x 4923
Post by GiveMeABreak »
Confusingly, the part is the same (!) for both with and without ABS
(1) Hydraulic Fluid Return Harness, part: 5270R6 (No Longer Available).
x 692
Post by xantia_v6 »
The LHD version is available after market, but would need extending to the RHD brake valve.
https://www.drxantia.com/index.php/en/p ... B&keyword=
Rhothgar
Donor 2023
x 70
Post by Rhothgar »
Afternoon Marc,
No particular rush but could I have the diagrams for the air con on the HDi please and any servicing information that might be available too please?
kuhar
Donor 2022
Post by kuhar »
Hello Marc,
It should be easy to find these (image attached):
- right rear tail light
- right rear reflective-only (cat-eyes) plastic
- rear wiper rubber/gummi (I only need the rubber part, not the whole wiper, or is it all-in-one?)
Thank you!
RuiV
Donor 2023
Post by RuiV »
GiveMeABreak wrote:
06 Sep 2023, 22:31
@RuiV
I need to change the whole kit (belt, whater pump, tensor,...). It has a unique part number (the kit). Can you help me?
x 4923
(18) Coolant Pump & Timing Kit, part: 1638159680, £350.52
x 4923
kuhar wrote:
11 Sep 2023, 09:07
Hello Marc,
Thank you!
Lights
(1) Rear Lamp (Right), part: 9676853880, £284.14
(5) Rear Complementary Lamp (Right), part: 9676122880, £132.08
Rear Wiper
(2) Rear Wiper Blade Holder, part: 1609428380, £35.53
Huskyxantia
Donor 2023
x 247
Post by Huskyxantia »
Vin . VF3**************[VIN obfuscated, can be read by forum staff] needing all the part numbers for the front and rear brake calipers top cover & sliding pins. Many thanks.
x 655
Post by wheeler »
Huskyxantia wrote:
11 Sep 2023, 19:30
Gadgy
New User
Post by Gadgy »
Hi Guys
Please can someone help a scum.bag has decided to rip off the DOOR CARD SIDESKIRT of the driverside backdoor I need to know what the part number is or the part is called so.i can Tey and get a replacement its basically the silver strip.at the bottom.of the car door can someone please help
c16rkc
Donor 2023
x 67
Post by c16rkc »
Hi Marc,
Would I be able to have the Citroen C5 X7 part number for the wiper arm nut covers please? The bit missing in this photo:
Actually the part number and price for the scuttle panel cover would be great too please - as mine is smashed and falling apart :lol:
x 4923
Gadgy wrote:
11 Sep 2023, 21:52
Hi Guys
Please see post one of this thread...
x 4923
c16rkc wrote:
12 Sep 2023, 16:29
Hi Marc,
Hi Chris,
(10) Cowl Air Intake Grill, part: 8251CY, £206.89
(15) Windscreen Lower Crossmember, part: 7140N0, £508.67
Wiper
Just checked and there are no covers on these Chris. I've put the wiper arms here in case though.
(3) Window Wiper Blade Holder, Right, part: 6429EX, £65.58
(4) Window Blade Holder, Left, part: 6429EZ, £61.68
Huskyxantia
Donor 2023
x 247
Can i please have part numbers for front & rear brake pads for my 308cc , vin number VF3**************[VIN obfuscated, can be read by forum staff] many thanks
x 4923
Front Pads
(3) OEM Front Pad Set, part: 1647862780, £122.32
Cheaper Set, part: 1617270080, £45.06
Rear Pads
(2) OEM Rear Pads, part: 1668247680, £82.70
Cheaper Pads, part: 1617250480, £22.19
