- Donor 2023
- x 1519
It might be better - and considerably cheaper - to get a cheapo standalone GPS antenna. The type with a Fakra connector I think is correct. Amazon and Ebay are your friends here.
"Trying is the first step towards failure" ~ Homer J Simpson?
- x 6909
Understood. It makes no mention of NAC though.vaho wrote: 31 Aug 2023, 19:52 Yes, it is not fitted but since I retrofitted NAC I need a GPS antenna. Just wanted to know where it is when fitted. Thank you.
(3) Radio Aerial Adaptor, part: 9674063480, £65.05
I have a generic one under the dash for now and it is not good for picking up satellites. It can be the position but since the original used GPS antenna part costed me 20 euros with shipping and the cable is another 15, it is worth to try. The original part says radio adaptor but it is actually gps aerial with Fakra connector.
- x 247
Hi Marc, can you give me the part number for an injector for my C5. I have three replacement injectors that are supposed to be compatible with it but they won't code to the ECU.I need to make sure I am not mistaken from a part number perspective at least.
Darren
- x 6909
Sure:
(5)
New Complete Injector (CL 5 DELPHI ROISSY), part: 1980S3, £723.22
Standard Exchange Injector (CL 5 DELPHI ROISSY), part: 1980W6, £492.04
Note, these are the latest superseded replacement part numbers as the old part numbers were:
1980K3 & 1980W9 respectively.
PS Don't forget to replace the High Pressure fuel injection Pipes if you are replacing the injectors as these are only designed to be tightened once when fitted. The seals will distort when undone and will not seal properly if re-used.
(5)
- x 22
Hey marc, recently had a front impact on my ds3 so need some part numbers please
need basically the radiator, a/c condenser (and pipes that go into it) , radiator plastic frame thing, the mount that the abs pump is on and i think that's all right now.
- x 6909
Radiator
OEM New, part: 1330P9, £414.30
PSA alternative, part: 1691346780, £180.46
Condenser (1) Condenser
New, part: 6455HF, £515.17
Cheaper PSA Alternative, part: E163371, £117.17
Pipes You'll have to be specific for the pipes, let me have the item numbers form the diagram above.
Fan Motor Driven Fan Unit
(1) New PSA, part: 9801666680, £441.53
(2) Fan Control Unit, part: 9827870080, £99.34
(Not sure if the control unit comes as part of the fan if ordering that, so you'll need to check).
Front Frame
Not sure if this is what you mean:
(1) Front Frame Face, part: 9801492280, £205.22
(1) Radiator:OEM New, part: 1330P9, £414.30
Front Frame
- Donor 2023
Hi
Could I please have the part numbers for the passenger side CV joint & wheel bearing for a Pug 308 GT 180 VIN no VF3**************[VIN obfuscated, can be read by forum staff] many thanks David
- x 6909
Peugeot Exchange Driveshaft, part: 1610276180, £292.70
- Donor 2023
Hi Marc This is a bit in reverse can you tell me what vehicle and where this wiring Loom fits
yp00111980
yp00111980
- x 6909
Sorry, that's not coming up as a valid PSA part.
- x 247
Hi Marc my previous post didn't work, thanks for your help on this I got it running nice I just didn't code them. I've reused pipe loads of times without issue just don't over torque them.GiveMeABreak wrote: 01 Sep 2023, 22:30 Sure:
(5)
Darren
- x 22
The pipes i was looking for is the one that 70 is attached to but i can't see a number for it. Maybe it's numebr 2? the upper and lower pipe that attaches to the condenser. The front frame there i could indeed do with but what i am reffering to with the "frame" is nothing to do with the radiator pack. The abs pump sits / bolts to itGiveMeABreak wrote: 02 Sep 2023, 11:10 Radiator
(1) Radiator:
Condenser
(1) Condenser
Pipes
Fan
Front Frame
- x 6909
I can’t help you without more detail. Perhaps a photo may help. The ABS module is not shown attached. With bodywork it can be anything from what I’ve given you to the front wing to the under body structure etc.
- Donor 2023
Can I have de system dyagram and part number of the Ancilliary system (driving belt, pumps, alternator, etc.)?
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thank you.
Thank you.
