Original part is no longer available, but replaced with: 1634882580. Price £20.20 inc. VAT as of posting direct from Citroen.
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5728
Re: Citroen and Peugeot Parts Requests
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
Lovely Marc. Not a bad price for OEM either. I don't suppose you can extract the original superceded part number can you? It's not 96145457 is it?GiveMeABreak wrote: ↑18 Dec 2021, 11:09Original part is no longer available, but replaced with: 1634882580. Price £20.20 inc. VAT as of posting direct from Citroen.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes that was the original part number.
- Donor 2023
Brilliant. Thank you ever so much as per usual Marc.
- Huskyxantia
- Donor 2023
- My Cars: Past cars
Xsara Picasso 2019 to 2022 r.i.p
Xantia mk1&2 1.9D & 2.0Hdi
Peugeot 206 sw 1.4hdi
Other models
Skoda fabia,escort van,ford ka,Vauxhall astra g car & estate, Vauxhall corsa b, Suzuki swift
Escorts mk 1,2,3,4,5 fiestas mk 1,2, Sierra diesel mk1 Mondeo mk1 diesel .
Peugeot 207 , 307sw
Now cars
Picasso 2.0Hdi now gone to scrappie
Citroen zx estate 1.9D the cherished one
Peugeot 206cc raised from the dead & saved from the crusher traded up to a 308cc
307sw traded for the 207 .
Wish list.
Peugeot 405 diesel
106 or 206
Mondeo Mk1 diesel once owned 1.8tdi was real nice. - x 424
Needing the correct number for a radiator water one for my 206cc 1.6hdi. Thanks in advance..
Husky.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Radiator:Huskyxantia wrote: ↑19 Dec 2021, 09:35 Needing the correct number for a radiator water one for my 206cc 1.6hdi. Thanks in advance..
OEM Original part: 1330N2, £429.06
Peugeot Exchange Radator: 133356, £268.68
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Please note the general conversation re the rad has been moved (link below) - and out of parts requests.
viewtopic.php?t=70213
- cs101
- (Donor 2021)
- My Cars: EXPERT 4 (KO) VAN L2 1.6 HDI 115 FAP (DV6FCU) STT TYPE 6-SPEED GEARBOX
- x 6
Hi,Marc!
Please can you give me gearbox oil capacity for VIN VF3**************[VIN obfuscated, can be read by forum staff].
And also the part number foe the Air filter Grommets (the rubber which holds the air filter cover). Thanks
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
If changing the oil, you should measure what comes out and replace with the same quantity.
Oil Capacity after emptying for DV engines:
1,9 litre (Gearbox casing with fins)
2,6 litres (Gearbox casing without fins)
Oil capacity after overhaul for DV Engines:
2,2 litres (Gearbox casing with fins)
2,9 litres (Gearbox casing without fins)
As for the Air Filter, they don't show the AF cover fixings as separate parts...
- cs101
- (Donor 2021)
- x 6
Thank you very much, Marc.
- Donor 2023
M728 passed MOT with flying colours today.
Managed to get a joblot of 6 droplinks for £16.99 delivered!!!
All for M728:-
Could I please have part numbers for all central door locking mechanisms please including boot solenoid when you have a moment?
Original and latest part numbers would be very much appreciated.
Also, is there a part number for the rear boot windscreen perimeter seal (that is around the perimeter of the glass). My mate reckons it probably comes as part of the rear screen which is also probably NFP.
Time to get on top of this baby now and get her back into tip top functional condition.
All for M728:-
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
This is the door control mechanism diagram. Obviously there are too may parts for me to list all these. Let me know which items you want part numbers for:
As for the tailgate weather strip, item (17) it is available separately and still available. Part 870746, £82.34
Obviously, the glass is bonded to the vehicle, but the tailgate rubber weather strip is available as said.
- Donor 2023
Cheers Marc.
It would be all Part 1 in the top picture that I would like for each door.
I am not sure that strip is the one I am looking for as I think Part 17 goes around the edge of the panels when the tailgate is open. I am looking for the weatherstrip that goes around the perimeter of Part 4 tailgate glass especially looking at the cross section of Part 17. That looks like the seal that seals between tailgate and car body panels not tailgate glass to Part 1. Fingers crossed it is on a glass fiche?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Doors:
Front
Right 9136J6 (1 Plug) £146.88
Right 9136H9 (2 Plug) £160.24
Left 9135H1 £146.88
Rear Door Locks Rear
Left 913744 (2 Plug) £173.62
Right 913859 (2 Plug) No Longer Available.
Rear Windscreen
So no, there is nothing else shown. The glass is bonded - just like the front windscreen. The only trims are item (2) left and right for the sides, but nothing else.
Front
Left 9135H1 £146.88
Rear Windscreen
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Marc, when convenient for you i need as follows
Part number for dpf sensor and pipe position from dpf to sensor
Thank you.
Thank you.
Husky.
