x 6405
Hi
Normally the hydraulic Block is listed separately, but in this case for your vehicle, the block (1) is NOT shown, only the bolts!:
So I don't have a part number for you as it's not listed for this engine combo.
Your engine is shown as a DW10FC Bharat 6.2 which to me is one of the Indian Emission Control indicators / standards! :shock:
drayton11
Donor 2023
Unread post by drayton11 »
Ok. Thanks very much for looking. Guess I will have to take it apart when it warms up.
x 6405
Interestingly, just to add, they only supply a standard exchange gearbox for this now, so don't even list a new original gearbox.
In case it helps, the markings on the box are: GZ09 or GZ07.
The exchange gearbox is part: 1637848180, £4900.02 inc. VAT
Huskyxantia
Donor 2023
x 472
Unread post by Huskyxantia »
Huskyxantia wrote: 13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Post here for the same vin.. part number for the oil pump and possible diagram of where it goes and so on Richard mentioned about some oil flange ? Behind the camshaft or crank , sprocket ? When blocked can throw upstream high pressure warning could you just clarify this please marc, thanks.
Husky. :?
x 6405
(1) Engine Oil Pump, part: 1001G8, £374.17
(2) Engine Oil Pump Strainer, part: 101866, £57.94
quintet
Donor 2023
x 41
Unread post by quintet »
Hello, could i put in a request for a passenger seat airbag unit, VF3**************[VIN obfuscated, can be read by forum staff] . I'm going to look around for a complete seat but failing that i'll change the airbag in the seat. I know there's at least two types of airbags fitted to the NSf, my vehicle has only one (4 way) green plug under the seat. (earlier 307's had two wiring plugs under the passenger seat).
Thank you.
Music keeps me going.
x 6405
I must of missed the 'side' from your request. These are still available:
(1) Pyrotechnic Side Airbag (Left), part 8216LR, £536.48
(4) Side Airbag Crown (Left), part: 8216FW, £33.40
Huskyxantia
Donor 2023
x 472
Huskyxantia wrote: 15 Dec 2023, 18:36
Huskyxantia wrote: 13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Marc, please could i have part number for the osr fog light
Same vin number Citroën c3 picasso . Thanks
Husky. :?
x 6405
(6) Rear Right Fog Lamp, part: 6351HJ, £83.45
nomad123
Unread post by nomad123 »
VIN : VF7**************[VIN obfuscated, can be read by forum staff]
Hello again!
I need part numbers for the following parts:
1. Clutch kit
2. Dual mass flywheel
3. Clutch master cylinder
4. Clutch slave cylinder
5. Engine clutch fork
6. Clutch fork ball joint
Thanks 😊
x 6405
DMF
(11)
OEM DMF, part: 0532X7, £923.42
Exchange DMF, part: 1613938680, £589.79
(13) Lock Bolt (essential to replace), part: 1682800980, £1.57
Clutch
(10) Clutch Master Cylinder, part: 2182J6, £120.94
(11) Clutch Slave Cylinder, part: 2182J5, £80.69
(1)
Pro Clutch, part: 1611271780, £508.50
Cheaper Clutch Kit, part: 1680365680, £301.20
Exchange OEM Clutch Kit, part: 2051N9, £278.89
(5) Clutch Fork, part: 9808513380, £62.86
nomad123
Thank you!
I have found Original PSA DMF and clutch kit on EuroFrance website.. DMF is 393e and clutch kit is around 230e. Thats half the cost than stated here. Is this website legit?
x 6405
You can find OEM parts cheaper - it depends on what it is, just make sure you get what you paid for as these people supply used parts too.
Huskyxantia
Donor 2023
x 472
Huskyxantia wrote: 17 Dec 2023, 09:16
Huskyxantia wrote: 13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Marc whats the part number for the oil filter ? Same vin number
Cheers.
Husky. :?
x 6405
(8) Oil Filter
OEM, part: 1109AY, £18.95
Cheaper, part: 1687120580, £9.40
