x 4927
Post by GiveMeABreak »
jordyh wrote:
28 Sep 2023, 10:53
Could you please let me know if there is a specific part for the wiring harness from the drivers rear parking brake to (from reading other posts) a connector under the rear seats? Been repaired once so want to replace the entire thing if I can.
Mk2 Picasso VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks,
Jordan.
This is potentially difficult because of where the individual harnesses may split, but these are the harnesses that I think are relevant - but there is no further detail as to where the handbrake control harness is, as that just shows the actual handbrake control unit.
Fascia Harness
(1) Fascia Harness, part: 1610773780, £648.92
Intermediate Harness
(1) Intermediate Harness, part: 1610770680, £1,989.96
Donor 2022
x 456
Post by Rp0thejester »
Hi Marc, can I get the part number for the MAF on my vehicle please
x 4927
Rp0thejester wrote:
28 Sep 2023, 18:00
Ryan, please see the post above here:
viewtopic.php?p=771021#p771021
This diagram and part for the MAF are identical for your vehicle.
Donor 2022
x 456
\:D/ thx bud, your a legend
tearing hair out
Donor 2023
x 13
Post by tearing hair out »
Hi Marc.
Very low-priority - next time you happen to be in looking. Could you grab the part number for the fuel cap sensor (31) from this post for me please? Assuming my MAF issue is resolved and the MOT passes next week, I'll probably finally get around to replacing it.
Oh, and I guess a clutch position switch - which I assume is near the pedal.
I shall keep ignoring the error code about glowplugs, at least until the engine needs to come out for something else.
x 4927
(31) Cap Presence Harness, part: 1503CH (NFP: No Longer Available from Citroen)
danlat1415
Donor 2022
x 16
Post by danlat1415 »
Please could I get a part number for the full right hand side (driver side in UK) door mirror?
Mine has been damaged by a passing car and no longer folds up and down when the car locks.
I know there are different models, so I need to make sure it's correct one.
Mine is Exclusive Plus model with lane guidance and blind spot monitoring
x 4927
Exterior Mirror (Left), part: 1609430580, £670.32
Exterior Mirror (Right), part: 1609431080, £670.32
Romtag
Donor 2023
x 6
Post by Romtag »
GiveMeABreak wrote:
25 Sep 2023, 13:25
Mark: I've moved your post here - your membership upgrade entitles you to request official part numbers, so in future just pop them up on this thread. :wink:
(11) Rear Door Weatherstrip (left), part: 902593, £42.35
(12) Rear Door Weatherstrip (left), part: 902595, £40.06
(10) Door Window Lower Outer Seal (Left), part: 931183, £45.12
(11) Door Window Lower Internal Weatherstrip (left), part: 931184, £39.10
I think the part is part 8, do you have part code for that by any chance?
x 4927
Romtag wrote:
30 Sep 2023, 17:38
(8) Window Channel
Rear Left Side, part: 9300W2, £165.37
Rear Right Side, part: 9300W3, £165.37
dylan26__
Donor 2022
Post by dylan26__ »
Looking for the lower rad pipe. Has decided to burst during my MOT smoke test , had to do it at the worst time lol
x 4927
(2) Radiator Outlet Hose, part: 1351VV, £21.49
dylan26__
Donor 2022
Post by dylan26__ »
Good evening Marc, i seem to be a regular here these days lol
Is there an Aux belt kit for my car?
x 4927
There is indeed, The kit (50) includes the belt (20) and the Tensioner Roller (8):
(50) Ancillary Belt Roller Kit
OEM Original Kit, part: 1611277880, £127.36
DS Cheaper Alternative Kit, part: 1613444880, £38.10
dylan26__
Donor 2022
Post by dylan26__ »
GiveMeABreak wrote:
03 Oct 2023, 23:19
This works with the a/c compressor too? i don't see it in the diagram there
