x 4930
Post by GiveMeABreak »
No, your caliper isn't electrically operated, but it is controlled by cables via the electronic handbrake, but there are no electronics on the caliper itself.
(4) Rear Brake Caliper (Left), part: 1610900880, £396.74
(5) Brake Caliper Yoke, part: 4404G2, £232.30
Donor 2023
x 2251
Post by Hell Razor5543 »
GiveMeABreak wrote:
18 Sep 2023, 19:45
If it's (8), then part: 1579PJ, £129.94
As parts 8 and 21 still available? If so, how much is 21? What is the part number for 8? Thanks.
Huskyxantia
Donor 2023
x 247
Post by Huskyxantia »
Is there part numbers for the road wheel bolts ? For 308cc vin
Dunkah
Donor 2023
x 4
Post by Dunkah »
Hi Marc, the battery clip on my battery tray is a little broken, can you sort an exploded diagram
Many thanks
Vin VF7**************[VIN obfuscated, can be read by forum staff]
x 4930
Hell Razor5543 wrote:
27 Sep 2023, 12:51
GiveMeABreak wrote:
18 Sep 2023, 19:45
I would tell you if parts were NOT available James.
(21) Fuel Return Pipe, part: 15731E, £30.44
I've already provided the part number for (8) in the original reply.
x 4930
Huskyxantia wrote:
27 Sep 2023, 16:02
For alloy wheels, the bolt (12X125) is part: 9817024580, £6.24 each
Huskyxantia
Donor 2023
x 247
Thank you marc.
x 4930
Dunkah wrote:
27 Sep 2023, 21:14
Many thanks
You won't have all the parts shown on this diagram, so let me know any item numbers for which you require a part number for.
Dunkah
Donor 2023
x 4
Post by Dunkah »
Don’t think it appears on that diagram as a numbered part. It’s the twist lock part of the clip, pics attached
Possibly part 17?
Or part no 20 to include the whole tray?
Donor 2023
x 2251
GiveMeABreak wrote:
27 Sep 2023, 21:57
27 Sep 2023, 12:51
GiveMeABreak wrote:
18 Sep 2023, 19:45
Sorry, my mistake. I meant 21! Thanks for your help, Marc.
tearing hair out
Donor 2023
x 13
Post by tearing hair out »
Hi Marc,
Could I trouble you for a part number for a mass airflow sensor for my C8 please? I haven't got the VIN to hand, but I think you should still be able to see it here: viewtopic.php?p=759416#p759416
(Interestingly, you've previously told me the parts catalog doesn't show a fuel cap presence sensor on mine, but I've definitely got one - I've tried unplugging it and the computer instantly decides the fuel cap is in place, but the sensor is permanently closed-circuit ("cap missing").)
Kind regards,
Paul
x 4930
Dunkah wrote:
27 Sep 2023, 22:49
Possibly part 17?
Yes part (20) contains the locking mechanism and is not available separately.
(20) Battery Tray, part: 6545SJ, £70.15
jordyh
Donor 2022
Post by jordyh »
Could you please let me know if there is a specific part for the wiring harness from the drivers rear parking brake to (from reading other posts) a connector under the rear seats? Been repaired once so want to replace the entire thing if I can.
Mk2 Picasso VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks,
Jordan.
x 4930
tearing hair out wrote:
28 Sep 2023, 09:33
Hi Marc,
Kind regards,
Paul
Ok, so as for the fuel cap sensor, there are 2 variants of the system fitted to the C8 and I previously must have looked at the other alternative. So in your case it will be this diagram which shows it at (31):
MAF
(21) Flowmeter (Diam 80), part: 1920AG (NFP: No longer available from Citroen)
You should still be able to get one on the aftermarket using this part number.
tearing hair out
Donor 2023
x 13
Thanks Marc - yes they seem to be available for about £40. Just wanted to be sure I was getting the right one. :-)
(Oh and how much I used to dread "NFP" while I was running a CX...)
