- Donor 2023
- x 382
Thanks Marc much appreciated.
Colin
Colin
Sorry Marc to bother you again, forgot to ask you how much of the stuff goes in it (car) after I dilute it 50/50 (is it 50/50?)? I've asked the dealership, but they are clueless...GiveMeABreak wrote: ↑07 Dec 2023, 11:22 For all non-collaborative vehicles, so not for the following:
PSA use Freecor Coolant.
Ready to use:
2 litre: 1637756380, £11.06
5 Litre: 1637756480. £23.99
10 Litre: 1637756580, £40.94
20 Litre: 1637756680. £101.75
- Marko
- x 6373
This is ready mixed and ready to add:
- Donor 2023
- x 472
Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]
Husky.
- Donor 2023
- x 4
I’m after the part number for the sump plug washer please
VR7**************[VIN obfuscated, can be read by forum staff]
- x 6373
@Walter:
(2) Engine Oil Drain Plug, part: 031139, £2.12
- x 6373
Husky - for reference, please note that in the VIN there are no character 'O's, just numeric 0'sHuskyxantia wrote: ↑13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]
(28) Engine Oil Pressure Switch, part: 1131K9, £66.28
- Donor 2023
- x 4
The washer please not the plug looks like no3 on picture thank you.
- x 6373
Oops , (3) Plug Seal, part: 016488, £2.40
- Donor 2023
- x 472
- Donor 2023
- x 472
ok, so this is the wired type .GiveMeABreak wrote: ↑13 Dec 2023, 16:29Husky - for reference, please note that in the VIN there are no character 'O's, just numeric 0'sHuskyxantia wrote: ↑13 Dec 2023, 15:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Husky.
Vin : VF7**************[VIN obfuscated, can be read by forum staff]
Hello, my engine temperature is fluctuating between 5 and 7 bars on the dashboard.
Driving with Lexia the coolant temperature is fluctuating between 68 and 78 degrees, up and down.
It can't reach normal operating temperature of around 83 degrees.
The main suspect is thermostat.
So I need part number for my vehicle.
I have found thermostat with this part number 1336Y9, is this the right part for my vehicle or not?
Thanks!
Thanks!
- x 6373
@nomad123
1336Y9 is the complete outlet unit and includes ALL parts in the (1) in the diagram. I've included the temperature sensor alone in case that is what you are after.
(1) Engine Water Outlet Tank, part: 1336Y9, £201.46
(2) Water Temperature Sensor, part: 1338C4, £67.00
Thank you very much.
- Donor 2023
Hi My VIN is VF3**************[VIN obfuscated, can be read by forum staff]. Could I please have the part number for the Automatic Gearbox valve body. Many Thanks.
