- Donor 2023
- x 9
Hi Marc
I'm wondering if this part is available on it's own or is it part of the full side panel?
VR3**************[VIN obfuscated, can be read by forum staff]
- x 6397
Front Wing Inner Frame (Left), part: 1646180980, £330.82
(1) Post Stiffener (Left), part: 1646182980, £208.04
- Donor 2023
- x 9
It's 13 on the top pic, 3 on the bottom one
- x 6397
Ok, so (13) & (3) is the Passenger Compartment Front Strengthener, part: 9823289980, £66.92
- Donor 2023
- x 9
Hi Marc can I have the price for a front NS lower control arm, all four seatbelts and an airbag/SRS module please?
- x 6397
(1) Pyrotechnic Safety Belt Right, part: 98266702XX, £434.52
(1) Pyrotechnic Safety Belt Left, part: 98266703XX, £434.52
(5) Seat Belt Buckle Strap, part: 98135293XT, £113.96
(1) Seatbelt Right, part: 98412247XX, £341.56
(1) Seatbelt Left, part: 98412248XX, £341.56
(3) Rear Buckle Left, part: 98265554XT, £91.93
(4) Rear Buckle Right, part: 98265562XT, £133.70
(5) Rear Seatbelt Centre, part: 98265640XX, £350.77
(1) Airbag Control Unit, part: 1657637780, £427.40
- Donor 2023
- x 9
- x 5
What is the part number for Air Con Compressor for DS5 Hybrid VF7**************[VIN obfuscated, can be read by forum staff]?
I found one on eBay https://shorturl.at/cIKS5 but unsure if it will fit my DS5. This part is for 165hp engine, whereas mine is 200bhp.
- Donor 2023
- x 9
Hi Marc can I have the part number and price for both bonnet hinges and these please?
Part E and the two screws
The two headlight screws Thanks
- x 6397
Bonnet Hinges
(2) Bonnet Hinge Left, part: 9823211680, £74.92
(2) Bonnet Hinge Right, part: 9823211580, £74.92
Bumper
(17) Bumper Support Set, par: 1649826580, £46.48
(73) Screw with Washer, part: 623006, £2.45 ea
(Note (73) above is the same screw for the Headlamps)
Bumper
- x 253
Hi Marc, is the pulley for My C5's alternator available separately?
- Donor 2023
- x 9
Thanks Marc
Both of my headlights were held in with these And my wing supports were held on with these Can you double check the screws please? Maybe mine has the wrong screws in either the wing supports or headlights.
- x 6397
For your 3.0 HDI, Jay:
(3) Alternator Pulley, part: 1611422780, £75.06
(4) Alternator Tensioner Roller, part: 1611424480, £145.94
- x 6397
Yes the headlight screws are correct: part 623006 (Diam 6-30) Screw with washer £2.45 ea, detail:
I'm not sure which diagram you are referring to for the above, as they aren't shown on the wing Schematic: unless you are referring to a different diagram?
- Donor 2023
- x 472
VF3**************[VIN obfuscated, can be read by forum staff] Needing all part numbers for the front shock,spring and everything else that goes with it need to check what I've got is correct as ive a feeling something is missing thanks marc
Husky.
