panel covers the fuse box under the steering wheel. There is a small ½ turn screw that attaches it to the dashboard.
Cheers
https://www.aliexpress.com/i/32918854232.html
Husky. :?
x 6398
GiveMeABreak wrote: 19 Dec 2023, 18:09 Ok, so let's try this one:
Forgetting the Glovebox trim, I've gone straight to the Fuse box / BSI which may be what you're after:
If it's (71), it's part: 6925W3. There's nowhere else I can think of to look.
Sloppysod
x 246
Thanks both but still stumped, the fastener I'm after is a ½ turn bolt.
The partnumber of the panel is 9625746377, the fastener goes through the lower middle of the panel, the panel covers the fuse box under the steering wheel, just above the 2nd finger in the original photo.
Thanks.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6398
I've checked that part number and it's not returning anything on any vehicle, so Peugeot must have an internal number for it.
Sloppysod
x 246
That looks like the part I expected to see, and really great that they give some dimension too!
It's for my 92 year old neighbours car, I have sort of adopted the looking after bit. He travels about 200-250 miles a year but the Peugeot garage still wants to charge him a full service, plus, anything else they could find. The fastener is missing and the panel was held on with black electrical tape! There's no way it is something he would have done and he has had the car from new.
Thanks again, Never bought from AliExpress so.......................... :?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 801
Unread post by wheeler »
Thanks in advance
Looks like number 5 to me.
Part no 8214HR £84.26 inc VAT
EDIT: thought it was the actual panel you were looking for. Ooops
Chris1974
Donor 2023
break parts
Unread post by Chris1974 »
hi me again in need of some help I'm looking for some parts I need CALIPER RH FR BRAKE and front Brake disc
Reason: Moved to Parts Thread
