- Donor 2023
- x 98
Hi sadly my Citroen C5 X7 has just failed it's MOT because of damaged rear brake cables...
Could I have part numbers for both rear brake cables please?
- x 6397
viewtopic.php?t=76480), they are only available from Citroen as part of the complete electronic handbrake assembly.
(2) Handbrake Mechanism
Original Part: 470208
Superseded (removal of emergency release cable), part: 1612865480, £1358.58
(73) Closer, part: 698343, £0.92
As Matt eluded to Chris (now posted here: (2) Handbrake Mechanism
- Donor 2023
- x 98
Thanks Marc - what are the closers for?
- Donor 2023
Can you please inform me what is the part number
Thank you
DS7 Crossback plug in 4x4 Opera
Thank you
- x 6397
These are the bits that go in the ends of the EPB and aren't shown separately on the diagram.
- x 6397
(1) Wireless Charger, part: 9813403280, £143.20
(2) Battery Charge Indicator, part: 9816001880, £55.81
(3) Wireless Charger Indicator Light Guide, part: 9816019480, £20.56
(4) Storage Compartment Trim, part: 98215271ZD, £34.19
- x 1639
Hi, not so much a part number request, but check on quantities:
Gearbox oil capacity, 406 Coupe HDi (ML5 manual gearbox)
Haynes reckons "1.9 litres (1.8 after drain and refill)" presumably for all gearboxes. I know that is correct volume for the BE gearboxes, can you confirm same for bigger ML gearbox too please?
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanks a lot
Edit as Autocorrect/sausage fingers seems keen to generate "496" not "406"!!
Thanks a lot
- x 6397
It's official capacity is listed as 1.85 for the ML5T Matt.
- x 1639
Spot on, thank you
(Only about 1.5 at most came out, so likely was a touch short!)
- Donor 2023
Morning folks,
I broke the bonnet opening handle under the bonnet of my X7 yesterday after I was topping up the washer fluid and lubing
the lock mechanism. Can I get a part number for it please. Chassis number is VF7**************[VIN obfuscated, can be read by forum staff]. (RHD) Thanks.
- x 6397
(9) Bonnet Safety Hook Lever, part: 7937R0, £33.55
- Donor 2023
- Donor 2023
Hi Marc could you please advise me on the correct transmission oil for my ds5 automatic 13 plate as I want to change it kind regards geoff
- x 6397
You require JWS3324 oil for your automatic Transmission on your Euro 5 DS 5
- x 846
On a serious note, can you supply me with a diagram on what valves to open when doing a coolant change please.
Champion of Where's CitroJim
